00 limited Crawler/DD build
1 reading
99K views 286 replies 49 participants last post by  project1
#1 · (Edited)
since my last Jeep went up in flames unexpectedly right after finishing it. and the fact that i will go insane without being able to wheel. i am starting another project. with the help of a bunch of family, friends, members of the 4x4 community I have picked up another shell and am steadily collecting parts.
The goal is to build a nice comfy wheeler with AC so my family can enjoy wheeling with me and still drive it to and from the trails while wheeling the places i want to wheel. and trying to get it done and wheeling within six months. my fiancé really wanted to take some of our wedding pictures with the last jeep, so I'm trying to get it together so we can do it with this one.
the last jeep.
anyways, on to the new victim
2000 limited 2WD/AW4/CH8.25
picked it up for a good price, motor is blown but interior is damn near perfect with leather and working AC.
Build plans are basically 107-110" wheelbase, ORI's, 37's, my built d44/8.8 combo(Plans ended up changing, tires and axles became larger!), links front and rear. exo/interior cage and harnesses
and this is about where the rear stretch will be. (tire is a 37" toyo we had around the shop, ill be running 37" MTR's) it should give me enough room to get the up travel i want and avoid going into the rear door.
plenty of cutting/welding/fab to come!
#6 · (Edited)
Axles seemed to have survived. The rear will need some new seals though im sure
Almost. This one will be stretched a bit more, ill be running a doubler, cage will be a little different, and the interior will remain comfortable with a/c , factory leather, ect so the family will enjoy riding in it
#7 ·
Well, i had the fuel tank relocated up, and built a steel box around it to seperate it from the cab. What im figuring happened is fuel started leaking from the vent since we were constanly on our side most of the week. And it may have started puddling in the tank box. So when we were coming down a trail we dropped off a ledge and the rear of the cage/bumper hit tge rock pretty hard and something must of ignited blowing up the tank box and filling the cab with fire.
Besides a full suppression system which im looking in to. Im going to run a fuel cell this time and ensure that the venting is routed and sealed so that there is no chance of puddling. Also eill be carrying a few larger extinguishers, since the small 5lbs didnt make a dent.
#11 · (Edited)
Super happy to see you got a new jeep brother!
I posted up that go fund me page on here and JF but the mother fuckers on JF fliped out and one of the mods was a total dick and long story short my build thread that has been up sinice 2006 was deleted .. fuckers .. anyways .. JF can be retarted ..
I honestly learn so much more from reading post on here so ill just stick to that ..
But super happy to see you got a new xj and is a awesome start .. super nice jeep :)
#14 ·
a buddy decided to go a different direction in his build. so after working out a good deal these will be my new axles.
Ford HP60. spooled with 5.38's ALL brand new parts.
and a 14b getting 5.38's and a grizzly for it.
#15 ·
anyways, back to the build progress.
got some frame stiffeners from ruffstuff, still need to get the front and rear.
tore into the motor from the other jeep. replaced the head with a freshly gone through head along with all the lifters and pushrods, and cleaned all the debris from the block.
stripped the interior out to check out the floors and start making room of the cases.
cut out a big section of the passenger side, and still need to cut out some of the driver side.
#23 ·
been tinkering with it here and there. only have tiny bits of time during the week at the moment to make progress.
slowly piecing the engine together. still need to make some little brackets to hold the coil rail to the valve cover. but its coming along.
my wheels showed up. nothing special just 17x9 pro comp steelies with 4" BS. down the road ill do some weld on deadlocks. but they'll do for now
and the spool showed up for the 60.
and since I'm converting this thing to an AX15, it means i needed to swap out the pedal assembly. for some crazy reason i figured that the older pedal assemblies would work in the 97+ jeep. so i bought the first one i came across.
i was wrong. while the fire wall mounting holes are the same, the upper dash mounting is completely different.
so instead of just tracking down a late model one (which is turning out to be pretty rare) i decided to make it work. plan is to splice the two together. i cut the early model one up to get the clutch assembly piece and welded it to the late model one. and i swapped over the brake and clutch pedals to the new assembly
still need to add a couple small plates so i can weld the two together in a couple other spots that don't quite line up right. like the top since i cut a little bit to far. and i need to modify the brake switch mount since the 5 speed brake pedal doesn't line up like the auto brake pedal to the switch. but the way it is now will be good enough to mock up and make sure everything works.
#24 ·
finished mounting up all the clutch stuff, ended up being more of a pain in the ass than i thought. there were no mounting holes in the fire wall so i needed to drill those. and it was a pain to get the new modified pedal assembly back in the jeep.
#25 · (Edited)
and i pulled out the tcase, completely sealed it up and finished cutting the floorboard for it to all fit with my crossmember. everything fits up nice and tight above the frame rails. i "may" have to pull it back out and clock the case down slightly. i won't know until i have the axle and front suspension in the jeep.
also, my original plan was to just run some stick shifters for all 3 shifters. but now I've been considering cable shifters so i can have all 3 shifters in the factory location and make it look a little cleaner. so well see
#27 ·
cut off the upper control arm mounts the PO had welded to the truss.
along with mocking up a tie rod to see the clearence issues ill have with that riddler cover
and tossed some roller 35's on it so i could pull the 2wd beam axle out and slide the 60 under the jeep
pulled off the front bumper and flares so it would fit
#28 ·
i set the front of the jeep up at the ride height it will be at.
theres just over 6" between the top of that pankiller truss and my oilpan. so ill have to make sure I'm pretty precise on setting up full bump. lol
started mocking up the control arms in my crossmember to see what I'm working with.
since the crossmember and arms were designed around a almost center LP EB44 front axle it puts the lower control arm pretty close to the driveshaft. i still need to run the axle through its range of travel to see if this will be an issue or not. worse case scenario i will need to cut off and relocate my crossmember side control arm mounts.
#30 ·
started mocking up my steering.
this is with running a small drop pitman arm to help out the angle some. I'm going to angle the axle side track bar mount a little more to help match the drag link angle and buy me a little more truss clearance.
the eventual goal will be to have a local guy machine the knuckle and cut me a keyed highsteer arm so i can flatten out my angles . but i think I'm just going to run it as is at first.
and it looks like ill be doing a little diff cover grinding.
