Rear mount rad in a MJ, plumbing? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2007, 12:24 AM   #1 (permalink)
Member # 53453
I've been working on this MJ for a while...
But the current trend with it is to narrow the front clip up and run the rad in the back.
It's something like this right now:
Other than it has an intake/exhaust manifold and a propane mixer on it. And I cut a little more out of the hood in prepration of bending tube.
And I've got this pile on the back of it.
Anyways, figured I'd mount the rad either above the tank, or behind it. That will be the easy part. The nightmare seems to be the plumbing. I've waffled on this quite a bit. I was going to run it through the cab by just laying down two peices of 1.25" exhuast tube in the floor and running some flexible abrasion reistant hot water hose to it. But I'm afraid I will literally cook in the cab during the summer. It's hot already... And I don't want something that I might burn myself on.
And there sure isn't much space below the cab because it is flat-bellied (flush with the bottom of the frame rails) and I've got to fit the exhaust under there too.
So I was thinking about going back to one of my early ideas. That is to run the coolant through my rock sliders and then to the rad. They're 2x2x.188, so they aren't exactly indestructible. However, I doubt I will be able to damage them enough to actually lose coolant pressure.
What bothers me about it is that I'm going to weld the cage to the sliders. So I don't want to compromise their structure by drilling a 1.25" hole in them to weld in a pipe nipple or such. Especially because where I want to tie in the A-pillar hoop is right where I'd need to weld in the nipple...
So, is there any chance I can cut into the rocker panels at the front and rear to run a peice of exhaust tubing through? Or is there a bunch of shit inside them that will hamper me just slipping a pipe in them?
Is there any other obvious routing options I've missed?
Or shoudl I just move the winch to the rear of the truck and find a rad to fit where it is (winch is a POS anyways)?
DirtyComanche is offline   Reply With Quote
Old 07-10-2007, 03:10 AM   #2 (permalink)
Member # 77811
What have you got bolted through the Unibody rail? Can you cut the floor out in the cab and run some tube inside the rail and patch it back in?
86 Ramcharger, 360, 727, 208, 60/14 w/ 4.56 & Detroits, 39.5" TSL
rustrtal is offline   Reply With Quote
Old 07-10-2007, 04:25 AM   #3 (permalink)
Member # 16724
Send a message via MSN to brcook_00
I'm actually considering this idea for my MJ. There's plenty of space inside the frame rail and you could build vibration resistant mounts in, somehow. I would consider making those patches removable in case you ever have to go back into the frame to repair anything.
brcook_00 is offline   Reply With Quote
Old 07-10-2007, 04:25 AM   #4 (permalink)
Member # 19323
you can run it underneath with exhaust tube and flex hose to connect on each end, I did the same on mine. You need to remember to keep it at about the same height as the original for the water pump to work right. Also keep in mind that by adding the extra length of tube and all to connect it that you will end up with about 4 extra gallons of water in there so it will run a whole lot cooler. I had the thermostat go out on mine this last weekend so I pulled it out and the thing ran at about 120 degrees all day long, I could hold my hand on the rad no problem at all all day long
Mud River Motorsports
RCrocs Class 3 Team #304
Fullsizexj is offline   Reply With Quote
Old 07-10-2007, 07:23 AM   #5 (permalink)
magoo117's Avatar
Member # 11963
we are using aluminum tubing running from motor to rad
SPREAD THE VIRUS http://magoosmotorsickles.blogspot.com/ www.cyclesource.com
magoo117 is offline   Reply With Quote
Old 07-10-2007, 07:25 AM   #6 (permalink)
magoo117's Avatar
Member # 11963
also pic of narrowed nose
Old 07-10-2007, 07:33 AM   #7 (permalink)
Member # 95255
Not exactly answering your question, but this may be helpful in the planning and layout. If the pipes go down then back up again, you have to have some way to easily bleed the air out of the motor end. I cut in one of those Prestone garden hose connectors (for flushing) on the top heater hose, outlet from the thermostat. I had to bleed air out periodically for awhile, till all the air in solution worked it's way to the top of the system. You should also connect a loop from the thermostat heater outlet and the water pump inlet (if you remove the heater and heater valve). The circulation/bypass helps the thermostat work better and faster. This can minimize those wild temperature swings as the thermostat opens and closes.
I had to go back and figure out why mine wasn't working well, maybe this will save you some trouble.
I used regular old water pipe in the exposed places (fairly bulletproof), exhaust tubing for the protected areas and universal type rubber radiator hoses for the ends.
I found some hard foam insulation (comes in different sizes and thicknesses) at a refrigeration and plumbing place (and the glue for it), kind of like roll bar padding, to keep down the heat where it was necessary.
I had two fans, a 12 inch pulling and an 18 inch pushing. The 12 inch was fairly low amp, constant on (with the key), the 18 inch was on a switch. I rarely needed the 18 incher.
MudderChuck is offline   Reply With Quote
Old 07-10-2007, 05:46 PM   #8 (permalink)
Member # 43032
I've never tried an 18 incher either...or a 12 incher...pushing or pulling. But it's nice to know you have an open mind. Thats just dirty.
Jury-rig:to rig for temporary service;
Jalopy:a car that is old and unreliable
JuryRigJalopy is offline   Reply With Quote
Old 07-10-2007, 09:47 PM   #9 (permalink)
Member # 95255
You can compensate for lack of diameter by increasing RPM's
Old 07-11-2007, 10:58 AM   #10 (permalink)
Member # 43032
Just make sure that the unit can handle that many RPMs, dont want to burn it up.
Old 07-11-2007, 11:08 AM   #11 (permalink)
Member # 95255
If it bypasses to much air flow, time for a tradein.
Old 07-11-2007, 03:01 PM   #12 (permalink)
Member # 64089
Send a message via AIM to 800MJ
you should be able to route it through the cab without increasing the temp inside. insulation would be fine. and running your motor at 120* all day sounds like a fucking dream
[QUOTE=roastbeef;10323284]last night, this girl was sucking my dick and she stated licking my balls and then she starteld likcing my ass. i almost nuttd right on top of her fucking head before i got to stick it in her.
im drunk.[/QUOTE]
[QUOTE=sucker;10784484]ok straight six and reliable don't go together. But have fun with that one.[/QUOTE]
800MJ is offline   Reply With Quote
Old 07-12-2007, 01:47 PM   #13 (permalink)
Member # 19323
It is true, 120 degree all day Max from Crawl was riding with me and saw it, rad was cold to the touch the whole time, I could lay my hand on it for as long as I wanted without a burn at all
