sway bar fitment - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-05-2007, 02:38 PM   #1 (permalink)
Member # 37184
sway bar fitment
I'm experiencing clearance problems with my stock sway bar.
I installed a WJ steering gear, which moves the Pittman arm right next to the frame, so that at full turns to the left, the Pittman arm just kisses the arm of the sway bar. My question is, does anyone know the width of a WJ sway bar? Jeep must of had the same problem I'm experiencing, and obviously solved it. I'm thinking the WJ bar may be a little wider than the XJ bar.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's.
Bubba_Jeep is offline   Reply With Quote
Old 05-06-2007, 10:38 AM   #2 (permalink)
Member # 37184
Some one with a grand Cherokee must be willing to measure the width of their sway bar? Sure would appreciate your effort.
Old 05-09-2007, 07:34 PM   #3 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Bump for some input
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
Old 05-10-2007, 09:20 AM   #4 (permalink)
RECON-ROCK SLUT
Member # 68433
Cut and lengthen your sway bar so it doesnt hit. Is that a possibility?
bholt5035 is offline   Reply With Quote
Old 05-10-2007, 09:26 AM   #5 (permalink)
Member # 62094
just cut the swaybar off
AKA xjkevin
XJ, 60/14bolt,,doulbler, linked, chopped, 39 crawlers....
jeepnzj is offline   Reply With Quote
Old 05-10-2007, 01:42 PM   #6 (permalink)
Member # 37184
Can't cut it off, it holds my radiator up And, Bhlot, the only way to widen a sway bar withot destroying it, would cost more than a custom bar built made specifically for my Jeep. Can't weld on the sway bar without killing the temper that's required to make it work. I guess I'm going to have to get off my fat-ass and go looking for a ZJ or WJ and measure it myself.
