snorkel 85 xj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2007, 10:00 PM   #1 (permalink)
Member # 80960
Exclamation snorkel 85 xj
i have an 85 jeep xj with the 2.5 4banger. it is carbd and i thought of something today and i am asking for answers if possible. i have a rubicon trip comming up and i know im going to be going through alot of dirt and wanted to know if anybody had any ideas for a snorkel on a crrbd motor... i was thinking about re-routing it to the back of the hood with a reverse hood scoop. if you have any ideas that would be great! im leaving in 8 days so the soonea the betta!
85 jeep xj -the only one with blue ballz hangin from the rear hitch!
[SIZE="4"][SIZE="3"][I][FONT="Comic Sans MS"][COLOR="White"]Cameron Park Crawlers[/COLOR][/FONT][/I][/SIZE][/SIZE]
[url]www.myspace.com/cameronparkcrawlerz[/url]
[FONT="Arial Black"][SIZE="3"][COLOR="DarkGreen"]Friends Of El Dorado[/COLOR][/SIZE][/FONT]
[FONT="Courier New"][SIZE="3"][COLOR="Blue"][B][I][U]Friends Of The Rubicon[/U][/I][/B][/COLOR][/SIZE][/FONT]
co-pilotmillie is offline   Reply With Quote
Old 05-17-2007, 10:39 PM   #2 (permalink)
Member # 10739
how does a gay snorkel help with dust???
:laughing:
scraprock is offline   Reply With Quote
Old 05-18-2007, 01:02 AM   #3 (permalink)
Member # 53528
dont get around much eh?
theres this place called Australia, one of the major reasons they run snorkels is becuase of dust.
rockyota83 is offline   Reply With Quote
Old 05-18-2007, 06:49 AM   #4 (permalink)
Fozzy_Bear's Avatar
Member # 50242
I just installed a snorkle on my 89. It's not carbed, but I don't understand why you think it will be any different. The snorkle doesn't tie directly into the throttlebody, it cuts into the existing airfilter housing. IIRC, the filter housing wasn't significantly changed when Jeep went to FI (but I COULD be wrong...) so the type of injection would not make a difference.
The only thing I can see being different is that the 4-banger has it's housing in a slightly different location. The flex-hose (connecting the formed snorkle body to the filter housing) would just have to route differently.
Am I just way off-base? Or did you already modify the air filter of your rig?
Shit happens. Carry a shovel.
Fozzy_Bear is offline   Reply With Quote
Old 05-18-2007, 07:25 PM   #5 (permalink)
cherokeefreak92's Avatar
Member # 91575
What a dumbass ^^^^
cherokeefreak92 is offline   Reply With Quote
Old 05-19-2007, 06:18 AM   #6 (permalink)
Member # 22393
No...the carb'ed 4 banger(84-85) used a standard round airfilter housing.In 86 theTB injected 4 used the box like the 6's.
OlyWa
OlyWaXJ is offline   Reply With Quote
Old 05-19-2007, 08:59 AM   #7 (permalink)
KOA-789
Member # 11777
You won't need a snorkel this time of year up on the 'Con. Most of the usual dusty areas are under water (near the Springs), and the other areas are very moist due to the snow run off.
Now, if you're running a stockish rig through, there are deep water areas on the Tahoe side this time of year that you might need a snorkel for.
Rigs running snorkels in Australia and North Africa have the inlet as high as possible (at or above the roof line) to help with dust issues. Most of the dust issues are caused by groups of vehicles running in a packs. Moving the inlet to the back of the hood is only raising the inlet about 6 inches, which won't cut down on the amount of dust the inlet will encounter.
FWIW, I've traveled to the Congo, Rwanda, Kenya, Bolivia, and numerous other countries in Europe - I've never seen a snorkel on a vehicle. Even on the FJ-80 group I came across in Southern France going to Tunisia via ferry for rally trials didn't have one.
I've seen a few here pounding pavement in Norcal
Capt. Nemo is offline   Reply With Quote
Old 05-19-2007, 12:52 PM   #8 (permalink)
Member # 80960
Uhh what the hell kind of a comment is that?!? You’re not that smart are you? I don’t know what you do for fun (drive around town) but my buddies and I go on the Rubicon when we can but we mainly like to do trail runs. This means lots of Dust!
Anyways...with the setup im thinking of it’s just to get it out of the way when I do a water crossing or when I go through a big puddle. The very beginning of the air intake is pretty much at the near the bottom of the grill. Jeep must not have been thinking clearly when they designed it. So the water gets sucked in pretty easily.
Here let me tell you guys why im doing this. 2000 miles ago I bought a brand new Fram air filter. Just yesterday I checked it and it was caked with dirt and mud. That’s just in 2000 miles. I had to replace it since my gas mileage dropped!
As for seeing other rigs with out snorkels, maybe they don’t have them cause they might not be a daily driver and really have no need for a snorkel. (Just a thought)
Old 05-20-2007, 05:48 AM   #9 (permalink)
Member # 14086
I notice your user title says that you are a NAXJA vice president. I also see from your profile that you are the wise old age of 23.
This surely must entitle you to decide what is gay and what is not on an XJ. You must also be the authority that decides how an XJ should be built.
I don't write this because I have a snorkel on my XJ (I do not), but write this reply simply because I think you're an ass.
Stephenw is offline   Reply With Quote
