With my upgrade I'm doing on my Xj currently, I'm installing a rear diff from a Nissan GQ Patrol (diff similar to 9") and going to be using 5.5" RE leaves with extended Terraflex shackles. Now the theory is I will be running 37" - 38" rubber and throwin around the idea of making a custom Anti-wrap bar.
Has anyone done this? I am wondering if it would be possible to run it on one single side off the top of the diff only, ie single bar now a y-link. Thought??
[url]http://www.ausjeepoffroad.com[/url] |
Newbie
i have seen a lot of people runa traction bar(wrap bar) either right next to the leafs or dead center on the diff. i ran my old wrap bar just to the right of the diff and used 2 poly bushing for mountting. then a old johnny joint up at a sub frame bracket i made. so no pics.
check out nth degree i beleave they have a pretty heavy duty set up.
i got a shit box, and i kill people for a living. |
Member # 39292
http://www.naxja.org/forum/showthrea...t=traction+bar
http://www.naxja.org/forum/showthrea...t=traction+bar A couple of ideas from the NAXJA crew. If you search and spend a couple hours reading, you will learn more than you really wanted to know about rear traction.
Got into some reading last night, think considering I am doing diff swap that I will run bigger mounts on the axle tubes for the leaves to mount to and see how that goes first.
From what I have worked out with the wrap bars, unless you do a ladder bar/y llink setup your wasting ya time and if anything actually causeing more problems.
#5 (permalink) | |
Member # 49320
![]() You can get it from Foothill Offroad for $109 Sam's Offroad has 2, one is $199, and a heavy duty one for $299. Last edited by Sierra Drifter; 07-15-2007 at 12:17 AM. |
#7 (permalink) | |
Member # 78387
#10 (permalink) | ||
Member # 43964
A typical ladder bar with a shackle is one option, and its proven to work well. I chose to do the slip and twist version and it works quite well also. It eliminated my axle wrap and it does great as a driveshaft slider. I cut a spiral groove in the inside tube and put a grease zerk on the outside one for "binding issues". Doesn't bind at all from what i can tell and seems pretty smooth. I used bushings at all points and something in the neighborhood of .25" wall tube...
Project (ware)Wolf 93ZJ/5.9L/46RE/NP231/D300/HP60/14bolt/35Creepies PORC-not just a meat, a way of life |
#11 (permalink) | |
Member # 36128
[B][I]"132 and Bush I've got him at gun point, OK gun point, 132 and bush, cover is code 3"[/I][/B] [QUOTE=87manche;10827893]just color it in with a sharpie. [/QUOTE] |
