Front Ford Dana 44 question? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-19-2007, 04:34 AM   #1 (permalink)
Member # 2237
Just wanted to know if any of you have or know someone who has used the stock radius arms on the old Ford style Dana 44 and still had luck with getting good flex...please post pics of how you did it.
jbrooks86 is offline   Reply With Quote
Old 06-19-2007, 05:20 AM   #2 (permalink)
Member # 87769
i've seen a few of them on other sites and if they flex anything like my buddy's 73 bronco with the radius arm 3 link up front, they flex out nice
96_zjlarado is offline   Reply With Quote
Old 06-19-2007, 10:21 AM   #3 (permalink)
Member # 53344
I think there were some here that did just that and very good luck with it. http://trailkrawlers4x4.org/tkbbs/index.php
PureFunction is offline   Reply With Quote
Old 06-19-2007, 12:54 PM   #4 (permalink)
Xjcrawler736's Avatar
Member # 84970
Send a message via AIM to Xjcrawler736
I am doing mine in July. So i will report back with my results. Not sure if I am going to run the stock rubber joints on the end or do a custom job with RE joints or Heims but I will definatly post up my project.
Andy~
RCrocs/Line Mt. - Route 63 Motorsports #736
Ultra4 #4343 Co-driver - Molten Motorsports
Xjcrawler736 is offline   Reply With Quote
Old 06-19-2007, 06:55 PM   #5 (permalink)
Member # 82644
I did it. flexes great.
http://www.swva4w.org/forums/viewtop...t=322&start=60
flex shots
http://www.swva4w.org/forums/viewtopic.php?t=457
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE]
hadfield4wd is offline   Reply With Quote
Old 06-19-2007, 08:20 PM   #6 (permalink)
Mr.N's Avatar
Member # 1635
simple answer: No
You've a lot of tweaking to make the Ford style flex well... you can find it done, but it's a lot of work as any good system is...
Remeber it's your money...
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote
Old 06-19-2007, 08:45 PM   #7 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Originally Posted by Mr.N View Post
simple answer: No
Photo by Goatman
7* POLY BUSHINGS
no flex at all....
cant go anywhere with radius arms...
Photo by Goatman
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 06-19-2007, 09:07 PM   #8 (permalink)
Member # 44302
i got no flex shots as of yet , im just finishing my build up. i extended the arm a bit with some tube and put an RE joint on the end. should flex decent. if not you could always wrist it, but that could weaken it a but too. to anyone else who posted: are your arms just stock with some kind of flex joint on the end? no wristing?
jeepxj91 is offline   Reply With Quote
Old 06-19-2007, 09:41 PM   #9 (permalink)
Member # 84593
If anyone says the radius arms don't flex, just show them this picture....
HardcorewannabeXJ is offline   Reply With Quote
Old 06-19-2007, 09:48 PM   #10 (permalink)
WHITE RHINO's Avatar
Member # 71446
Send a message via AIM to WHITE RHINO
not a jeep but the set up you are talking about
(WHITE RHINO)88 Ranger, 2.9liter,1350/1354 doubler, HP 60 with Plated knuckles, chromos, PSC Hydro, 3 link, Rear Eaton 44" Pitbulls on H1's
Section8Krawlers.com
Extreme Dual Sport Tuff Lites Unbreakable Turn Signals for your Dual Sport/Adventure Bike
WHITE RHINO is offline   Reply With Quote
Old 06-19-2007, 09:49 PM   #11 (permalink)
Member # 71446
simple answer: No
thats bullshit i have $125 in mine work great done a shit load of trips no problem
Old 06-19-2007, 10:05 PM   #12 (permalink)
Postrunner
Member # 37109
I built one XJ with 12" extended ford radius arms and Johnny joints. Flexed fine, but the mounts hung 4" below the rails, even with 7* bushings. There are much better solutions out there.
RockcontrolXJ is offline   Reply With Quote
Old 06-19-2007, 10:17 PM   #13 (permalink)
Member # 71446
should have set them up better
Old 06-20-2007, 04:09 PM   #14 (permalink)
Member # 2237
Thanks for all of the responses. I think I'm gonna go ahead and use the radius arms on the Ford 44. This will makes things a lot easier than the other option I was going with (triangulated 4 link). I'll post some pics when done. Just in case anyone was curious, here's my winter project plans:
87' XJ
Ford dana 44 front-(detroit)
Ford 9" rear-(spool)
87 4.0L w/ 97 intake/injection
aw4 trans
231 transfer w/231 crawl box
Rusty's 8.5-9" front coils
SJ 7.5" rear leafs w/ 1.5" shackles
Rear leafs reversed
Lengthened Ford radius arms on front
Trac bar fabbed on the rear
As many sub-frame stiffeners as possible!!!!
Full hydraulic front steering
Full interior cage
38.5 x 14.50 sx's
Home-made rock sliders
Any advice//critics????
Old 06-20-2007, 07:04 PM   #15 (permalink)
Member # 82644
I'd look at the TNT customs D44 truss. I did the ford radius arm and it flexes great and was cheap, however you can take that axle and weld on the truss and be done. If I were doing it all over again I'd probably go that route. les custom fabbing make a project go quicker.
Old 06-22-2007, 08:11 AM   #16 (permalink)
XJ_ranger's Avatar
Member # 31848
87' XJ
Ford dana 44 front-(detroit) ALLOY USA SHAFTS, CTM JOINTS, HI-STEER
Ford 9" rear-(spool) CURRIE 35 SPLINE SHAFTS
aw4 trans
231 transfer w/231 crawl box (I dont know about this one)
Rear leafs reversed
Full interior cage
38.5 x 14.50 sx's (ALL THIS WORK TO RUN SHITTY TIRES?)
Old 06-22-2007, 09:20 AM   #17 (permalink)
Member # 73309
Send a message via AIM to horsepower4x4
Ford Arms work great!
I added a spud to the end which added 8" of length and allowed for an 1-1/4" heim joint to be added. Absolutely zero problems with them.
Greg Heinrichs
89 Cherokee 4.0L Turbo, AW4, NP242, Mog 404's, Hummer wheels, 42 IROK's and a few little body modifications. (This used to be our family car)
2001 Dodge Quad Cab Dually 4x4, Cummins, 6-spd, K&N, AFE, Edge 75hp injectors, Edge Attitude, 4" exhaust, 315/75R-16's
horsepower4x4 is offline   Reply With Quote
Old 06-22-2007, 09:38 AM   #18 (permalink)
Member # 84593
Originally Posted by XJ_ranger View Post
X2 on the Alloy shafts and upgraded u-joints in the front D44 at least to run 38.5 x14.5 tires.
Old 06-22-2007, 11:17 PM   #19 (permalink)
Member # 25601
Photo by Goatman
7* POLY BUSHINGS
no flex at all....
Photo by Goatman
pardon my french, but where the fuck is that?!?!?!!? I want to go there!
CrustyJeep- "Your faith in your government to protect your wife from you is LIBERAL THINKING."
88burban is offline   Reply With Quote
Old 06-23-2007, 04:43 PM   #20 (permalink)
Member # 50642
I ran that same setup on my second xj.I extended the radius arms and ran RE flex joints on the end.Flexed great using Rusty's 8" coils.There are a few on here that have ran this setup with great results.One of them that pops into mind is Ken Carter/Bruiser.Try a search,should turn up a few.
I have no idea what the fawk I'm doing
trailcreep is offline   Reply With Quote
Old 06-23-2007, 11:39 PM   #21 (permalink)
Member # 25601
oh yeah, and I run modified stock ford radius arms too. some pics on my myspace. www.myspace.com/associate02
Old 06-24-2007, 12:59 AM   #22 (permalink)
Member # 18531
Yea and if you dont belive him................. well you get the picture
[QUOTE=weedwacker;9581606]It ain't perfect but it works well if lubed. [/QUOTE]
PornstaR is offline   Reply With Quote
Old 06-24-2007, 05:36 PM   #23 (permalink)
Member # 25601
HAHAHA!!!
Old 06-30-2007, 09:15 AM   #24 (permalink)
Member # 63174
I sure hope that style works. I am getting ready to build mine this month. I cut the webbing out of the radius arms got some 2" DOM and some 1.5" dom for my joints to thread into. I had the 1.5 turned down and threaded and then I have Curries 2.25 joints with the 1.25 threads. I am adding some pics of What I will be using. I used a can for size comparison.
Family TJ is offline   Reply With Quote
Old 07-09-2007, 05:03 PM   #25 (permalink)
Member # 28151
Send a message via AIM to cherokee4x489 Send a message via Yahoo to cherokee4x489
go to james duff inc. they build stuff for broncos and they have some heavy duty radius arms that are powder coated blue and look alsome. they are really strong and can hold up to the hard abuse. and the flex pretty darn good! www.jamesduff.com
TOW RIG- 99 f-250 superduty 6 inch lift 36,15.50 micky tompson atz's
WHEELIN RIG-yellow 89 cherokee 4.0
- custom long arm 3 link front ford bronco dana 44, 4.88 and mini spool
- custom 4 link rear with ford 9 inch with 2.5 fox air shocks 4.88 and lockrite no slip locker
cherokee4x489 is offline   Reply With Quote
