Member # 81931
8.8 or 44
I am going to run 36x13.5 irocs in my cherokee. what axle would be stronger dand 44 or ford 8.8. im going to get chromoly shafts and be locked up. which one could I build for cheaper. let me know what you guys think... thanks
Member # 86685
I see the prices of 8.8 r&p's dropping. but then you have the issue of c-clip vs semi-float
run an 8.8 on stock shafts, they are supposedly as strong as alloy 44 shafts. I know they are fairly heavy shafts |
Member # 57166
8.8 disk brake all the way, they can be had for 300 bucks from the junk yard with 4:10's and they are comparable to a 9"... much stronger than the 44. also, with the disk break, you won't have ot worry about the c-clip as the disk brakes will hold the axle in till you get off the trail
87 pathfinder HPD44 wristed radius arm, yukons, super joints, detroit True hi9 spooled 4 link 5.38's WH variable rate coils on all 4. |
Swag Sales
Member # 90594
I was going to use a 8.8 but my jeep is no longer a daily driver so im going with one tons. I did alot of research and the 8.8 has disk brakes, bigger axle shafts, bigger tubes, and a bigger ring and pinoin. (8.8 vs 8.5) Randy's Ring and pinion rates the 44 at a 33 inch tire while the 8.8 is rated for a 35 inch tire. I have read about many people that run bigger than 35's on an 8.8 and have no troubles. Its all about the research! You also get to keep your 5x4.5" bolt pattern. It was a clear choice for me. As for price(i dont know if i can do this on here) i have on ill sell for $175. The salvage yard by me wants $310 for them. It has 3.73 gears with a limited slip and disk brakes) PM me if you want it.
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! Last edited by dozer_xj; 05-05-2008 at 08:34 PM. |
Member # 99982
I have both in my yard and im goin 8.8, disks, larger shafts, yada yada yada. Im also doing the super 8.8 kit just to get rid of the c clips and widen the axle a lil bit. I say 8.8 easier to find, usually cheaper and you can find some with 4.10 gears. Oh yeah and search they're some guys on here runnin 38's on the 8.8, thats what im goin to run BTW.
90'YJ 258 1tons np435 d300 |
Swag Sales
Member # 90594
I dont promise you wont break something but you will be better off with the 8.8 than the 44.
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! |
Member # 57166
my buddy runs 38.5s with a 360 on an 8.8.. 2 shafts in 3 years..
Member # 88127
I don't understand the whole 8.8 thing. It's cheap, "stronger than a D44", 4.5" bolt pattern and works for 35"-38" tires. What are ya'll using for a front axle? Dana 30 I would think. So now you have this end all beat all rear axle and are stuck with a D30 front. Don't tell me you are going to run 36" Irok with a "heavy right foot" and are more concerned about the rear axle. I just don't understand.
'92 XJ with add-ons Tellico #625 |
#11 (permalink) | |
Member # 39045
Anthony |
#12 (permalink) | |
Probably because lots of people who are looking into the 8.8 swap are running D35 rear ends. |
#13 (permalink) |
Member # 25117
If you have a heavy right foot and bigger tires, look into a Ford 9". I blew up the ARB and ring and pinion in my F8.8 last year in my XJ with a very strong 4.6L stroker, 5 speed manual, 35s and no fear of the throttle. The cost of new gears and a locker for the 8.8 was a few hundred dollars more than what it cost me to build a 9" with alloy shafts. I think I have $600 in the axle, factory N case, 4.10s, spool, narrow'd with custom alloy shafts, and disk brakes.
AARON
91 MJ truggyfied, Custom Suspension and Axles on 35s |
#16 (permalink) |
Member # 25117
Hasnt been any more of a problem than the lip on the bottom of the F8.8. I cant remember who makes it off the top of my head but there is a pinion yoke guard for the 9" that works very well and bolts on.
AARON
91 MJ truggyfied, Custom Suspension and Axles on 35s Last edited by MrShoeBoy; 05-11-2008 at 03:36 PM. |
#17 (permalink) | |
Member # 14600
Just a redneck trapped in a brown man's body |
#19 (permalink) |
SnivelRightsViolator
Member # 82394
Heres the one I run!
It looks like the same product for less $$$ http://www.fourtreks.com/yoke_guard.html Last edited by BerzerCO; 05-11-2008 at 05:04 PM. |
#23 (permalink) | |
Member # 14600
Just a redneck trapped in a brown man's body Last edited by Oatmeal; 05-11-2008 at 09:14 PM. |
#24 (permalink) |
Member # 3191
I don't like the 8.8. Tubes tend to spin in the housing. It is C-clip, so there is the obvoius issue if you break an axle. Additionally, the C-clip makes the ARB design weak. If you plan to run an ARB, don't run the 8.8. You can build a Ford 9" pretty cheap. Much better for a heavy foot.
