Member # 77493
Jeepspeed pre-runner
My grand father left me his Jeep. Before he died he said i could have it if I fixed it up. This is what I started with.
![]() After a LONG weekend my father and I got the lift on and the new wheels and tires. ![]() ![]() Then i decided with some help from the guy at work that hit the jeep that i needed to upgrade the front end to the new body style grill and fiberglass fenders. ![]() ![]() ![]() I'm saving for the paint. After that a Currie 9" Last edited by NRT_Chris; 05-11-2007 at 08:53 PM. Reason: title |
Member # 5639
I wish there were rear fenders to match the front, I love the front's but hate how it looks with the stock rear.
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. |
Member # 86044
they do, give me a minute to find it heres a pick of one used on a 4 door...
-Jackson Polygoat My XJ makes wierd noises.... my MJ makes scary ones.... '92 XJ 4.0L, 4x4, 4dr Limited pretty much stock... |
#8 (permalink) | |
Crazy Diamond
Member # 7595
I could care less about the access to the rear seat. 2 doors make it easier to get in and out of for me and make rollcages easier to build. Screw the back seat. Mines been out of my 95 4dr for 3 years. I wish I could find a clean 2 door shell/body to swap all my XJ parts onto...
Great spirits have always encountered violent opposition from mediocre minds.” -Albert Einstein
#11 (permalink) | |
Member # 43562
Filarski Bros |
#13 (permalink) |
Member # 77493
There are a couple of reasons. They are cheep, this jeep is also my DD, and I sell them were I work. As far as the "pre-running" goes I believe that in order to get a good idea of the track conditions you don't need to be running at race speeds. I will more then likely get some Kings for it when i can. |
#14 (permalink) |
Member # 86044
Do you sell Sway-Away or Fox where you work? Get some 10" 2.0's for the front and go 12" in the rear, play with the valving till it rides good enough for you.
Get Remotes... your shock will last longer
-Jackson Polygoat My XJ makes wierd noises.... my MJ makes scary ones.... '92 XJ 4.0L, 4x4, 4dr Limited pretty much stock... Last edited by IslanderXJ; 05-12-2007 at 07:15 PM. Reason: Another recommendation. |
#15 (permalink) | |
Member # 77493
![]() We carry Rancho and Walker Evans. the RS9000X are way cheaper then the W.E.s . Like i said ill probably be getting better shocks as soon as my budget allows for it Last edited by NRT_Chris; 05-12-2007 at 07:33 PM. |
#17 (permalink) |
Member # 77493
Why would i want to spend the money on a 2.0 with a res and that shitty small hose that will cause heating issues. I got the Ranchos for like 40.00 each. Like I said before I don't do a fast pre-run. for now the ranchos will serve my purpose. The only reason I would go with the 3" and not a 2.5 bypass (which i like better) is I don't want to hear the bypass clicking everyday
#18 (permalink) |
Member # 22176
Looking at the vehicle you built, I think a 2.0 would be a huge improvement. And it would give you the chance to improve the valving, whether you pre-run fast or slow.
Yes the twintubes are $40ea. That XJ could kill them in one hard run however. Remember that although the reservoir can is 2 3/8 the working piston is only 1 3/8" diameter. Fade, while even running calmly will be an issue. 2.0 Resi's are always available on the desert sites, and due to perceived value issues, they are cheap as hell for what they are. Why do you think that reservoir hose size effects the heating of the shock?
I can break a steel ball in a rubber room! |
#20 (permalink) |
Member # 83971
Chris, Where did you get the front grill from? I've been searching online and coming up empty handed. Thanks.
__________________________ EKCO RACING #24 [url]www.ekcoracing.com[/url] [url]www.jeep-tv.com[/url] |
#25 (permalink) | |
Member # 77493
