Question about an axle swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-15-2007, 04:20 PM   #1 (permalink)
Member # 56981
Hi,
I heard that a 1976 f150 hp44 and 9" are a direct bolt-in. If it is true is there any other years that can work for it too.
Thanks
Kris
SnakeXcape is offline   Reply With Quote
Old 06-15-2007, 04:25 PM   #2 (permalink)
nate379's Avatar
Member # 20099
No.
nate379 is offline   Reply With Quote
Old 06-15-2007, 07:08 PM   #3 (permalink)
Member # 77930
Originally Posted by SnakeXcape View Post
Hi,
Thanks
Kris
whoever told you that they were direct bolt in's is a tard. they're far from 'bolt' in by any means of the word. for the 9", the spring perch width would need to be corrected, the brake lines would need to be looked at and adapted most likly, the drive shaft yoke would need to be adapted or changed and the front just gets more fun. pretty much figure cut everything off the front axle and start from ground zero and copy your d30 would be a good start.
53guy is offline   Reply With Quote
Old 06-15-2007, 07:17 PM   #4 (permalink)
Member # 53453
Uh... F-150s run 1310 u-joints. They bolt right in. I happen to have the yoke off one on my front D44. The only thing that would be needed is possibly a u-bolt kit for the yoke.
Anywho, these axles aren't even the same width.
DirtyComanche is offline   Reply With Quote
Old 06-15-2007, 07:39 PM   #5 (permalink)
SnivelRightsViolator
BerzerCO's Avatar
Member # 82394
They bolted right into my cherokee.
After a week of torching grinding & welding!!
BerzerCO is offline   Reply With Quote
Old 06-16-2007, 02:21 AM   #6 (permalink)
Member # 56981
i figured it was bull shit, thanks.
Old 06-16-2007, 07:25 AM   #7 (permalink)
magoo117's Avatar
Member # 11963
check it out /forum/axles-tires-wheels-sale/587756-xj-chero-currie-9-nj-will-ship.html
SPREAD THE VIRUS http://magoosmotorsickles.blogspot.com/ www.cyclesource.com
magoo117 is offline   Reply With Quote
