np231 front flanged yoke???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2007, 06:15 PM   #1 (permalink)
xjtony's Avatar
Member # 50866
Does anyone know of somebody who makes a 231 t-case front yoke that is flanged in stead of a u joint style yoke???????? im tryin to come up with a front driveshaft/parts here...
I currently have no rig.
xjtony is offline   Reply With Quote
Old 05-25-2007, 06:56 PM   #2 (permalink)
Member # 89483
the WJ's have that crappy double cv driveshaft setup, the yokes can have a small lip machined off and there is meat to drill a bolt pattern, like a Toyota yoke.
'lil mill/old Southbend/homemade bender/BullTear CNC plasma table w PM45
Caper is offline   Reply With Quote
Old 05-25-2007, 07:04 PM   #3 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Check out Dakota/Durangos/Rams w/231's if I remember correctly they all have them.
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
Old 05-25-2007, 07:09 PM   #4 (permalink)
Member # 22824
IIRC, I used an '87 or '88 NP 231 u-joint yoke to replace the flanged output on an old NP 207 I had (it had the crappy constant velocity front driveshaft) in an '85 XJ. It bolted right up. Maybe you could find one in a junkyard, and snag it to give that a shot.
Georgia Mike is offline   Reply With Quote
Old 05-25-2007, 08:30 PM   #5 (permalink)
rkjplt1's Avatar
Member # 28242
Yep, the pickups have them for sure. I'm looking at one right now.
rkjplt1 is offline   Reply With Quote
Old 05-28-2007, 04:30 AM   #6 (permalink)
Member # 63174
I think I have the opposite problem but basically. I have a 242 flange and need a 231. Here's a pic of mine, the top is 231 and bottom 242. In front of the 242 is my AA SYE that I need to bolt to. Can you switch out the flanges of a 231 and 242?
Family TJ is offline   Reply With Quote
Old 05-28-2007, 04:54 AM   #7 (permalink)
Member # 46175
For a 231 series case, use a 94 and newer Ram 231D front output yoke. If you have a 242 series case, use a 241D (89 n newer) or 241C flat flanged yoke short style (94 and down).
Famlit TJ, it looks like you are trying to bolt a hack-and-tap SYE compatible CV to your new SYE. Measure the distances between bolts and I will see if I have a 32 spline yoke that will fit that.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote
Old 05-28-2007, 05:06 AM   #8 (permalink)
Member # 63174
I have 2 front DS that mate to the SYE. That bottom shaft is a Tom woods and had the 242 flange. I was going to take a flange from a front 231 DS and try to switch out the 242 flange. It looks like it will work but I won't know until I get it apart. I just want to be sure I have everything I need before I do the SYE and new rear springs.
Old 05-28-2007, 04:51 PM   #9 (permalink)
Member # 63174
The flanges on the 242 and 231 are interchangable. I switched mine around today. I am good to go now.
Old 05-28-2007, 11:20 PM   #10 (permalink)
xjtony's Avatar
Member # 50866
so anyone got a spare flanged yoke that will fit a 231 front???? 26 spline isnt it, a dana 44 yoke will work to correct?
Old 05-30-2007, 12:00 AM   #11 (permalink)
xjtony's Avatar
Member # 50866
alright so the deal i got goin is that i cant keep a front driveshaft in my hunk of crap cuz the angle is so high that i have to grind too much off the yoke on the t case end that i end up busting one of the ears off the front t case yoke. so now im looking at those off set u joints from tom woods. i wonder if one of those at my t case end would actually help me out some??
Old 05-30-2007, 05:13 AM   #12 (permalink)
Member # 22393
You could do something like this.Thats my rear DS it's a D50 TTB axle joint stuffed in 2x.25" tube and a plate welded on the end.Think they get 40*+ in angle.
OlyWa
OlyWaXJ is offline   Reply With Quote
Old 05-30-2007, 04:01 PM   #13 (permalink)
xjtony's Avatar
Member # 50866
Yeah that would be great accept i dont have any dana 50 ttb axles layin around nor do any of my friends... i saw a guy on here that did that with some broken 60 axles, but i havent found anyone with any broken ones i could get yet... and that all comes about if i can find a dodge 231d front flange
Old 05-30-2007, 08:10 PM   #14 (permalink)
Member # 22393
Yeah not my idea...but a good one.Seems to work fine.Cant find D50 axles,are you serious? The things litter the wrecking yards.
As far as a flange goes sounds like some dodges,grands and cherokee's with 242's.
OlyWa
Old 05-30-2007, 08:46 PM   #15 (permalink)
xjtony's Avatar
Member # 50866
Yea, well i meant i checked my ready supply of crap around me and my buddies houses. We have a stockpile of ford 10.25/10.50 rear ends, and Dana 44 fronts. I did locate a 50 TTB but it only had one axle left in it and it was broken at the ears.... but im goin to a few junkyards friday so i'll see. anybody got any axles broken or layin around???
Old 12-16-2012, 11:18 PM   #16 (permalink)
Member # 81189
Do you have a crossmember drop? TC lowering kit or whatever?
Please keep in mind, when you drop the transfer case... You HELP the rear driveshaft angle by lowering the rear output... BUT you HURT the front driveshaft angle because you're tipping the front yoke up.
If you have the TC lowered, ditch it. This will help your front driveshaft angle issue.
You probably have too much lift as well. Trim your coils to lower your rig down an inch or two, this will make things MUCH better.
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote
Old 12-17-2012, 12:37 AM   #17 (permalink)
Member # 184396
^ interesting post from a 2k6'er. I'd think you would have figured out how to read post dates by now
Jeep450r is offline   Reply With Quote
