raised ZJ gastank - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2007, 06:03 AM   #1 (permalink)
Member # 89483
raised ZJ gastank
this is pretty applicable to fitting in a big axle or smoothing out the bottom of a crawler. my rig isn't there yet....but i hope this fits in with the intent of this "cherokee" section. send me home crying me if it isn't.
cut a big hole:
movin' on up
was doing some other "real" frame install work for the tracbar, added some thicker metal for the tank skid.
i had to extend the fuel lines, if you cut the oem plastic lines, they give up the clip ends that you can use inside your new longer rubber lines.
Caper is offline   Reply With Quote
Old 04-16-2007, 06:05 AM   #2 (permalink)
Member # 89483
yep, the only scrap i had to fit was chrome treadplate.....
pretty decent change in clearance for the effort involved.
Old 04-16-2007, 07:50 AM   #3 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
Looks good!
ZJim is offline   Reply With Quote
Old 04-16-2007, 10:23 AM   #4 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Nice. Did you notice any chande in chassis stiffness?
I plan on moving my XJ tank up so it's bottom is even with the frame rails for a flat skid rail to rail. That way I shouldn't lose any chassis stiffness once I put the skid and removeable upper cover on.
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
Old 04-16-2007, 10:44 AM   #5 (permalink)
Member # 89483
the floor was soggy, it didn't make any difference to cut it out. the skid is welded in and tighted the back up a lot. i tied it into the bumper, plated subframe,etc.
the tank cover is held down with sheetmetal screws, easy to pop it off to get at the pump.
i cut the filler lines shorter and put them thru the wheelwell. the outside filler is stock tho, works normally to fill it.
Old 04-16-2007, 12:46 PM   #6 (permalink)
Vagitarian
planefixer's Avatar
Member # 33328
Nice work.
Just anohter poop-flingin' day in the jungle.
planefixer is offline   Reply With Quote
Old 04-16-2007, 06:58 PM   #7 (permalink)
AprilzWarrior's Avatar
Member # 21033
Looking at the pics... the only problem I see is that the exhaust is now too close to the plastic tank... Id recommend moving the exhaust.
Otherwise its always fun cutting the floor out of a unibody.
AprilzWarrior is online now   Reply With Quote
Old 04-18-2007, 05:41 PM   #8 (permalink)
Member # 89483
must be the pics, the exaust is fine. it dumps to the side of the tank just after the axle. thx fer lookin.
Old 04-18-2007, 06:39 PM   #9 (permalink)
Member # 21033
Did you ditch the rear seats ?
Old 04-19-2007, 12:19 AM   #10 (permalink)
Member # 89483
they still clip in.
if you are wondering about the clearance between the seatbacks and the tank cover, it's about 8-10" with the rear seats up.
