Member # 73680
Who makes custom leaf packs at a decent price?
So i'm trying to moving my axle back about 5 and half inches or so from stock location during my 1 ton swap on project shit missile. Who makes some good springs at a decent price that can bring the centering pin back back about 4-6 inches. Here's the meausrements on my current Rustys (and they're pretty rusty too) springs:
47 5/8" eye to eye 21 5/8" front eye to center pin I need the pin to sit about 27 1/8" or so...basically if you flipped the springs they would sit perfect...my only problem is the bushings are different...any solutions here? any custom spring makers at decent price? thanks... Last edited by pipehitter155; 04-07-2007 at 04:31 PM. |
Member # 42255
Have you tried Deaver springs. I do not know about price but the can build pretty much custom whatever you need.
http://www.deaverspring.com/ |
#3 (permalink) | |
Member # 10739
x2 on the deaver stuff. Your honestly best looking at flipping the rear springs and running an anti-wrap bar.
:laughing: |
Member # 6670
i've reading up on the rear spring flip. looks like either we swap the bushings out or you get some custom springs. if the pin moves back further then the center of the spring pack, then we need to figure out a track bar to help control the spring wrap. btw, had fun cutting the body today wish i brought my dig cam.
[url=http://www.rightcoast4x4.com/phpbb/index.php][color=orange]rightcoast4x4.com[/color][/url] [url=http://www.surfandcrawl.com][color=blue]surfandcrawl[/color][/url] |
Member # 25239
Keep in mind that on a leaf spring the front half of the spring serves as a control arm, positioning the axle and transfering the axle torque/movement to the body. If you turn the spring around so the front half is longer than the rear half then the spring will fatigue much quicker due to the force that's applied to that half of the spring. If you need to move the axle rearward, the best thing would be to get a longer set of springs and locate the rear shackle further back or use a pretty long boomerang type shackle.
A set of Commanche leaves would move the axle back 3", and are 52" long, 5" longer than stock. If you're willing to piece together a set of leaves out of used springs, any local spring shop could bend up a main leaf for you. I'd also recommend you talk to Deaver, both to get a quote and to get some reputable advice on how to do what you're looking for.
Richard Gauthier Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643 Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes |
Member # 67906
dont know if they can do custom center pin locations, but i ran a set of bigoffroad springs http://www.bigoffroad.com/vendors/bigoffroad/index.htm which are contracted out from alcan....they were a bit stiff, but miltary wrap, and they were made for 300 or so pounds in the back if you run alot of spare parts/tools, no axle wrap either.
Member # 1655
Just flip your springs and have some custom main leaves made with the right bushing ends. The bolt them back together. Any local leaf spring shop can do it. Might cost 200-250 for both. Also like others have said...gonna need a stout anti-wrap bar.
72 COMMANDO/454/TH400/39.5 BOGGERS/DANA 60's/203/300 Doubler......sold Last edited by rockhog; 04-09-2007 at 08:54 AM. |
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE] [QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit. [/QUOTE] |
Member # 45871
I have been very pleased with my Alcans, I just wish I would have linked it from the start, instead of doing leafs, and then going 4 link
90 Comanche truggy a work in progress |
#12 (permalink) | |
Crazy Diamond
Member # 7595
Your MJ build-up looks good post up a link for everyone and share....
Great spirits have always encountered violent opposition from mediocre minds.” -Albert Einstein
#13 (permalink) |
Member # 45871
I wish I could take the credit for th tube work, I had a shop do that 2 yrs ago, but this time I am re doing the rig myself. I will post up a build from the begining when I can find all the pics over the yrs
#15 (permalink) |
Member # 21079
I have had real good luck with a combo of s-10 and XJ leaves flipped. Obviously you have to have a traction bar or it is rap city. I am really light on the ass end so the springs are a little heavy for washboard roads but for crawling and high speed they seem to work really well. I have run Tomken, Rock Crawler, and god forbid Rusty's springs and these have been the best.
![]() You can kind of see the extended wheel wells in this pick.
Lots of stuff, thanks to Trick Tools, and ORI |
