Transfer Case - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2007, 06:33 PM   #1 (permalink)
wesley_huddleston1's Avatar
Member # 95189
Transfer Case
Just Bought a new transfer case from Mountain Garage to replace the one I broke this weekend it has the hd V8 planetary and wider chain good for up to 3900 ft/lbs of torque. Hopefully i wont break this one. You can get the 231 with slip yoke eliminator for 850 I put his contact info below.
Darin Hutchison
Mountain Garage
434-284-1315
wesley_huddleston1 is offline   Reply With Quote
Old 07-10-2007, 07:37 PM   #2 (permalink)
Member # 53453
Yay 231.
I broke that output with 3 planets and a narrow chain.
DirtyComanche is offline   Reply With Quote
Old 07-11-2007, 09:00 AM   #3 (permalink)
Member # 95189
thats pretty sweet
Old 07-11-2007, 08:44 PM   #4 (permalink)
Member # 36911
not to much help. anybody got anything to ad?
yotaryan82 is offline   Reply With Quote
Old 07-12-2007, 03:00 PM   #5 (permalink)
Member # 89192
I replaced my stock NP242 with a 208 from a 3/4 ton Ford p/u, ran that for a couple years with no complaints - 32 spline outputs front & rear, and lots of beef
Had to "massage" the floor a little to make it fit, and trim a 1/4" off the seal housing around the input shaft - bolts up to the AW4 nicely.
It did hang down a bit low - now running a 231 with the A.A. SYE kit. (had to make room for the Clayton cross member and skid plate)
231 seems to be OK, only running 35's so not a big load on it........but the front output sure is small compaired to the 208
PedalMesh is offline   Reply With Quote
