Member # 91856
Rear buggy design?
I am looking for opinions on my design for the rear of my xj. The jeep isnt a road vechile and looks arent a concern for me. I am wondering if i going to be using enough support to jeep the rear tied together.
I know the bashing is about to hit me like a ton of bricks, but i appreciate the suggestions. I have braced the unibody to the exo, seen here. ![]() Unirail brace ( it will be welded on ) ![]() This is my plan
Pigs Fly
What do you have on the remainder of the frame rails for bracing?
I would recommend connecting that coil mount section down to something else...I realize you've got it braced to the cage but that's still a large amount of unsupported unibody rail. I think you need to clean some garbage out of the rig and then post some more pics so we can see a bigger picture of what you're planning on doing.
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 |
#3 (permalink) | |
Member # 91856
![]() Here are some pictures of the brace. ![]()
Pigs Fly
Ah...I looked at that and figured it was an upper coil mount for a rear link suspension. I see what you've got now.
The 1/4 ellip will take a lot of stress off the back half of the frame for sure. wait.... edit: 3/4 ellip? Why?
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 Last edited by vetteboy79; 05-22-2007 at 09:42 PM. |
Member # 25239
What's a unirail?
My XJ's have a frame.........it just happens to be hard mounted to the body, but it is a frame, it runs from the front bumper clear to the back bumper. ![]() Sorry, I can't see enough of what you're doing to comment.
Richard Gauthier Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643 Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes |
Moderator
Member # 10249
How do the sliders tie into the frame?
Your B-hoop and C- hoop have no X brace in the cab. Its completely open front to back and is not a strong design. Its ugly ![]() I would cut off your rear tube and start over on the rear, raise the gas tank and build around that. Start with a rear hoop kinda like the top of a truck bed, tie it into the rear bumper then into the C-hoop.
Dave, 2013 KOH "Got, Some of it" #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
#8 (permalink) | |
Member # 91856
I thought the cross brace in the cab and the rear would be a given to anyone. I guess i was wrong. Maybe i should have supplied more information. As for it being ugly, i wasnt trying to make it qualify for a fashion show. Last edited by jeepxj86; 05-23-2007 at 04:45 PM. |
Member # 25239
I don't get why you're going outside of the body lines on the C pillar, and then inside for the D pillar. The D pillar takes quite a bit of abuse, it's what usually hits and scrapes down the rocks. It's nice to have it positioned so it keeps the rocks off the rest of the structure......and it needs to be strong enough.
I don't like the lines you outlined with tape, that looks pretty useless to me....and while you might not be going for a beauty contest, it doesn't have to be real unpleasant to look at. I'd run the bar from the top of the C pillar where it connects to the C down bar down to the back corner of what will be your bumper. Then run from that bar down to reinforce your spring or shock mount or whatever that short piece of frame reinforcement is. Hard really to get ideas from what you've shown so far. A very good rule of thumb to use in cage building is to create as many nodes as possible, where multiple tubes come together at one point. You can build a cage with virtually no dead end bars, meaning a bar that intersects another bar in the middle. Try to make as many tubes as possible connect where other tubes are coming together.
Member # 91856
Goatman, i appreciate the information which you gave. I cut out what i had and went in this direction. The tube on the rear bumper is center above the rear shackle mount. As i said before there is going to be a 3/4 elipitical mounted. It will be tied to the rear bumper and the forward unirail mount which i made. I didnt mention before but the tank will be mounted in the rear and wheelbase is going to be stretched another 5". this will put the rear of my tire inline with the old rear shackle mount. I hope these pictures explain things a little better.
Member # 82889
Looking like there is going to be a lot more strenght in this design. Makes it a lot easier to see whats going on with the stuff out of the backaswell. Is there any plans to bring the gastank up, and out of the way? Fuelcell maybe?
#13 (permalink) |
Member # 25239
What you've drawn this time looks like it will be much stronger, and it looks better.
Good luck with your project........
