'98 XJ fullwidth Build up - pics - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2005, 06:44 AM   #1 (permalink)
Ken Carter / BRUISER's Avatar
Member # 3321
Send a message via AIM to Ken Carter / BRUISER
Well after doing a few upgrades to my XJ I decided I was going to update my post I started a long time ago and to my surprise it has been lost in last server update (per Lance)
So I am gonna post up a quick overview of what I did with a lot less pics but you will get the gist.
Specs:
1998 Jeep Cherokee
chopped back half
with exo cage
Engine/Drivetrain:
• 4.0L, I-6 engine
• 4-speed automatic transmission
• NP231 t'case w/ 2 low kit
• Dana 44/Ford 9" axles (front/rear)
• 4.88 gears
Suspension:
• Rockkrawler 6" coils in front
• Tomken 2" blocks / Rusty's 4.5" Leafs in rear
• Custom made shackle mount in rear
• Ford custom Radius arms
• Rusty 6" Shocks
• 6" steel braided brake lines.
• Custom Belly up skid
Wheels & Tires:
• 38" TSL Swampers
• 15x10" Alum Rims's w/ welded rock guard
• Inner Air Lock Beadlocks
Armor:
• Custom built Front High Clearance Winch Bumper
• Custom built Rock Guards
• Rusty's OffRoad steering box brace
• Skid Plates (front, transfer case, and rear gas tank)
• Exo Cage
Accessories:
• Suspension seats
• 5 point harness
• Redneck Ram Hydro assist steering
• custom made driveshafts
• Warm 9000i Winch
• Radio Shack CB
• 2 fire extinguisher
• 48" Hi-Lift jack
• Full set of spare shafts fro front and rear
• 10LB CO2 tank in back
Well when I decided to do this fullwidth build up I was running 35's on stock axles and I wanted to go bigger So I sold my axles and got under way.
1st pic is most current pic after last project update
2nd pic is how it sat before I started the Full Width build up
www.iMPAKS.com, www.LoneRiderBeer
Tread Lightly Master Trainer
My Builds:
Bus / RV, New Jeep, Camper / ToyHauler, CTD Tow Rig, Jeep XJ, Shop
Ken Carter / BRUISER is offline   Reply With Quote
Old 05-04-2005, 06:50 AM   #2 (permalink)
Member # 3321
First thing I did was take out 30/8.25 and get rid of them
then I found a 9" local and a 44 on ebay
tore them apart and rebuilt them
and slapped the 9" under rear of jeep
Old 05-04-2005, 06:51 AM   #3 (permalink)
Member # 3321
then started build up of front 44
Old 05-04-2005, 06:52 AM   #4 (permalink)
Member # 3321
front pic
Old 05-04-2005, 06:53 AM   #5 (permalink)
Member # 3321
front pic 3
Old 05-04-2005, 06:54 AM   #6 (permalink)
Member # 3321
then I took the radius arms cut them up added control arm bushings to them/braced them.
I also made my own driveshafts
Old 05-04-2005, 06:55 AM   #7 (permalink)
Member # 3321
made new rear shackle hanger
Old 05-04-2005, 06:56 AM   #8 (permalink)
Member # 3321
made rear shock mounts
Old 05-04-2005, 06:57 AM   #9 (permalink)
Member # 3321
finally got it rolling
Old 05-04-2005, 06:59 AM   #10 (permalink)
Member # 3321
pic.
Old 05-04-2005, 07:00 AM   #11 (permalink)
Member # 3321
then it was onto the steering.
decided I wanted Hydro assist... so I enter the Rednceck x-mas drawing and son of a b*itch I WON
Yes I won a full asssit set up
So I got a J-20 steering box had it tapped and set up REDNECK RAM steering
using Posion Spyder inserts to make all my own steering
Old 05-04-2005, 07:02 AM   #12 (permalink)
Member # 3321
I also made a diff guard for the 44
Peace sign part was just for looks the protection is the tampoon behind it
Old 05-04-2005, 07:03 AM   #13 (permalink)
Member # 3321
pic
Old 05-04-2005, 07:04 AM   #14 (permalink)
Member # 3321
After wheeling it a few times I decided 36's were not big enough so I found a guy on drugs and bought his 38 TSL on rims for $400 ( always looking for a deal ).
but then I needed beadlocks
So I made my own.. here is first attempt
Old 05-04-2005, 07:05 AM   #15 (permalink)
Member # 3321
and here is finally design on the Jeep
Old 05-04-2005, 07:06 AM   #16 (permalink)
Member # 3321
and then getting it on the trail this past weekend.
I did learn that I should have trusted my beadlocks and aired down a lot more.. oh well there is always next time.
Old 05-04-2005, 07:07 AM   #17 (permalink)
Member # 3321
and now the next thing on the list is the cage...
I just started drawing up what I want and have decided to do an internal with some exo bracing... I hope to have it in and done by end of summer.
My Builds:
Old 05-04-2005, 07:16 AM   #18 (permalink)
MossMan's Avatar
Member # 11995
Send a message via MSN to MossMan Send a message via Yahoo to MossMan
Looks good. What trails ya on there?
MossMan is offline   Reply With Quote
Old 05-04-2005, 07:41 AM   #19 (permalink)
Member # 3321
Last pics was at the club Beginner ride at Uwharrie in Troy , NC
but last year was at Tellico with the 36's
Old 05-04-2005, 07:52 AM   #20 (permalink)
Evil Twin
yager's Avatar
Member # 10695
Send a message via AIM to yager
looks god ken!! its come a long way...
yager is offline   Reply With Quote
Old 05-04-2005, 08:19 AM   #21 (permalink)
Member # 34067
sweet, keep the pics coming
davidt is offline   Reply With Quote
Old 05-04-2005, 09:39 AM   #22 (permalink)
Member # 35803
nice! maybe someday I'll learn to wheel something other than "begginers" uwharrie trails.
www.mallcrawlin.com
Puma297 is offline   Reply With Quote
Old 05-04-2005, 09:53 AM   #23 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Talking
are you using the stock ford steering knuckles?
got any close up shots of them and how you worked the steering?
i am working on this swap (HP 44) and thinking out my steering setup and it seems that no one runs the stock ford knuckles...
send a boatload of pics to opiebennett@gmail.com if you fell the need...
thanks
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 05-04-2005, 11:30 AM   #24 (permalink)
Member # 3321
Yup every year we our club does 2 beginner rides to uwharrie to help educate the new folks that are just getting into 4x4ing.
Maybe you should come along and learn some stuff
Old 05-04-2005, 11:32 AM   #25 (permalink)
Member # 3321
thanks
Yes I am using stock knuckles.
I drilled and tapped them and add a high steer arm to the passenger side so the draglink goes to high steer arm, and tie rod goes straight across on top of original knuckle location. (sorry no pics of it) if i get a chance I will take some pics..
My Builds:
