Converting front xj d30 to 5 x 5.5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2007, 07:19 AM   #1 (permalink)
Member # 66921
Is there a way to convert a d30 to 5 x 5.5 bolt pattern instead of 5 x 4.5 without using spacers?
Thanks,
Jack
sktw8 is offline   Reply With Quote
Old 06-20-2007, 07:33 AM   #2 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Yep, the Warn hub conversion kit does that.
http://www.warn.com/truck/axles/hubconv_kit_5on5.shtml
It only costs about 10x as much as wheel spacers and still widens the axle a little on each side.
'94 XJ RIP, time to move on
New East Coast TTB racer in the works, trimmin' the fat...
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote
Old 06-21-2007, 07:24 AM   #3 (permalink)
Goatman's Avatar
Member # 25239
The kit also comes with 30 spline chromemoly stub axles, which are a considerable upgrade from the 23 spline stock stubs, and are stronger than chromo 19 spline D44 stubs. If you need 5 on 5.5, and are also putting in chromo inner axles, and don't mind spending that kind of money on a D30, then it's a pretty good upgrade. It also eliminates the unit bearing.
Richard Gauthier
Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643
Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes
Goatman is offline   Reply With Quote
Old 06-22-2007, 11:56 AM   #4 (permalink)
hitech_hick's Avatar
Member # 62866
If you want cheap and easy, go with wheel spacers. Here is another option for you...http://www.pirate4x4.com/tech/billav...HybridAxle.htm
hick
'97 XJ, D30, Ford 8.8, 35's
'94 Mazda B4000, D35 TTB, Ford 8.8, 35's
hitech_hick is offline   Reply With Quote
Old 06-22-2007, 12:06 PM   #5 (permalink)
Member # 35291
Wheel spacers are the devil....I wouldn't run wheel spacers on any of my rigs if you paid me
offroader5 is offline   Reply With Quote
Old 06-22-2007, 12:45 PM   #6 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
I hope you've never driven a Ford dually truck then.
Old 06-22-2007, 06:07 PM   #7 (permalink)
Member # 35291
Nope...I can safely say I have NEVER driven anything with wheel spacers.
Old 06-22-2007, 08:09 PM   #8 (permalink)
backyard wrenchers's Avatar
Member # 81935
put a dana 44 up there. what you would pay for shafts and hub conversions and all the B.S. you would damn near be at the same price but you would have a much better axle
Keen Motorsports #125
Thanks to our sponsors: Appalachian Offroad Inc and Clayton Offroad Manufacturing
Originally Posted by zachv View Post
I bet that will be the first rig ever with King coilovers and a C-channel truss!!
backyard wrenchers is offline   Reply With Quote
Old 06-22-2007, 08:34 PM   #9 (permalink)
Member # 82861
thousands of people run them with no problems, its just like running a rim with less backspacing.
2002 Jeep TJ, Ford 8.8, Clayton Rear suspension, 4" stretch, Build-up Coming Soon
smurison14 is offline   Reply With Quote
Old 06-23-2007, 10:47 AM   #10 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
That is VERY debatable. A stock 44 isn't anything special.
Old 06-25-2007, 04:45 AM   #11 (permalink)
Member # 11204
Send a message via AIM to xjweeble
What about 2005 or so grand cherokee hubs or even the whole axle? Some of them are 5 x 5.5 and have a separate tie rod and drag link setup getting rid of stupid Y setup that cherokees have they also moved the drag link 2 inches higher on the passenger side knuckle.
99 XJ Rock wagon 9/404's, 39.5 rockers, ori's.
xjweeble is online now   Reply With Quote
Old 06-25-2007, 05:47 PM   #12 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
I think WJs are LP. Other than that, they've got dual piston brakes and bigger rotors.. but I thought their bolt pattern was 5 x 5.
ZJim is offline   Reply With Quote
Old 06-25-2007, 10:00 PM   #13 (permalink)
Member # 88423
I too have the same question but I was thinking going to older cj front diff..... if anyone has any info on the front diff out of a 80s jeep cj it would be appreciated the front diff is involved in my suzuki sidekick build (want to stick with 5x 5.5 wheels)
Kcampen is offline   Reply With Quote
Old 06-30-2007, 10:02 PM   #14 (permalink)
Member # 66921
Would it be possible to have a machine shop redrill the wheel or the wheel mounting surface to a different bolt pattern?
Thanks,
Jack
Old 07-01-2007, 10:46 AM   #15 (permalink)
Goatman's Avatar
Member # 25239
Thanks,
Jack
I don't think there is enough material on the hub flange to go to the bigger bolt spacing. If there was, there would be very little metal left on the edge of the wheel stud holes, so you would need to tap the holes and use screw in studs rather than press in. Folks have been going to 5 on 5.5 on the front to match new rear axles for a long time, if this was possible it would have come up before, and I've never heard of it being done.
Richard Gauthier
Old 07-01-2007, 10:47 AM   #16 (permalink)
Goatman's Avatar
Member # 25239
CJ D30's are low pinion and passenger side drop.......if that works for you.
Richard Gauthier
Old 07-02-2007, 09:03 PM   #17 (permalink)
Member # 40665
Send a message via Yahoo to joe_and_jeep
Get a CJ D30 for $50. Grind off inner C's on both axles and put CJ inner C's on XJ D30. Reassemble with CJ parts.
I Like Boobs
joe_and_jeep is offline   Reply With Quote
Old 07-05-2007, 09:34 AM   #18 (permalink)
Member # 44659
So, I have got one more option that I have been running around in my head. I have done a lot of measurements, and they seem to work, I just am having a hard time finding the parts to test fit.
So, try finding a set of knuckles off of a 1994 up Dodge 44. I believe they will fit the 30 inner C, with possibly a ball joint change. Then you will get bigger brakes, 5 x 5.5, way bigger unit bearing, and the 297 joint outer stub. Now if you don't have 297 joint inner shafts, you will have to get those, but other than that it should be and easy swap. But finding the parts seems to be a PITA. Every one I have found is far away from me and the JY's want some big bucks for them. You know there are guys out there throwing these out when they upgrade their trucks, I just haven't found them yet.
Just a though anyways, and it would be built with all stock components.
88K5 14b/d60 Self destruct mode switched to on! 97 Xcab Dodge crawler in the works. 77fj40/94fzj80
lumpdog is offline   Reply With Quote
