THE XJ/MJ/ZJ/WJ master cylinder upgrade thread, what works, no questions. - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-26-2007, 06:01 AM   #26 (permalink)
duke it out
XJUSA's Avatar
Member # 11132
Location: If I could start again, a million miles away.
I have done this 4 years ago. WJ brake booster and master cylinder with custom brake lines in my '91 XJ. I welded the old booster rod to new booster rod. May be that's , but no probs at all. Easy swap.
http://www.msctec.de/xjusa/projects/booster/index.html
....“I never shot nobody I didn't have to”....
XJUSA is offline   Reply With Quote
Old 10-22-2008, 12:01 PM   #27 (permalink)
Member # 100945
Originally Posted by vetteboy79 View Post
There are hundreds of threads on this topic, but they all contain a huge amount of hearsay and uninformed responses, and the true tech gets buried.
I'd like to have a thread in which only people who have actually SUCCESSFULLY completed a master cylinder upgrade should post the following:
- Year/model of vehicle
- Year/model/style of booster
- Year/model/style of master cylinder
- year/model of proportioning valve (if used)
- Front brake configuration
- Rear brake configuration
- Overall performance
What we DON'T need is a bunch of people saying "I've heard you just swap in a E350 master cylinder" or "A 79 corvette MC works".
Sorry if this is a repeat, but I know I've been quite frustrated trying to find any accurate information on this, and I know there's some others out there with the same problems.
-98 xj
-stock dual diaphragm booster
-99 durango MC
-stock distribution block with o-ring removed (had to add advance auto adj. prop valve)
-front: waggy 44 (GM 1/2 ton calipers)
-rear: ford 9 inch (80 malibu calipers) [TSM MFG. kit]
-On 35s currently, stops a heck of a lot better. Not as firm as I would have hoped, but is MORE than adequate. Rear was locking up, so I had to knock it down a bit with the adjustable proportioning valve.
98xj chromo'd 44/9, lifted/locked/caged
shmoken875 is offline   Reply With Quote
Old 10-22-2008, 12:16 PM   #28 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Originally Posted by Bubba_Jeep View Post
Would be useful to hear from you guys experimenting with late ('99 or newer) model Dodge (Rams and Durangos) MC's onto late model ('95 or newer) XJ/WJ dual-diaphragm boosters.
- 94 XJ
- 95 ZJ dual-diaphragm booster
- 1998 Dodge 2500 MC
- 95 ZJ distribution block (ABS removed)
- Large single-piston D60 calipers (front)
- GM 1/2-ton calipers (rear)
Much better than the stock MC on the same setup.
The Dodge MC bolts directly in place and seals properly; you need to extend the pushrod by about 5/8". I made a spacer to go in the pushrod bore of the MC. It's still a little too short but I haven't had the motivation to take it apart again.
The flare fittings are the same as the stock XJ so no cutting/reflaring is necessary.
Left to right:
'95 ZJ, '98 Dodge 2500, '94 Dodge 2500. I ordered the wrong Dodge one initially.
I forgot all about this thread.
'94 XJ RIP, time to move on
New East Coast TTB racer in the works, trimmin' the fat...
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote
Old 10-22-2008, 12:28 PM   #29 (permalink)
95steel's Avatar
Member # 14509
91 MJ with stock booster. Ford 9 with drums, HP 44 disc with waggy calipers.
E-350 MC. Aside from the lines being on the wrong side of the MC it was an easy swap and it works well.
95steel is offline   Reply With Quote
Old 10-22-2008, 07:06 PM   #30 (permalink)
Member # 91325
Originally Posted by Flashover Mfg View Post
Stock 93 XJ booster
77 Mercury Marquis Master
Wilwood adjustable prop valve
78 F250 front brakes
77 Chevy K20 front brakes mounted to rear 14bolt
It'll lock up my 35s with ease.
-Joel
I have the same exact brake setup. Everything works well? No fade, nothing?
Echo4charlie is offline   Reply With Quote
Old 10-22-2008, 08:23 PM   #31 (permalink)
Member # 29071
Send a message via AIM to Starboard M
Small write up on the WJ Grad swap into a Renix XJ:
http://naxja.org/forum/showthread.php?t=924285
Starboard M is offline   Reply With Quote
Old 10-23-2008, 02:15 PM   #32 (permalink)
Member # 114235
- '88 XJ, my heep.
- '96 XJ booster, MC and porp valve as donor junk.
- Stock front disc brakes.
- Stock rear drumb brakes.
- 37" tires
- Awesome performance
I don't know why I didn't do this sooner. I always wanted to get rear discs. After the swap I haven't even thought about it. The only issues I had was try to keep the porp valve in the location of the '96 with the bracket. By doing this I had to make new brake lines for the additional length. Also, I would have been able to keep the washer fluid tank in the stock location. My only issue was the rod. The '96 was round where my '88 has a flat end. I used my air grinder to make it flat and ended up taking too much off. I tack welded material back on and made it flat again unit the break switch worked. Not too tough, but a little frustrating. Overall, it was the best modification I've made after having 37" tires. I used to have to use both feet on the pedal if I had to stop on a steep hill. I'd still slip if it was steep enough. I can now stop anywhere with normal breaking. Can't lock them up on pavement, but just about can. I can get the tires to skip. Jeepforum has some great write ups on it. Don't think about doing it...just do it. You'll be glad you did.
http://www.madxj.com/MADXJ/technical...terUpgrade.htm
http://www.4x4wire.com/jeep/tech/bra...kes03/booster/
http://www.cardomain.com/ride/325707/15
blk88 is offline   Reply With Quote
Old 10-26-2008, 11:01 PM   #33 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Originally Posted by Sierra Drifter View Post
Real World Measurements: + or - 1 or 2 thousands
I just pulled my master cylinder.
2001 Cherokee Sport stock master cylinder 1 inch bore.
Anyone know if all XJ cherokee MC's are 1" Bore?
Kragen lists the non-abs MC's for a '92 as 15/16" Bore...
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 11-02-2008, 06:32 AM   #34 (permalink)
Member # 51576
Swapped in a '00 WJ booster and M/C... works great but I did need a adj prop valve after taking out the stock prop valve.
Pics: http://rides.webshots.com/album/561412237cWcOoT
flexy92xj is offline   Reply With Quote
Old 11-08-2008, 12:43 PM   #35 (permalink)
Member # 29476
Model-'92/XJ
Booster-'92/XJ
M/C-'97/Expedition 1.25"
P/V-'93 s-15
Front brakes-'03 SuperDuty
Rear brakes-'03 SD
Stops well on 39.5"s.
The previous MC had a wider mounting surface and a larger bore in the booster itself, which I remedied with a blockoff plate and smaller hole.
I also had to lengthen the push rod on the new MC and slot the mounting holes to fit the booster's studs.
Sealed it with RTV.
'92XJ, '97 Expedition
'92XJ booster
Used a sleeve and a short length of solid
Welded it to the MC
'93 s-15 PV
Okie Terry is offline   Reply With Quote
Old 11-14-2008, 09:41 AM   #36 (permalink)
Member # 91325
A known solution
Does anyone have 78 Ford fronts and 78 Chevy 3/4 rear disks with brake setup that can actually say it works well? There is a lot of information in all of the brake threads but I still cant find one that says "this is what works and it works well"
Old 11-14-2008, 09:45 AM   #37 (permalink)
pipehitter155's Avatar
Member # 73680
yeah i have them in my 99 and everything is stock as far as the braking system goes...i have a rear 14 bolt w/ 78 K20 front D44 calipers, discs, pads, etc. and a front 78-79 HP60 w/ dual piston caliper and it stops on a dime...no problems...guess i just got lucky...
pipehitter155 is offline   Reply With Quote
Old 11-14-2008, 09:51 AM   #38 (permalink)
lookin4fun_inca's Avatar
Member # 16698
I got hte 14bolt rear with the disc conv. w the 44 calp. and the front is a rockjock with the stock D60 1979 dual piston 3/4t calipers and rotors
I have the 04 WJ booster and master, no prop valve and all stock lines expect extended at the ends. Stops my 3000lbs buggified XJ on 40's very nicely!
lookin4fun_inca is offline   Reply With Quote
Old 11-14-2008, 10:03 AM   #39 (permalink)
Member # 91325
My pedal goes to the floor. My MC is a 1991 XJ, so single booster. I think I am going to try the WJ setup. Thanks you lucky bastard
Old 11-14-2008, 02:23 PM   #40 (permalink)
Member # 73680
shit i gotta WJ too (it's the ole lady's ride)....that thing can't wait to stop...man i bet that is your best bet honestly (going with a WJ setup)...
Old 11-15-2008, 09:02 AM   #41 (permalink)
Member # 37184
PLEASE, ADHERE TO THE ABOVE PURPOSE OF THIS THREAD! THE IDEA IS TO HAVE POSTS THAT SAY: "I'VE DONE IT CORRECTLY , MEANING WHAT i DID ACTUALLY WORKED.
The point here is to get feed back and detail about what really works, and the part numbers/mods/adjustments required to make it work.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's.
Bubba_Jeep is offline   Reply With Quote
Old 11-18-2008, 06:51 PM   #42 (permalink)
Member # 4660
1995 ZJ
1991 XJ
1988 E350
none
Mid - late 80's 3/4 ton calipers on CJ rotors on 609
1979 Lincoln Calipers on Ford 9
Sweeet
'95 Orvis ZJ, mostly...
JayH is offline   Reply With Quote
Old 11-20-2008, 10:55 AM   #43 (permalink)
Member # 73202
91 XJ w/abs
2000 WJ
2000 WJ
98 TJ with the o-ring removed
D30
Exploder 8.8
Really soft peddel ... feels like there's air in there, but have bled it 3 times already. Can lock up 35s on dry pavement now though. ABS finally tossed.
dhoffryn is offline   Reply With Quote
Old 11-27-2008, 05:55 AM   #44 (permalink)
Member # 54468
88 mj
95 xj booster
95 xj master
stock prop valve with stock load sensing valve in rear wired for full pressure
98 xj front brakes
98 exploder rear discs
stops excellent with 35s... solid pedal and great feel. dont know if i can lock up the tires on pavement as i havent tried.
troy6187 is offline   Reply With Quote
Old 11-27-2008, 07:59 AM   #45 (permalink)
wheatfield's Avatar
Member # 8990
91 XJ
91XJ booster
78 Merc Marque 4 wheel disk hydroboost cylinder
Willwood Adj prop valve full open (could be taken out)
77 Chevy 3/4 ton rotors and calipers front and rear
works well (much better than the Vette cyl I used to run)
Scott
RubberBellyRacing
Special Thanks to, The RBR crew
Jeff Knoll: What do you need to see anyway, the spotter is driving, your just a monkey at that point, the only thing you need is to follow orders, and have brass balls.
wheatfield is offline   Reply With Quote
Old 01-31-2009, 01:45 PM   #46 (permalink)
CrawfishStu's Avatar
Member # 83272
- 94 XJ
Left to right:
When he talks about cutting a 5/8 spacer, what exactly does that mean? Something 5/8" long to drop in the bore?
CrawfishStu is offline   Reply With Quote
Old 02-01-2009, 09:56 AM   #47 (permalink)
Member # 99723
Yes but the most common way to do it is to remove the pushrod from the pedal and swap it with a bolt that is longer. Then round the head on the bolt to match the end of the pushrod. Here is a great thread for it
http://pirate4x4.com/forum/showthrea...aster+cylinder
Moore87 is offline   Reply With Quote
Old 02-02-2009, 09:44 PM   #48 (permalink)
Member # 123611
1995 xj 2dr se
axles: d44 3/4 ton front 14b ff rear
brakes" discs front and rear
proportioning valve: willwood adjustable
master cylinder: 1978 chevy 1 ton
This things stops amazing. I couldnt be happier with how the brakes work. None of my friends rigs can stop as good as mine can my setup works the best.
hammerdownxj is offline   Reply With Quote
Old 02-03-2009, 06:01 PM   #49 (permalink)
Member # 91325
What mods did you have to do to the Chevy MC?
Old 02-03-2009, 11:40 PM   #50 (permalink)
Member # 123611
open up the 2 holes on the mc to attach it to the jeep booster that was it.
