Help on a lift kit (or not) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-01-2007, 05:48 PM   #1 (permalink)
Member # 94768
I am acquiring a used Cherokee as an extra vehicle to use for some exploring and fly fishing in more remote areas. I need some advice on suspension.
I will not be doing any rock crawling or more extreme four wheeling, mainly just gnarly desert dirt roads and trails getting in to an area. I also need the car to be able to be comfortable on pavement for perhaps 200 miles getting to the area.
Do I need a lift kit?? Would better shocks alone do for my use? If I need/could use a lift, what height do you recommend? I would like to not have to change any major steering pieces by going too high, avoid fender trimming, etc. Does, for example, a 2-3" lift kit gain anything? Can one use stock length shocks with such a 2-3" lift kit?
What do you recommend for my application? Any brands of kit or shocks rate better with you folks? Thanks.
Walter
Tucson AZ
Walter Nash is offline   Reply With Quote Quick reply to this message
Old 07-01-2007, 06:23 PM   #2 (permalink)
Member # 65289
Send a message via AIM to XxStirCrazedxX
well on my 94 (2wd) DD i went for pro comp es9000 shocks, there great for the street and also for dirt roads. got them from Telico (i think it was) For $106 shiped to my door. it was a buy 3 get 1 free deal and they asked if i had a lift and i told them no i didnt, and asked them if it was more expencive if i did and was told no. So i would go ahead and do 2in Coil spacers and shackles in the back.
Coil spacers are cheap $30 shipped to your door and shackles can be easy built from 3/8 steel or bought for $30 if i remember correctly.
Alot of people will probley say that the pro comps = Crap, But they work great for me on the paved roads and even better on dirt roads.
Hope this helps.
[QUOTE=Sturgell;7838459]Hell yes it does. Going balls deep in some chicks bellybutton should be a requirement of all men.[/QUOTE]
I'll stop Web Wheelin' when i get tires!
post 46 in the biggest thread backfire of the year :flipoff2:
XxStirCrazedxX is offline   Reply With Quote Quick reply to this message
Old 07-01-2007, 06:26 PM   #3 (permalink)
Member # 65289
BTW you might want to get Poly Bushings and Greasable bolts for the shackles. the stock one suck on my XJ
Old 07-01-2007, 07:04 PM   #4 (permalink)
Member # 75710
I'd just look for a 2" BB. This lets you run 31's with very slight rubbing on the LCA's. I think you can run stock shocks, you'll just have less uptravel.
rallyemore is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 07:20 AM   #5 (permalink)
Member # 94354
I wouldn't do a damn thing to it. Try it first, and if the ride is really bad, replace the shocks, but I definitely wouldn't lift it.
darwin27 is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 07:23 PM   #6 (permalink)
Member # 94768
Darwin 27: why do you say to not lift it? Thanks.
Walter
Old 07-02-2007, 08:48 PM   #7 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Walter
Tucson AZ
A local...
What year, what axles, what motor, what tranny, what t-case?
Get lockers first if you want to not get stuck.
Id do a jeep speed style build (search jeep speed) that would be ideal for high speed dirt road use.
Id do at least 4.5in lift, all new shocks, you can do a t-case drop and not do the SYE right away. get some 31in ATs and I bet youd be happy with it.
Pirate4x4, is focued more on rockcrawling and more extreme buildups.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
