Member # 29713
doubler gearing
I'am putting together my cherokee with a 4.0, aw4, and a np231,dana 300 doubler. the axles I'am putting in have 4.10 gears. for tires i'am running 39.5 iroks.
my question is do i need to change my gear also. or is the gearing with the doubler going to be ok? if i swap out gears i'am going to get 5.38. what do you guys think? |
Pigs Fly
I think you will probably be wanting much better brakes or a different stall converter at that point. You probably won't be able to stop it by brakes alone in full low gear.
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 |
#5 (permalink) | |
Postrunner
Member # 37109
Your axle ratio really depends on wheither you drive to the trail or not. Trail only; 4.10's will work, otherwise your 4.0L needs the 5.38's to climb hills. |
Crazy Diamond
Member # 7595
I could idle over 2' boulders with my 120:1 gearing I used to have while walking next to my XJ. I could stop it, but it would load/extend the suspension causing about 2" of extra lift. Don't stop when you're flexed and tippy because it can cause a roll. Neutral is your friend.
Great spirits have always encountered violent opposition from mediocre minds.” -Albert Einstein
#7 (permalink) | |
Moderator
Member # 10249
I run 5:13s (before 5.38 were available 14 bolt) more to help with my over all gearing but does help take some load off the drive shaft. Id do the 5.38s eventually but maybe it would be wiser spent$$$ on other "trail" needed upgrades.
Dave, 2013 KOH "Got, Some of it", 2014 KOH qualified. #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
#8 (permalink) | |
Member # 43964
I wouldn't want it any slower, its crawls about anything in low/low and is almost useless anywhere but deep in the rocks.. 300 rear output upgrade is a good idea, its the "new" weak link and prone to breaking.. I broke mine in 3 months.. E350 master cylinder and discs on the rear (using stock booster) and I have no problem holding it in low/low..
Project (ware)Wolf 93ZJ/5.9L/46RE/NP231/D300/HP60/14bolt/35Creepies PORC-not just a meat, a way of life |
