Member # 76997
FS Dodge Ram Axles
here's the deal.... i've been thinkin about upgrading my axles for a while now. a buddy of mine has a set of axles from under his 99 Ram 1500. a D44 DS drop and a 9.25 chrystler in the rear. geared 4.10 and both locked. he's gonna cut me a good deal in them if i want them, he's going 1-tons. the rear is no big deal, done similar things before..... the front, uses a 4-link system thats similar to the XJ. what do you guys think??? can i just build some wider lower control arms? do i need to grind off all the front brackets and put on a set of XJ/TJ brackets??? its a CAD axle, but ii'm pretty sure i can just slip in a long side axle shaft from an older D44 considering it uses the same locker as the older D44's.... i did the locker install, and i'im re-gearing and locking his D60/D70 setup so the price on these will be right!
98 XJ 84 K5 |
Member # 5021
You would have to completely strip that axle and then figure out how to widen your spring mounts. I believe the dodge springs are ~41" on center and jeep is ~36"
For a 44 front and a ok rear axle I would pass unless you are just overly amazed by the setups. |
Member # 37184
It's also a low pinion set-up.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's. |
Member # 76997
alright then..... guess i'll just take the $$ for setting up his axles and put that twards lockers for my 8.25 and some new shocks.... thanks for the info!
98 XJ 84 K5 |
sc4wda
terry, its a '01
Dodge Ram 1500/360ci/4link'd/backhalf'd/chro-mod D60/D70/5.13d, ARB'd, & welded/37" MTRs Build Thread - /forum/dodge/774229-joining-bandwagon-my-buildup-bluedodgeram.html '03 CTD QCSB, 6spd 4x4, II SPS 62/80, 4" Flo-Pro, Edge EZ/Smarty stack, DDP 90HP, FASS 150, Fab Fours bumpers, Warn 16.5ti |
