home fabed long arms. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-22-2007, 11:41 AM   #1 (permalink)
BlueXJBuddy's Avatar
Member # 93074
Send a message via AIM to BlueXJBuddy
(1) 1/4" thick 2"x5" rectangle 40" long (cross member)$40
(2) 6"x4" angle iron (holds the cross member to the unibody rails) $15 each
(2) 1/4" 1 1/2"x1 1/2" square tubing 32" long (arms) $35
(4) LCA mount tabs free (scrap)
(2) johnny joints $44 each
(2) fixed joints $12 each
(2) rustys adjustable UCAs $150 used
love when that diesel exhaust smell catches up...yum
BlueXJBuddy is offline   Reply With Quote
Old 11-22-2007, 12:10 PM   #2 (permalink)
slowagon's Avatar
Member # 44976
Oh boy! Here we go, Happy Thanksgiving. What did you trim the front fenders with, a honda civic? Your rock rails don't look bad at least.
slowagon is offline   Reply With Quote
Old 11-22-2007, 12:37 PM   #3 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Why would you do that?
'94 XJ RIP, time to move on
New East Coast TTB racer in the works, trimmin' the fat...
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote
Old 11-22-2007, 01:13 PM   #4 (permalink)
Unibody Junkie
[Memphis]'s Avatar
Member # 49281
because booger welding is funner then that bolt on shit!
Driving a 5.3L 4x4 el camino wrapped in tupperware
[Memphis] is offline   Reply With Quote
Old 11-22-2007, 01:28 PM   #5 (permalink)
Member # 86685
deathtrap
the front fenders look like they were cut with an axe
s10er8 is offline   Reply With Quote
Old 11-22-2007, 01:43 PM   #6 (permalink)
Banned
Member # 83025
Originally Posted by s10er8 View Post
deathtrap
hahaha
not to mention the UCA's are attached to the stock mounts.
you think he is friends with this guy??
rehab is offline   Reply With Quote
Old 11-22-2007, 02:02 PM   #7 (permalink)
Member # 86685
I shouldnt be making jokes, you should see my fabrications skillz
Old 11-22-2007, 04:10 PM   #8 (permalink)
Member # 77718
PSSSSSSST You forgot to put the shocks back on......
'89 B2 with slight modifications
[QUOTE=AZFord4x4;8084876] I really shouldn't download so much porn while I'm trying to ban people.[/QUOTE]
IROK Cherokee is offline   Reply With Quote
Old 11-22-2007, 06:36 PM   #9 (permalink)
Member # 25117
Holy loss of ground clearance Batman! I wonder if the driveshaft will clear the lower mount when the driver side droops out saying the change in the pinion doesnt blow the shaft up first.
AARON
91 MJ truggyfied, Custom Suspension and Axles on 35s
MrShoeBoy is offline   Reply With Quote
Old 11-22-2007, 06:46 PM   #10 (permalink)
Member # 86685
He only lost 12" of clearance, he still has 6 more inches to go
Old 11-22-2007, 06:50 PM   #11 (permalink)
Supporting PBB
BlackSkies7's Avatar
Member # 31931
California's roads just got a bit more dangerous.
Somewhere out there is America, then there is New York...
CJ2a- 360... caged.. axles etc...
BlackSkies7 is offline   Reply With Quote
Old 11-22-2007, 10:03 PM   #12 (permalink)
Member # 93074
actually i was chewing up the tires w/ only 2" blocks on a trail so a guy w/ a cut-off wheel let me have at.
i didnt forget i just didnt have extra steel to make shock brackets. it was a fun drive home.
its just progress i still have more work to do. becuase i wont be wheeling any time soon i just need 2 b able 2 drive it on the street.
the upper control arms will b welded onto the lowers sometime soon.
Old 11-22-2007, 10:09 PM   #13 (permalink)
slowagon's Avatar
Member # 44976
All I can say is try and stay away from the fairfield and vacaville area 'cause when it goes I don't want my family around it.
Old 11-22-2007, 11:21 PM   #14 (permalink)
Goatman's Avatar
Member # 25239
You just decreased the trail capabilty of your XJ by the massive decrease in ground clearance. A lot of work for nothing. You'd have been better off with drop brackets.
It is very difficult to design and build a long arm set up for an XJ that really works, and not that many have been able to do it. Many XJ long arm setups are useless. Getting hung up on a rock or berm is what stops you on a trail most often, so a considerable loss of ground clearance in order to get a better ride on the street is senseless. Design it with the mounting points tucked up inside the frame and now you're talking.
Richard Gauthier
Ultra4 Stock Class Team NAXJA /Petty Cash Racing 4643
Thanks to NAXJA, Goodyear, BILSTEIN, Ten Factory, Brown Dog, Hooker Harness, Raceline Wheels, G&G Auto Repair, WARN, Yukon Gear and Axle, Solid Axle, JKS, Full Traction, Viking Winchline, Black Magic Brakes
Goatman is offline   Reply With Quote
Old 11-22-2007, 11:25 PM   #15 (permalink)
Member # 65506
I just laughed so hard I cried.
P.S. You might want to leave those LCA mounts there for when you get tired of being laughed at
''somebody get captain canada a chocolate chip canookie...'' -- Flatline's Up!
newman98XJ is offline   Reply With Quote
Old 11-23-2007, 07:28 AM   #16 (permalink)
Stands to wipe.
Member # 81266
BB1980 is offline   Reply With Quote
Old 11-23-2007, 07:32 AM   #17 (permalink)
Member # 92522
What loss of ground clearance? From the crossmember?
jeeperanthony is offline   Reply With Quote
Old 11-23-2007, 09:32 AM   #18 (permalink)
Goatman's Avatar
Member # 25239
Yes. Also, since the crossmember is low, the arms are also lower and can get hung up. They don't always slide nicely down the rocks.
Modifications should always be to get better performance....not just to do them.
Richard Gauthier
Old 11-23-2007, 10:52 AM   #19 (permalink)
Stands to wipe.
Member # 81266
