XJ, MJ coil to leaf conversion tech. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2007, 09:20 AM   #1 (permalink)
Member # 51526
I like the idea of starting specific tech threads for gathering information. One I haven't seen yet in the new Cherokee forum is one on converting coils to leaves. I don't have a lot of input on this topic yet but I plan to change that in the near future
Hopefully this is of interest to gather some decent tech in one spot.
Thomas M is offline   Reply With Quote
Old 05-12-2007, 09:42 AM   #2 (permalink)
NothernAZxj's Avatar
Member # 8528
Why in the world would you like to take a step backwards on tech.....IVe built one for a guy and let me tell you its the worst mod you can make IMHO. not cheap to do, loss of performace...........you name it not much in the way of good
Brian Harmon
NothernAZxj is offline   Reply With Quote
Old 05-12-2007, 09:51 AM   #3 (permalink)
Member # 51526
But there are also people who have done it and are quite happy with their conversion for many reasons. I was hoping more for tech than a pros and cons thread but we take what we can get
How did you set up the conversion you did? Maybe if you give some specs we have something to compare against someone who was happy with their set up......Ya know what works, what doesnt?
Old 05-12-2007, 09:56 AM   #4 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Check out naxja.org for info about this. There is tons of posts about it.
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
Old 05-12-2007, 10:04 AM   #5 (permalink)
Member # 8528
conversion shackle reversed, trail ready shackle bar widened a bit MJ leafs
pros
a bit more stable on the highway
cons.
6" loss of approach angle.
shackles through the frame get hung up
loss of center ground clearance. BIG TIME
loss or articulation. about 6" less
thats just a few. its not worth effort
Brian Harmon
Old 05-14-2007, 06:57 AM   #6 (permalink)
Derek K10's Avatar
Member # 43420
im going to have to disagree
im running leaves up front on my mj, with waggy springs it flexes more then any short arm front ends and was WAY less expensive then it would have been to build or buy a long arm kit and set it up for my d60
mine is nice and low, extremely stable and just plain works
only con i have found with mine, is i have bent a couple main leafs on the stock waggys springs, going to try a set of aftermarket double wrapped springs eventually
i have pics from the whole build up, just let me know what you want to see
bone stock MJ on 38s
Derek K10 is offline   Reply With Quote
Old 05-14-2007, 07:13 AM   #7 (permalink)
Goatman's Avatar
Member # 25239
I ditched the rubber bushings in the UCA axle mount to eliminate the slight front axle wrap they allowed............imagine the front axle wrap you'd get with leaf springs.
Cheap is the only reason. Performance wise, a decrease in every way. As far as fabbing, no simpler than building a new link setup, and the only cost really is paying for the link end joints. Brackets have to be made either way, link material isn't expensive, so it's just the cost of the joints. After paying to set up a front D60.....to get better performance and reliability, why go cheap on the suspension that makes it all work? Hey, do what you want.....but it certainly doesn't work better.
This stuff is always weird.....changing just to change. Leaves to links and links to leaves.
Richard Gauthier
Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643
Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes
Goatman is offline   Reply With Quote
Old 05-14-2007, 07:22 AM   #8 (permalink)
95steel's Avatar
Member # 14509
I ran into so many problems with my old MJ's suspension that I wanted something I would not have to fuck with every time I went wheeling.
For the style of wheeling I do, leaves work well. I don't have the travel a long arm has, so what. I am locked front and rear and have more travel than I can use. I have only lifted a tire a couple of times.
Comparing short arm to leaves, advantage leaves. Long arm to leaves, advantage long arms...
I run mine 500 miles a week and wheel when I can. I don't wheel as much as many people here, but people who bash the leaf spring conversions don't know shit... or can't build worth a shit.
I run BDS YJ springs on the front of mine, soa with a small shackle lift in the back. I clear 36" irok's and have run much faster on road than I thought possible (wifes water broke and I needed to be home). My jeep has a much better ride than my old 2wd dodge diesel. Corners as well as anything should on Irok's. I have not run into any problems or "cons" with mine yet.
As with anything, if you actually plan the modifications before you do them they tend to work.
95steel is offline   Reply With Quote
Old 05-14-2007, 07:42 AM   #9 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
True enough.
For those looking to do some more reading, here's a thread I started back in '05 with some decent discussion of the pros and cons. It's more about the relative merits of each setup (not necessarily which one is "better") and covers a lot about the specifics of doing it on an XJ/MJ front end.
http://www.jeepin.net/forum/showthre...ing+brake+dive
'94 XJ RIP, time to move on
New East Coast TTB racer in the works, trimmin' the fat...
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote
Old 05-14-2007, 11:38 PM   #10 (permalink)
Member # 18531
http://www.naxja.org/forum/showthrea...ing+conversion
[QUOTE=weedwacker;9581606]It ain't perfect but it works well if lubed. [/QUOTE]
PornstaR is offline   Reply With Quote
