Member # 72429
drivers side Front 3-link.... is there room?
I'm running out of space ! I just finished 4-linking the rear of the Xj and i'm looking at doing away with my RE style radius links in favor of a 3-link. I hastily welded a 3/8 plate truss across the diff of the HP 44 going in. I don't really like the idea of a super-braced pass. side axle mount for a 3- link as i'm worried about the link separation with the center of the lowers mounted at the centerline of the axle tube. That leaves me with running a link on the drivers side. I'm not scared of cutting sheet metal as i already have to worry about covering up holes for a flipped 231doubler to a flipped 300 and two rear upper links
Any pics of driver side 3-links? i've found several for tj's but not sooo much luck with the xj. thanks in advance ! Adam |
Not the best picture, but its a picture I guess.
![]() I don't know how well the lower links being at the center of the axle will be. I would imagine if you are going with a 3-link you would want them towards the bottom, so the 3rd link effectively keeps the pinion angle intact.
'97 S10: D44+Aussie/9"+Detroit | AMSOIL Dealer | <>< Last edited by MudOnTheTireS10; 05-01-2007 at 01:51 PM. |
Member # 7575
Here's mine, about 40,000 miles on it and it works well.
The axle housing with all the bracketry welded on... ![]() Driver's side... ![]() After a lot of trail time...
TDO Dysfunctional Rockcrawlers. URF Racing. JV rally post #31. |
Pigs Fly
You guys really need to get over the "centerline of the axle" theory. It's bullshit. Having the link mounted at the axle centerline does NOT suddenly create infinite force on the other links, and in fact it's not much different than mounting it anywhere else.
FWIW, I run a single upper link on the driver's side in my XJ, with a passenger-drop diff, trussed all the way across. No biggie. Other folks have done them on the opposite sides too. I dunno if it'll help your situation much, but here's how I snuck it in there...
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 |
Member # 25239
My upper link is on the passenger side, as is Paul Sinclair's, and we've wheeled the dog shit out of them, both crawling and hauling ass. Mine has been that way for 6+ years. And, my lowers are in the middle of the tube (actually, slightly above center line).
Build it right, make it strong, make the seperation enough, and don't worry about what side it's on. I adjusted mine one time, increased the seperation at the axle to increase anti-dive, and it works well. If you want it on the drivers side, go for it, it can be done....but don't worry that you shouldn't put it on the pass side.
Richard Gauthier Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643 Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes |
#7 (permalink) | |
Member # 75076
Why not just weld the upper to the top of the pumpkin? (why angle it to the side?)
flame suit on...
Real trucks don't have spark plugs [URL="http://community.webshots.com/user/444turbodiesel"]My Pics[/URL] Last edited by 444turbodiesel; 05-02-2007 at 11:15 AM. |
#12 (permalink) |
![]() ![]() As far as I'm concerned, the upper link is pretty much only there to keep the pinion angle correct. Also, welding the upper on the pumpkin brings up the cast issue, plus if you have a lot of uptravel there might be concerns with contact of parts above it. Had to consider the driveshaft being in that same general area as well.
'97 S10: D44+Aussie/9"+Detroit | AMSOIL Dealer | <>< |
#14 (permalink) |
For a parralell 3 link setup w/panhard, the upper and lower links should be the same length and parralell to eachother horizontally for it to keep the pinion angle continous througout the range of motion. From the picture it looked like it may not have been :P
Looks much better in pic2 ! Got a build thread on that S10?? Got a guy here locally who we are trying to get to do the same thing!
#16 (permalink) |
Don't have a build thread I don't think. I have some threads in different places that recaps everything with all the pictures I have, and then there is the photobucket location. PM me if you're wanting to see those and I'll dig up some links.
#17 (permalink) | |
Pigs Fly
Keeping the pinion angle constant should be the least of your concerns.
#20 (permalink) | |
Member # 4001
You're a dumbass and are contributing to the reason that dudes like adam90xj come here thinking that what they have done is correct...and then get all worried when it doesn't work right. If you don't know what the fawk you are talking about, go back to asking questions until you do know. Adam: definitely move that upper link to the top of the diff at least. I've successfully welded to cast with either 6010 or 6011 (Can't remember). However, it wasn't pretty and I do suggest that you find someone with an arc welder or pay a welding shop to weld it with hi nickle content rod. Actually, depending on the room, you want the upper link o be as close to center as possible. This helps to distribute braking forces evenly. Now don't get crazy if you can get to the actual center...just get it as close as possible TOWARDS the center without causing yourself heartache.
Dysfunctional Rockcrawlers Last edited by Scout Dude; 05-04-2007 at 09:16 AM. |
#21 (permalink) |
Member # 37606
Here are four links to photo albums of my setup. I put a long arm 3 link on the drivers side of an xj with 4.0L/AW4/NP231/HP D44 front/LP D44 rear. It took some work, but it fit. I did rotate the 231 up just a touch, used a stock tranny mount, have a flat crossmemeber even with the bottom of the frame rails, modified the AW4 shifter a little to put the shift arm closer to the tranny, and redid the t-case shifter so the lever at the t-case points up and there is one link from that lever to the stock tunnel mounted cab shift lever. Some of the above posters have manual tranny's, different t-cases, or run shorter arms. All can be made to work with enough reworking of things. Jeff
http://share.shutterfly.com/action/w...=8IbtGzVo3bMoc http://share.shutterfly.com/action/w...=8IbtGzVo3bMo- http://share.shutterfly.com/action/w...=8IbtGzVo3bMpY http://share.shutterfly.com/action/w...=8IbtGzVo3bMp6 I should mention that I used 4x6 box tubing cut in half to plate my frame rails, so the mounting of my crossmember may look a bit different. Here is an album of the frame rail work prior to doing the long arm 3 link front. http://share.shutterfly.com/action/w...=8IbtGzVo3bMqU Last edited by Jeff_98xj_WI; 05-04-2007 at 09:54 AM. |
#22 (permalink) |
Moderator
Member # 10249
I did a double triangulated 4link but my upper link frame mount idea could be used on a parellel 3, 4link.
Dave, 2013 KOH "Got, Some of it", 2014 KOH qualified. #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
#23 (permalink) |
Member # 37606
That's interesting. I feel the vertical separation of the links at the frame is pretty minimal though. My setup puts the link up into the transmission tunnel. I'm not saying your setup doesn't work, but I just wanted to point out the minimal vertical separation of the links at the frame. Jeff
#24 (permalink) |
When I look at my truck, I fee like if I would have put the upper link on top of the pumpkin that I would have issues if the drivers side ever fully compresses.
I can't really see that upper link not having clearance problems. Maybe its just me?
#25 (permalink) | |
