XJ steerint box - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2007, 08:16 AM   #1 (permalink)
Member # 36385
XJ steerint box
How far are you guys safely moving the front axle forward and still running the XJ steering box. Im looking at a D44 with crossover steering but looks like if I move forward muhc my steering will be all out of whack
Big4x4Rides is offline   Reply With Quote
Old 07-04-2007, 09:33 AM   #2 (permalink)
Member # 37184
If moving the axle forward results in interference with the steering (Pittman arm to tie rod clearance), then you have to reposition the steering box. If you move the steering box (on an XJ), the front cross member will be in the way, and the driver's side frame rail will have to be modified to accept the new location. The frame has an internal crush sleeve/support bracket that is spot welded in place; you would need to move this to the appropriate place.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's.
Bubba_Jeep is offline   Reply With Quote
Old 07-04-2007, 10:24 AM   #3 (permalink)
Member # 89070
Send a message via AIM to theHenz33
i put wrangler leafs in the front of my 89 xj, with the rear spring eye mounted in the stock lower control arm mounting hole on the frame. This moved the axle approx. 4 inches foward, and i had no problems lining everything up. i have high steer arms and everything works well.
theHenz33 is offline   Reply With Quote
Old 07-04-2007, 10:37 AM   #4 (permalink)
1toughxj's Avatar
Member # 50519
Do you have pics of the steering setup on your cherokee with the leafs??
_______________
Ben
2001 XJ
1toughxj is offline   Reply With Quote
Old 07-05-2007, 12:41 PM   #5 (permalink)
Member # 86080
to move the steering box, you'd have to literally cut out the front cross member since the stock steering box location is practically butted up really close already.
Maybe fab up a front bumper with steering box attach points. hehe
djblade311 is offline   Reply With Quote
Old 07-05-2007, 03:13 PM   #6 (permalink)
mjlogan88's Avatar
Member # 23553
this what you're looking for?
mjlogan88 is offline   Reply With Quote
Old 07-05-2007, 07:46 PM   #7 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
Check out the link and pictures of how the steering iset-up in this thead.
/forum/jeep-cherokee/594747-fabbing-upper-control-arms.html
Follow the link in that post for some great tech.
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
