Member # 84725
Axle swap questions
I have been thinking about swapping in some Rocks under my Ford, so I would have a built 9" and d44 from it to use on somthing. I was wondering how I would mate the larger driveshaft U-joints to the XJ T-case..? ('86 XJ)
This is probably a stupid question, but I do not know the answer, and I have to learn some time.. ![]() Thanks, -Dallas Last edited by homelessduck; 07-11-2007 at 11:46 AM. |
I am doing the same swap right now and I am just going to be making new driveshafts. I have the XJ shafts and Ford shafts so i am just going to just weld the ends to some DOM and a slip yolk. Cut up the old shafts and some DOM. Do a little welding and I should be good to go. If you arent a good welder and dont take your time it can get you frustrated very quickly. Good luck.
I will post up pictures as soon as I do them. I just have to wait for my Box 4 Rocks kit and I will be on my way.
RCrocs/Line Mt. - Route 63 Motorsports #736 Ultra4 #4343 Co-driver - Molten Motorsports |
#3 (permalink) | |
Member # 84725
Yea, I was thinking about doing that as well, since I have a complete parts Ford with driveshafts. I am in no hurry to do this swap, I actually have to wait untill we move into our new house, which should be about 20days. So, Ill just wait and check out your swap and copy what you did. ![]() You should make a build thread for it. ![]() ![]() ![]() -Dallas |
Dont worry the build thread is coming. I want to get most of it done before I start posting though. I just finished the HP44 on monday. I am waiting for a crap load of parts so I dont want to post and then run out of parts. Everything is coming cross country so I am at a stand still right now.
I have to have the thing done by the second week in August for a trail run. And I am moving into a new place too so I have to really start to pick it up.
#5 (permalink) | |
Member # 49320
By the way the 9 inch usually has a non-standard 1330 ujoint with 1 1/8" caps instead of the normal 1330 1 1/16" caps, which makes finding the right conversion ujoint a chanlenge. But you can make one by switching caps on a spicer 5-134x and a 5-1201x..... http://www.jeepforum.com/forum/showthread.php?t=397243 oh yeah, you will need to register as a user (its free) to be able to see the 100+ pictures....
01 XJ D44/D60 ARBs 37's Axle swap thread: [url]http://www.jeepforum.com/forum/showthread.php?t=397243[/url] Last edited by Sierra Drifter; 07-15-2007 at 12:24 AM. |
Member # 63174
I just did it over the weekend. Was a pretty good install however I still have a ton to do like new steering and better brakes. Here's the link to some pics and info. http://www.nc4x4.com/forums/showthread.php?t=27248
#7 (permalink) | |
#8 (permalink) | |
Member # 82644
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE] |
Member # 82644
Mine is the big bearing housing and 3rd. Also nodular 3rd. I just know what fit, don't know why.
Member # 84725
Thanks for the help guys! I have decided to go this route, and I will start as soon as we get moved into our new house. This is of course assuming I dont get side tracked on another project. I think I have ADD..
![]() EDIT: Ah, jeepforum, Im allready a member Sierra.
#13 (permalink) |
Member # 26055
Both 9's I have from Early Bronco's have the same pinion yokes as my cherokee. Which also matches the yoke on the SYE kit. All are 1310's. One less thing to deal with on my swap.
Never kick a turd on day it may be your boss! Uncut 66' U-14 Bronco |
#14 (permalink) |
Member # 50866
well i have a ford 44 in my xj and after breaking front output yokes on the t case i finally swapped to a front dana 44 yoke on the tcase end and bam no more problems. just thought i would throw that in there.... oh and i use all 1310 u joints except at my rear end which is a bastard 1310/1330 joint.
I currently have no rig.
#15 (permalink) | |
Member # 94571
What's the WMS to WMS of your axles and how much backspacing do those rims have? |
#16 (permalink) | |
Member # 63174
My build goes like this: Axles......$400 Tires......$150 (for mock up only, I am getting new ones) Rims......Free 2" dom tubing...$80 1.5" Dom inserted in 2".....Free Had them Machined down and then threaded to accept the Johnny Joints...Also Free by my neighbor Currie Johnny Joints....$40 each Currie nuts and grease able bolts $20 TNT Frame stiffners....$170 Rustys Reaf 6.5" leafs...$300 RC 2" shackles....$50 DS...$200 (tom Woods Rear used, Cherokee front included with the rear) Brake lines and calipers and rear cylinders...$70 Welding done by my buddy.....$600 roughly I gave him free labor and $300 cash Used motor....$200 Things I already had: Rock Krawler 6" front springs....$110 RK Trac Bar and bracket....Free ( it was included in another deal I made) RK Drop Pitman arm....Free ( it was included in another deal I made) AA SYE...Free ( it was included in another deal I made) JKS Quick Disconnects...$25 BDS front Shocks.....$80 Rear Shocks....Free ( I got them off a ford edge pick up. They have a lot of travel) Things I need: Steering linkages Dedenbear knuckles, Front DS shortened E350 master Cylinder, tires. Currently I can drive it. But it's not where I want it to be. Here's pics of the frame stiffners and links. ![]() ![]() ![]() ![]()
