Lq9 xj - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-21-2012, 08:09 PM   #26 (permalink)
breakin shit
gunsnarrows's Avatar
Member # 129396
pics..pressed the new oil seal in and i bent it a tad but i dont think its to bad
PEACE THROUGH SUPERIOR FIRE POWER!GUNS UP! 0331
Last edited by gunsnarrows; 07-21-2012 at 08:12 PM. Reason: scentence dident make sence (alcohol)
gunsnarrows is offline   Reply With Quote
Old 07-21-2012, 08:33 PM   #27 (permalink)
breakin shit
Member # 129396
Originally Posted by DRICH394 View Post
man, the black box is nice, but damn pricy!!, watchign this one....
Yah ther are..and it took me almost 2 months to det it after i ordered it..but the install was extremely easy and i really like how clean they look...and i know aggressive spending does not always equal top notch performance ..
Old 07-21-2012, 09:16 PM   #28 (permalink)
DRICH394's Avatar
Member # 140225
I m just looks for front digs with a go set of gears, but I'm worried about busting the 300 with the way I drive, don't want to fork out $$ for lowmax just to break them, are u running any gears in the 300
FROM THE EMPTY BOTTLE!
1 Ton Roll-bucket; MGO
DRICH394 is offline   Reply With Quote
Old 07-21-2012, 09:42 PM   #29 (permalink)
breakin shit
Member # 129396
Stock gears I want the lowmax gears but i bought new tires for my pickup and i just got engaged so there goes 5 grand also work is slow in the summer for me..im pretty sure the lowmax gears will take the abuse
Old 07-21-2012, 11:24 PM   #30 (permalink)
DRICH394's Avatar
Member # 140225
Yeah, I know what you mean, i got married the other month,,,, adn jsut got new tars aswell on the tow pig- But i agree with the LM gears taking the abuse, im just worried about the 300 case cracking adn breakign and then the gears F'ing up...
Old 07-22-2012, 07:35 AM   #31 (permalink)
breakin shit
Member # 129396
2 years ago if someone told me to cut my jeep in half i would have told em they are crazy lol.. the reading ive done the housing of the 300 is pretty stout.
Once i get the LM gears installed ill have about 3500 in it including the blackbox if i knew where this was going i prob would have bought a atlas 3 speed. Im not sure what my wheeling style is because ive never had a rig like this. (Cut in half)..
If anyone's cracked a d300 case how did you do it?..
Old 07-22-2012, 01:44 PM   #32 (permalink)
DRICH394's Avatar
Member # 140225
Fast wheel speed and jumping, got a few guys here that have snaped several..., is like to do an atlas as well but hate to think about dropping $2500.... May have to though
Old 07-30-2012, 08:56 PM   #33 (permalink)
breakin shit
Member # 129396
some pics of how the new frame will sit. i am working on tieing them into whats left of the xj.. i figure ill make the roof level and the rails level and square and burn em in and plate em like a mo fo
engine bay plated and burned in..i know im missing a nut on the motor mounts
Old 07-30-2012, 09:38 PM   #34 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Bad ass...
ashmanjeepXJ is offline   Reply With Quote
Old 07-31-2012, 07:04 AM   #35 (permalink)
breakin shit
Member # 129396
Originally Posted by ashmanjeepXJ View Post
Bad ass...
Cant wait to start bending tube so it will really start taking shape. Just putting the new rails in really lights a fire under my ars to get it done.. once the rails are done i guess ill work on my 3 link front and 4 link to make it a roller.. the other day it was 100 out and my welder was giving me fits
Old 07-31-2012, 10:15 AM   #36 (permalink)
Awesome Fab Tools
RockRogue's Avatar
Member # 84883
Cool! Can't wait to see where this build goes.
RockRogue is offline   Reply With Quote
Old 08-02-2012, 09:36 AM   #37 (permalink)
breakin shit
Member # 129396
Need some advice on getting the frame straight with the body..i am thinking i can hang 2 plumbobs the with of the frame (32 inches inside of the frame) from the back of the roof where i cut it off and center the 32 inches on the with of the roof then line up the frame ?? Input would be greatly appreciate. I already have the frame square and have braces tacked into keep it square.. thanks
Old 08-03-2012, 06:23 AM   #38 (permalink)
ONEtonXJ's Avatar
Member # 145633
1 plumbob from the center of the roof then measure stuff..
then to check it, plumbob off each side where the B pillar was... should be the same on both sides...
just get it as close as you can, not buildin space ships......remember that
and get that motor in... im out of porn
that is all
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 08-03-2012, 07:34 AM   #39 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
Or build it then graft it to the XJ?
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 08-03-2012, 09:23 PM   #40 (permalink)
breakin shit
Member # 129396
haha that takes skills i do not have.. i went with welding the frame in first and got er welded in tonight using the onetonxj method turned out great! thanks ..befor i welded the frame i closed the ends of the 2x4 so i can tap the frame and use it as an air tank once i get the AC compressor set up for OBA.
Old 08-04-2012, 10:37 PM   #41 (permalink)
breakin shit
Member # 129396
dove tailed the rear after i got the frame mounted..i need to buy a shit ton of tube.its pretty motovating to see it starting to look like somthing!
Old 08-04-2012, 11:59 PM   #42 (permalink)
DRICH394's Avatar
Member # 140225
Drool
Old 08-05-2012, 03:20 AM   #43 (permalink)
DRICH394's Avatar
Member # 140225
This may have been brought up earlier but ,,, i cant help it, its bugging the shit out of me--- Why in the HELL is there a RED tool box in your tree, not sure if anybody else had noticied this.....
Old 08-05-2012, 08:38 AM   #44 (permalink)
Yukon Gear and Axle
Member # 35700
You don't have those kinds of trees in the south?
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 08-05-2012, 09:14 AM   #45 (permalink)
Newbie
Jhalleau's Avatar
Member # 1680
Thats a true shade tree mechanic!
sick build - subscribed
Those Guys Off Road
www.thoseguysoffroad.com
Jhalleau is offline   Reply With Quote
Old 08-05-2012, 09:49 AM   #46 (permalink)
breakin shit
Member # 129396
Why in the HELL is there a RED tool box in your tree, .....
the frickin thing climbed up there and now it wont come down im about to call the fire department or shoot it down. naw just seemed like a "good" place to put an empty tool box for my circumstances
Old 08-05-2012, 12:12 PM   #47 (permalink)
DRICH394's Avatar
Member # 140225
Aghhhhhhh, nice
Old 08-07-2012, 02:16 PM   #48 (permalink)
breakin shit
Member # 129396
boatsides
got some work done on my boatsides. i would have gotten more done but i ran out of gas for my welder and need more 1.75 .120 wall tube..as it sits the frame is 15 inches off the ground and the bottom of the tube rail is about 27inches
Old 08-07-2012, 06:52 PM   #49 (permalink)
ONEtonXJ's Avatar
Member # 145633
ah fawk yaa
Old 08-07-2012, 06:54 PM   #50 (permalink)
Whatever Works
JM93LiftedYJ's Avatar
Member # 128472
So when you're done, what part will remain XJ? haha
Badass build. I'll follow this one for sure.
Samurai Build on a Low Buck Budget: The Tin Can
1. NEVER, EVER date a single mother.
Originally Posted by am4x4 View Post
It had a dent so we had to cut it off
JM93LiftedYJ is offline   Reply With Quote
