A VERY humble jeepspeed build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2007, 04:50 PM   #1 (permalink)
skullver's Avatar
Member # 60364
started with these about a year ago, the brown one is a 1985 XJ pioneer 4wd, had a 2.5L, the one behind it is a 1991 that was t-boned on the psnger side used for the motor/tranny/xfer case donor:
preliminary cage that has changed add some tube here, remove some tube there etc. 1.75" x .120" DOM
35-spline Ford 9" with spool and deaver leaf packs:
MORE bombproof block mounts, motor mounts have a tendency to shear off the block hardware, these add quite a few more mounts using existing tapped bosses in the block:
the dana30 front end, built by Curt LeDuc:
Shocks, 2.5" x10" travel SAW piggybacks, SAW 2.0 x 4" stroke hydro bumps:
a bit of bracing for the bump cans:
rear bumps and shock mounts, 3.0" x 14" travel SAWs remote resi:
skullver is offline   Reply With Quote
Old 05-16-2007, 04:51 PM   #2 (permalink)
skullver's Avatar
Member # 60364
starting on the 2wd beam:
trackbar mount:
almost done
some plating for the front end:
start of the engine cage and suspension tie-ins
start of the cab area:
Old 05-16-2007, 04:52 PM   #3 (permalink)
skullver's Avatar
Member # 60364
full traction longarms getting tied into the mix:
got some maxxis bighorns 33/12.50
and the start of our "horn"
and finally the seat mounts tacked and ready for plating/gusseting:
Feel free to ask any questions you may have, I have tons more pictures available and would be happy to help anybody that asks about the build, it has been fun and we should be racing it for the first time this coming August for the night race in Lucerne Valley
Cheers
Chris(soon to be 1735)
Old 05-16-2007, 07:15 PM   #4 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Keep up the good work. Post up those pics and give us the lowdown on the tech set-up.
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
Old 05-16-2007, 07:32 PM   #5 (permalink)
Member # 53344
Awesome build, I am drawn to Jeep Speed for some really weird reason. I only have a few questions for no other reason than to ask them.
What thickness of plate did you use to plate the front and why not plate the portion below the doors?
What springs are you using in the front?
Can you show a pic of the upper shock mounts in the rear?
PureFunction is offline   Reply With Quote
Old 05-16-2007, 07:56 PM   #6 (permalink)
skullver's Avatar
Member # 60364
thanks much
the plating is .120" CR steel, got them from a jeepspeed guy, no matter how clean you get that metal right there, the glue that holds all those panels together was killing me, it was like getting sprayed with hot shrapnel when I was welding it all up, and I was bundled up pretty good. Got lots of little scars from that.
I currently have a set of Deaver progressive rate coils for the front, they are coiled a bit tighter towards the bottom of the spring.
The "frame" rails are plated with 3/16, TNT unibody stiffener
well the rear upper shock mounts used to look like this but they were built for a 2.5" 3-tube bypass, well we have now decided to go with a 3.0 shock which has a longer compressed/extended length, bigger body, and those mounts would not work, took the plasma to them and now it is back to the drawing board, I am going to do something a bit different than previous, same double shear but more tubing based, if that makes any sense:
R.I.P.
Old 05-16-2007, 09:05 PM   #7 (permalink)
Member # 85319
I'll see you in a month and a half
98 XJ/30/44 with discs/32 bighorns/some armor and other goodies.
sharpie1k is offline   Reply With Quote
Old 05-16-2007, 09:19 PM   #8 (permalink)
jpnbren's Avatar
Member # 83807
Excuse the possible stupid question but did you mount the rear shocks to the spring plates? And is that a jeepspeed thing or is this a common setup, cause I have never seen this? By the way it is a very nice build, i like your modesty in saying its a humble build.
93 New Holland Blue XJ with 1 tons, chopped and exo'd on 38's
Eph 4:1-7
jpnbren is offline   Reply With Quote
Old 05-16-2007, 09:41 PM   #9 (permalink)
Beat95YJ's Avatar
Member # 22176
Doesn't Jeepspeed require BFG tires?
Beat95YJ is offline   Reply With Quote
Old 05-16-2007, 11:39 PM   #10 (permalink)
skullver's Avatar
Member # 60364
yes they are, I have seen some jeepspeeds with them and others inboard a bit on the tube, it is a natural spot for them if you are going through the floor with your shocks but really it depends on how/where you do your upper mounts
They are the most common but other jeepspeed approved tires are Maxxis, Goodyear, and Mickey Thompson, you must use American racing rims though.
Old 05-17-2007, 02:48 PM   #11 (permalink)
pipehitter155's Avatar
Member # 73680
that shit looks fawking sick dude...lots of talent there bro....keep up the good work...
91 toyota pickup--a work in progress
XJ, tons, 40's, EOR cage, locked, doubled...GONE
pipehitter155 is offline   Reply With Quote
Old 05-18-2007, 10:53 AM   #12 (permalink)
skullver's Avatar
Member # 60364
Thanks a whole bunch, for everything, I would really like to buy you a beer sometime mang, tons of respect for Vets!!
Old 05-18-2007, 12:04 PM   #13 (permalink)
Member # 1636
In one picture you show a braced D30, and in the other a 2WD beam. Is the beam a spare in case you break the D30 out in the middle of nowhere, or is it required/desireable for certain races?
chris demartini is offline   Reply With Quote
Old 05-18-2007, 12:10 PM   #14 (permalink)
skullver's Avatar
Member # 60364
most of the time we will be running in 2wd, but some courses 4wd is beneficial, so we will remove the front shaft and swap the front ends, we will also have a spare 3rd for the rear so we can have lowest for D30, 4.88 while in 4wd, and have a 5.xx third for running 2wd, still haven't gotten to the dialing stages yet but that is the plan.
Chris
Old 05-18-2007, 09:13 PM   #15 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Which springs are you running in the rear. I'm ordering up the Denver JeepSpeed coils like you have and am looking for a good match. I'm thinking about Denvers or maybe National springs. I figure a soft spring rate in the rear will help at speed with the proper shock valving and bumpstops. I don't like most of the springs I have used and like the military wrap and some of the other features. Mine won't be a race XJ but I want the handling like a JeepSpeed set-up has. I still need to figure out shocks and valving yet also.
Any input would be great.
-Albert Einstein
Old 05-19-2007, 12:31 PM   #16 (permalink)
skullver's Avatar
Member # 60364
We have the Deaver 1654G9 packs and our rear shocks are set up with .010 compression, .012 rebound, haven't tested them yet so can't input, I believe the national springs are custom so you will need your wheel weights, good luck.
Old 05-19-2007, 05:59 PM   #17 (permalink)
HeiserOilMotorsports
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
Lookin SWEEEET!
Scott
Black Star Status!
Po' riggity is offline   Reply With Quote
Old 05-20-2007, 04:29 PM   #18 (permalink)
skullver's Avatar
Member # 60364
thanks
after a lot of thinking I decided to shine going to C.O.R.R race and locked myself in the shop, got one half of a shock mount almost done, no helpers so everything took twice as long, not to mention a whole bunch of head scratching and ideas that didn't pan out, I'm pretty happy with how they are turning out, gotta go make sure I am still married
Old 05-20-2007, 09:27 PM   #19 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
I like this design better. Nice work. You can come fab on my XJ anytime.
-Albert Einstein
Old 05-20-2007, 11:33 PM   #20 (permalink)
Member # 85319
Nice work Chris. If you will be in the shop July1-3, I can be your helper. I am going to be in the area june 30 until july 5.
Old 05-21-2007, 09:02 AM   #21 (permalink)
skullver's Avatar
Member # 60364
Me too, thanks much. It was a lot of work. You are a bit far but if you are ever in the area........
I'll be EXPECTING you, heheheh, just kidding, I can always use some help though, one man operations bring the suckage
Old 05-21-2007, 11:22 AM   #22 (permalink)
blackcloud's Avatar
Member # 68088
Send a message via AIM to blackcloud
just a quick question, if the compressed and extended lengths of your shocks are longer now, why did you move the mounts down? or is the picture just decieving?
blackcloud is offline   Reply With Quote
Old 05-21-2007, 11:30 AM   #23 (permalink)
skullver's Avatar
Member # 60364
nope it is down about 1.5" but the shock bodies are much bigger also so it wouldn't fit mainly because of that, we have been messing with the compression/rebound travel and finally decided to try and get more droop, as it is now we can vary/play-with the compression from 4" to 10" depending on lower bump striker pad location so we will be finalizing the location after testing/experimentation, we are limited to 12" of rear wheel travel so I am still kind of trying to figure out what travel ratio I want, any input would be appreciated
edit: forgot to mention the previous shock was a 18" travel 2.5 shock, the new is 3.0/14" travel.
Old 05-21-2007, 11:58 AM   #24 (permalink)
Member # 85319
chris: were I to have cash in hand down there, wanna help me build a cage?
Old 05-21-2007, 05:08 PM   #25 (permalink)
Member # 43562
Hey Skulver, if you have the engine out, it would be a really good time to strengthen the frame area where the engine mounts bolt down. hat area dosn't last long. It starts to crack all over the place. Ther're are a bunch of Jeepspeed racers that have had the engine mounts break right off the "frame".
Filarski Bros
GoodTimes is offline   Reply With Quote
