Grand front axle info needed!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2007, 10:25 AM   #1 (permalink)
Member # 46011
Just toasted the front diff on the wife's '99 Grand cherokee. Basic Dana 30 with 3:73 gears.
When looking for a replacement D30, what axles will go under there? Do I have to find one out of another WJ, or will a ZJ, XJ, TJ D30 bolt in under there?
The outers are good, so theoretically all I need is a center section (inner C to inner C) with 3:73 gears and what not - I'm pretty sure the axleshafts are OK.
Thanks for your help
You have the right to remain silent. Anything you say will be misquoted and used against you.
GPNS-GR8 is offline   Reply With Quote
Old 06-30-2007, 02:38 PM   #2 (permalink)
Member # 81654
If you can find a Rubicon Dana 44 I'm pretty sure it's a bolt in replacement. As long as your's is not IFS (not real sure when they started that). 97-06 wrangler, XJ Cherokee, Grand Cherokee, yadi, yadi you get the drift.
Team Obscene (Office held: Winch Bitch/Beer Can Extractor!!!!) WE SUPPORT TRAIL HEAD
(1st Annual Alpha Gorilla run 40 and under champion)
lockedupLJ is offline   Reply With Quote
Old 06-30-2007, 03:24 PM   #3 (permalink)
Member # 18616
99 grands and up are WJs they have a different lug pattern and there control arm mounts are different, for a direct bolt in you will need another 30 out of a WJ
99xj turboed, 35spline 60's, full hydro, 37 red label krawlers
XJeep633 is offline   Reply With Quote
Old 06-30-2007, 04:17 PM   #4 (permalink)
Member # 46011
Bolt pattern is not a big deal if I can bolt my outers on it. What I'm worried about is the control arm mounts and coil buckets like what XJeep633 said.
Thanks for the info, anybody got a 30 out of a '99 - '04 WJ??
Old 06-30-2007, 07:09 PM   #5 (permalink)
AprilzWarrior's Avatar
Member # 21033
Will need a WJ front end ONLY...
5on5 bolt pattern, and odd sized control arms limit ya...
AW
AprilzWarrior is offline   Reply With Quote
Old 06-30-2007, 07:18 PM   #6 (permalink)
renojeepster's Avatar
Member # 63261
AW
True, and the 99-04 housing is wider.
[FONT="Arial Black"][COLOR="Red"]RALLY POST #82[/COLOR][/FONT]
4.3 CMFI Vortec, SM465, D20 Twinstick, 30spl Chromo'd ARB'd Yota Axles, high pinion front, Trail Readys, 37's
renojeepster is offline   Reply With Quote
Old 06-30-2007, 08:03 PM   #7 (permalink)
Member # 46011
Well. . . That sucks!
Thanks guys!
Anyone know of anyone trying to unload a 99-04 front axle???
Old 07-01-2007, 04:19 AM   #8 (permalink)
Member # 72000
while were on this subject...
im picking up a 93 with a toasted front diff. what will interchange with that? basically,being the older pattern,i can use anything but a 99-04 wj front axle?
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote
Old 07-01-2007, 09:36 AM   #9 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
XJ/TJ/ZJ D30 will work. Look for a high pinion out of an XJ.
ZJim is offline   Reply With Quote
