Honky Lips builds a bigger xj costing much more money than the last one - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-28-2017, 01:13 PM   #76 (permalink)
Honky Lips's Avatar
Member # 67732
X finished. Seatbelt bar done. Stinger on. Fender bars on. Radiator support made. Hood latches made.
THIS SPACE FOR RENT, INQUIRE WITHIN
That guy can go fuck himself with whatever power tools he has left.
Honky Lips is offline   Reply With Quote Quick reply to this message
Old 04-28-2017, 01:40 PM   #77 (permalink)
Biding my time...
whitneyj's Avatar
Member # 135947
Looking good
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is online now   Reply With Quote Quick reply to this message
Old 04-28-2017, 03:57 PM   #78 (permalink)
Honky Lips's Avatar
Member # 67732
Originally Posted by whitneyj View Post
Looking good
For the time I've got to build it it's turning out decent
Old 04-28-2017, 10:12 PM   #79 (permalink)
Honky Lips's Avatar
Member # 67732
Pic
Old 04-29-2017, 02:27 PM   #80 (permalink)
Honky Lips's Avatar
Member # 67732
Got most the floorboard done. Gotta patch up the passenger side floorboard still.
Seat mount isn't clearing the atlas so I gotta modify the mounting brackets.
Had to buy a three-quarter inch drill bit today so I can connect my steering cylinder to the hi steer arms. That way I can keep the Tires straight will loading in unloading on the trailer so I can bring it home
Old 04-29-2017, 08:33 PM   #81 (permalink)
Honky Lips's Avatar
Member # 67732
Got my orange synthetic which line from snevey's off-road.
Old 05-04-2017, 07:30 PM   #82 (permalink)
Honky Lips's Avatar
Member # 67732
Got my shop moved to my garage. Things fit nicely. Jeep will have to be finished outdoors.
Old 05-05-2017, 06:27 AM   #83 (permalink)
85stanky's Avatar
Member # 72380
I feel your pain on having to work on stuff outside of the actual garage. My house came with a 2 car, with a 15x25' carport off of that. All of the household stuff and the wifes car are in the 2 car side. So i laid out all of my shop in the carport side. Much like how you have yours laid out, work space in the center and tools along the perimeter. It is a good amount of space if you utilize it. Good luck!
striving to achieve mediocraty
85stanky is offline   Reply With Quote Quick reply to this message
Old 05-15-2017, 04:27 PM   #84 (permalink)
Member # 729777
Nice build.
Did you use 2x6 or 2x8 for the rockers?
MikeBravo is offline   Reply With Quote Quick reply to this message
Old 05-15-2017, 05:51 PM   #85 (permalink)
Member # 88083
I see you mounted your winch feet forward.
Just fyi i had mounted a Smitty feet forward in the same manner. I pulled it apart for service and regrease after the first year. Found a bunch of water and mud collected in it because the housing have drains intended for them to be mounted with the feet down.
Not sure how that warn is designed but worth a mention.
"It's Not Rocket Surgery"
Lake_v2 is offline   Reply With Quote Quick reply to this message
Old 05-15-2017, 05:54 PM   #86 (permalink)
Member # 88083
Oh and nice tie in on fender tube with bumper, i have been staring at my bumper for a while trying to visualize a clean simple tie in. Your base bumper is very similar to mine. I may steal that when i cage the grand.
Old 05-15-2017, 07:42 PM   #87 (permalink)
Honky Lips's Avatar
Member # 67732
2x6 on the rockers. I'm wondering about the winch myself. It'll either work or not.
Steal away on the bumper. It's compact but offers protectikn.
Old 05-18-2017, 07:19 AM   #88 (permalink)
Honky Lips's Avatar
Member # 67732
got the air filter put on yesterday and a little polished radiator overflow put on. Just use L cheapo eBay air filter and spectre tubing running over to the passenger side of the motor up against the hood.
Got the insulated stud for the positive battery cable and AGM battery so I can get the electrical side of things finished up. Once I get that done then I can get the synthetic winch line spooled up change engine oil and once my pump Comes in from psc I can get the steering all plumbed up.
Old 05-18-2017, 09:01 AM   #89 (permalink)
Honky Lips's Avatar
Member # 67732
eBay installs. Cheap but hopefully functional
Old 05-19-2017, 12:51 PM   #90 (permalink)
tjjared413's Avatar
Member # 46942
I would not run that PVC vent back in to the intake... when ever this thing is up side down the oil pumps back in to the wrong areas.
I run mine to a vented/rollover can
04 tj to hang out at the malls and 15 F350
tjjared413 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 07:23 PM   #91 (permalink)
Honky Lips's Avatar
Member # 67732
Not a bad thought. My last Cherokee I just put a breather filter on it.
Old 05-21-2017, 07:42 PM   #92 (permalink)
Honky Lips's Avatar
Member # 67732
Little update.
Got the battery box welded in today. Battery cable made. Most everything hooked up. Got a few grounds to take care of in the engine bay.
Extended the fuel line.
Changed the engine oil. Started it up and let it run for a second.
Made a bracket to mount the manual shift rail.
Got the synthetic line on the winch.
Old 05-23-2017, 09:15 PM   #93 (permalink)
Honky Lips's Avatar
Member # 67732
Got the factory fan shroud and electric fan put in.
Old 05-24-2017, 07:07 PM   #94 (permalink)
Honky Lips's Avatar
Member # 67732
Progress. I had to put a U in the transmission crossmember so it would clear the driveshaft with the four-speed atlas I didn't realize how far back it sat with the planetary box. With also having the transfer case crossmember I think it will be plenty solid.
This weekend's goals are to make the metal brake lines and bleed the brakes and my power steering pump from PSC should be here Saturday so I can put the pump in and get the steering all installed and operational.
I did see that where the pinion bolts to the center section is leaking so I'm going to have to pull that back apart for a little bit of silicone in there and hopefully that takes care of it.
Old 05-28-2017, 06:16 PM   #95 (permalink)
Honky Lips's Avatar
Member # 67732
Seats installed. Exhaust made, that sucked with the severe lack of room. Brake lines finished up. Lap belts installed.
Old 05-29-2017, 04:23 PM   #96 (permalink)
Honky Lips's Avatar
Member # 67732
Seat belts bolted in. Brakes bled. Pinion housing leak fixed. Charged the ori struts and set at ride height.
Measured for driveshafts. Gonna have them made tomorrow.
Old 05-29-2017, 05:39 PM   #97 (permalink)
pitbullcruiser's Avatar
Member # 193971
Nice build, your back seat area looks like a cop car!
ECORS Toyota #779
pitbullcruiser is offline   Reply With Quote Quick reply to this message
Old 05-29-2017, 06:17 PM   #98 (permalink)
Honky Lips's Avatar
Member # 67732
Thank you. Now that you mention it. It really does haha
Old 05-29-2017, 06:19 PM   #99 (permalink)
Honky Lips's Avatar
Member # 67732
Ride height pics
Old 05-31-2017, 10:35 AM   #100 (permalink)
Honky Lips's Avatar
Member # 67732
Psc pump and steering shaft u joint showed up! Heading to the parts store to get a belt and hopefully we are steering by the end of the night.
Got .25 wall 1350 jointed driveshafts being made today. 425 each. That was a little more than expected but they should last. I'm gonna drive this like by the weekend! Hell or high water in gonna drive it.
Picked up a set of 5 76% tread 39.5" irocks on h2 wheels for 1500. That'll get me in the trail while I save up for treps.
