Doing a SAS need help knoing what this AXLE is. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-05-2007, 11:54 AM   #1 (permalink)
Member # 49032
OK so first off sorry no pics of the axle, the deal is I am looking for a dana 44 to do a SAS on my 89 trooper .
OK so i was up at my parents farm, and I found stitting in the bush a 44 front axle ( my dad used to own a few wagoneers )
But we both cannot figure what year its was from, we think its a 86 not sure.
But since its a pass side drop it has to be 79 or older right.
So I took the numbers off in hopes that you guys can help me figure this out.
So the numbers that are stamped on the axle are 0-86970
Then the numbers on the tag thats on the diff cover are 53-521-00 top
43-14-307 bottom.
And yes I have already posted this on the isuzu page.
Just thout you guys would klnwo more about the full size jeeps wagoneers .
I hope one of you guys know what that all means ..
Thanks.
franko is offline   Reply With Quote
Old 06-05-2007, 12:08 PM   #2 (permalink)
Member # 49032
I should add that it dose NOT have manuel hubs..
Old 06-05-2007, 02:51 PM   #3 (permalink)
Adnimistrator
FatCity's Avatar
Member # 2870
Can you get the axle lengths?
FatCity Off-Road Racing
FatCity is online now   Reply With Quote
Old 06-05-2007, 03:26 PM   #4 (permalink)
Go Dawgs!
BadAssXJ's Avatar
Member # 30164
I have no clue on reading those numbers, other than looks to be a 3.07 ratio. But on the other hand, what does it matter what year it came from? If it is the side drop you need, the width you want to go with, run with it.
BadAssXJ is offline   Reply With Quote
Old 06-05-2007, 04:20 PM   #5 (permalink)
Member # 51692
Send a message via ICQ to rocknbronco Send a message via Yahoo to rocknbronco
Your more than liely gonna need to change the gearing anyhow.
Space for rent sold it all....
rocknbronco is offline   Reply With Quote
Old 06-05-2007, 07:05 PM   #6 (permalink)
Member # 49032
Yeah I know i'll need to mach my 456 rear end anyway . I think its 59 wms not sure .
Thanks I think all .
Old 06-05-2007, 07:54 PM   #7 (permalink)
Member # 25325
Send a message via AIM to redranger4.0
If its from a grand waggy it has to be older then 80, my 86 grand waggy D44 had driveflanges, so im sure the older 79-down could too.
redranger4.0 is online now   Reply With Quote
Old 06-06-2007, 05:24 AM   #8 (permalink)
Member # 22393
73-79 pass drop,came in wide track and standard.79-89 drivers drop also came in wide track and standard.
If it's the drop you need and the correct width run it.
OlyWa
OlyWaXJ is offline   Reply With Quote
Old 06-06-2007, 06:30 AM   #9 (permalink)
Member # 92535
78/79 have Drivers side drop, I know cause I have one in my XJ. Sounds like You have a Chevy axle out of a Blazer...
Look here this might help you: http://www2.dana.com/expertforms/demenu.aspx?prod=AXL
[B]If Hank III won a Grammy he'd probably throw it in the air & blow it all to hell with his 12 gauge![/B]
hellbilly04 is offline   Reply With Quote
Old 06-06-2007, 08:31 AM   #10 (permalink)
Goatman's Avatar
Member # 25239
So, why do you need to know what it's out of? Most D44 parts are interchangeable, so if the pumpkin is on the side you need, and the width is OK, just build it.
Richard Gauthier
Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643
Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes
Goatman is offline   Reply With Quote
Old 06-06-2007, 11:14 AM   #11 (permalink)
Member # 49032
Thats guys,
and yes I am more then likely going to just use it and swap it manuel hubs..
Thanks again .
