Member # 64983
New ZJ Crawler Need Some Help
ok Here Is my new 93 5.2 litre GC
![]() ![]() ![]() ![]() ![]() Specs Are As Fallows 93 Grand Cherokee 5.2 litre Long Arm Lift 10 inchs in front 8 in rear 3/4 runnging gear d44 in front D60 rear 3.73 gears spool in the rear Full width axles ARB bumper Roof Rack 37 inch MTRs Planned upgrades OX Lockers Front And Rear and 4.56 or 4.88 Rear Rock Krawler XJ Long Arm Coil Over Conversion Kit Adapted to ZJ 12 Inch King Resovior Rear Coil Over Shocks 14 Inch King Resovoir Front Coil Over shocks Custom Stinger Bumper in added to ARB bumper Hanson Rear ZJ bumper Winches front and rear High Steer Corbeau Seats Minor intirior cage for 4 point harnesses Custom Stereo 37 Inch Nitto Mud Grapplers 17 Inch Aluminum Bead Locks New T Case Questions I have What Spring Rates Should I run on The Dual Coil Over Shocks? What problems are there with this motor? Whats a Good Steering Box Swap For this Rig? Or Should I go partial Hydro? How Hard Would It Be To Swap In A NV241 T case Or Would it Just Make More Sense to Just get a Stak T case? Should I go Coil Overs Or Will Some 2" Sway Away Air Shock fit the Bill? Thnx for lookin feel Free To post Comments! |
Sounds like you have a good idea of what you want. I would say dont go so high. 10 inchs is going to give you a center of gravity at can make things scary at times. just do some more trimming. As for the coil overs, if you have the cash go for it but I would put the money into other things first. As for the locker and gears OX are great and of your choices I would go with the 4.88. For your bumpers I would just keep what you have. They look pretty strong and very functional. The high steer is a must and I would go with a AGR superbox or again if you have the money go hydro. As for the Tcase it comes down to money again. you could get a 231 doubler and a flipped Dana 300 with twin sticks for much less then a Stak or Atlas but if you have the money the stak and atlas are bullet proof and install much easier then doing all the work with the doubler and flipped 300.
Last thing. The motor - the 5.2s are good motors and make power in the right places for crawling and they have tons of upgrades available. They are long lasting motors too. good luck in your build make sure you keep us updated with plenty of tech.
Andy~ RCrocs/Line Mt. - Route 63 Motorsports #736 Ultra4 #4343 Co-driver - Molten Motorsports Last edited by Xjcrawler736; 05-01-2007 at 09:17 AM. |
Member # 64983
its running 10 inches of lift right now and its pretty close to bein trimmed all the way out its running 12 inch travel shocks in the front right now seems to flex pretty well since its running fullwidths. I am thinking of running some 2.0 swayaway air shocks for now cause the Skyjacker springs ride like sh!t, will the air shocks fit my needs for now? I was gonna run 12's in the front and 12 in the rear. As for the T case I am gonna go stak I figure Do it once do it right I am lookin into swapping in a th400 at the same time. And one the bumper I am just weldin on a stinger setup. Thnx again for the feedback I will keep everyone posted and I am buyin a red star today!
this might help you a bit
http://www.swayaway.com/calculators/...Calc.php#step5 or if you dont trust yourself putting all the numbers in and feel like wasting some time on the phone call poly performance. they will help you out. 805-783-2060 the way I see it you are going to want about 350 in the front and 250 in the back but i would put the work in to be sure with your application. Get that red star so you can search
Andy~ RCrocs/Line Mt. - Route 63 Motorsports #736 Ultra4 #4343 Co-driver - Molten Motorsports |
Member # 84570
I woul lower it if your at 10" I run 7" springs that are probalby sagged at least an inch but I feel it is still to high. I run 35" with very little trimming and can clear 37's. Set your bumpstops and use your travel for droop. You don't need 8" compression travel for trail running 3"- 4" is plenty imo.
KOA-789
Member # 11777
Doesn't sound like you've had it out yet. Having bought a pre-built rig, I would go over everything very carefully, checking welds, nuts and bolts, clearances, etc... then I would wheel it for a season and determine where to go from there. You'll quickly learn what to change, vehicle limitations, and weak points. You may find that the vehicle is set up fairly well already, or you you may find it really needs alot of work.
Asking for input on this pre-built rig having no seat time in it will only get a ton of different responses and speculation, which for me would be extremely frustrating. Enjoy your purchase and get it out on the trail!!! |
#12 (permalink) |
Member # 4368
10" is too much. I ran 37's on 5.5" on my old chopped ZJ and I run 35's on 5.5" on my DD ZJ. 6-7" would be plenty of lift for 37's and it will be much more stable.
As for spring rates, I have no idea. I ran really soft springs on my SAW's but I also had no weight in the rear. I know Hal had coilovers on a fullbodied ZJ so maybe he can fill you in on spring rates. I can't remember his screen name on here though. for the t-case I wouldn't mess with a 241. Get an atlas or something with with twin sticks. and get alloy shafts for that 44 before you spend countless hours and dollars swapping out destroyed 44 shafts. |
#13 (permalink) |
Member # 79762
What the fuck is happening to this site???
By the way, I have 5.5 inches of lift and clear 40's with 12 inches of travel at all corners. LCG=GOOD
UA 2009 - 98 ZJ - RIP T-Fab 4 seat chassis with a few parts on the shelf |
#15 (permalink) |
Member # 18115
I have messed with spring rates some on my ZJ. I am running really soft springs right now. I have swayaway 16" CO's. I run 250 over 300 in the front and 150 over 300 in the rear. it has worked well for me. But I still think the back is to light. I want to get some shorter springs and run an air bag setup on top for some adjustability for off camber stuff among other things.
I want to use universal air suspension but they currently only make bags for 2" coilovers. ![]() I think you should lower the rig as well, my rig sits a bit high to. Last edited by Tommy_M; 05-17-2007 at 05:43 PM. |
#16 (permalink) | ||
Member # 18531
[QUOTE=weedwacker;9581606]It ain't perfect but it works well if lubed. [/QUOTE] |
#17 (permalink) |
Member # 7073
I can't believe that ZJ is still kicking around.
If you want more indepth conversation on ZJ specific stuff go to www.mallcrawlin.com Most of the guys already surf here as well, but the answers you have might already be answered with a quick search over there.
There is no such thing as Driver Error, Only Vehicle Failure. |
#18 (permalink) |
sorry dude there is no way that ZJ have 10" of lift ofer factory. mabey including the tire lift.
EPIC POLYMER RACING Toyo Tires Offroad Race Team | EMF Rod Ends | Big Country Customs | Mulitia Muffler | VancouverWaterjet.com EPIC POLYMER RACING ULTRA 4 Buggy Build WJ Grand Cherokee |
