TOTM: Unibody gas tank relocation - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2012, 09:39 AM   #101 (permalink)
Member # 132938
Originally Posted by xj9140 View Post
Since you are already getting parts from summit, you better get a flame sute and extinguisher as well
i bought my flame suit the day i joined pirate
i think this is the pump i will be using
http://www.summitracing.com/parts/SUM-G3138/
SheetMetalSlug is offline   Reply With Quote
Old 04-16-2012, 11:19 AM   #102 (permalink)
TabooCustoms's Avatar
Member # 105073
Ive thought about running the stock pump externally. Bought a E2000 pump off ebay already though. For shits and giggles Im thinking Im going to mount both next to each other and run the stock one on a 2 day run coming up. If it lives through that Ill be suprised. If it doesnt oh well, was just going to add to the clutter in the shop.
www.taboocustoms.com
Team TABOO 2012 RRock
Thanks to:
LOCTITE
Tom Wood's Custom Drive Shafts
Central Welding Supply
Koenig Machine & Welding
Delta Tire & Yokohama
H&B Quality Tooling
Aire Serv of Quincy
TabooCustoms is offline   Reply With Quote
Old 04-16-2012, 11:24 PM   #103 (permalink)
Member # 46112
Just recently moved my stock tank up. Very easy and very effective.
relocated the stock filler
built a crossmember that attaches to the rigidco bumper bracket
built a skid for it
97XJ tru hi 9, locked, caged, 36s
savethehammers . org
RuggedJeep is offline   Reply With Quote
Old 04-19-2012, 11:43 AM   #104 (permalink)
Member # 153054
Sessy
DeftwillP is offline   Reply With Quote
Old 04-19-2012, 12:28 PM   #105 (permalink)
xo_jeep's Avatar
Member # 112255
WTF man. Now I gotta step up my gas tank game
Very nice work. Probably the best, cleanest relocation I've seen.
Boom goes the dynamite
xo_jeep is offline   Reply With Quote
Old 05-29-2012, 06:00 PM   #106 (permalink)
jeepnatv4life's Avatar
Member # 132985
3/16 plate with holes for the hitch/bumper mount
2x2 risers
should have bought 3 inch l channel for the trim.
AND TO THOSE CUTTING YOUR OWN UP........CUT IN TOWARDS THE CENTER FROMT THE PINCH SEAM and CUT N FOLD LIKE A FENDER!!!! dont make my mistakke of cutting flush with the frame edge
99 XJ 4" and 35's locked f/r
TEAM ADAM #4467
jeepnatv4life is offline   Reply With Quote
Old 08-24-2012, 01:51 PM   #107 (permalink)
Member # 189683
built a skid for it
super clean relocate! love the skid.
Byron XSPower Batteries
4xspower.com 888.497.7693 Ext. 1213
Byron@XSPower is offline   Reply With Quote
Old 08-24-2012, 05:38 PM   #108 (permalink)
Member # 132985
my go at it
risers
finished
TEAM ADAM #4467
Old 09-07-2012, 06:51 AM   #109 (permalink)
Member # 184176
Ive been having troubles with fumes in the cab.
I have a vent line on the filler neck and on top of the cell and they are both in my cab and I was looking to move them.
My question is if I run them out the side below the cell am I gonna throw gas out of it all the time?
I was also thinking of putting some filters on the end of them and mounting them out of the ceiling.
Ill post pics tomorrow for some vent tube tech.
FUCK I DONT KNOW!
[SIZE="4"][COLOR="Red"]Id rather go fishing for a day than to have crabs for a life.[/COLOR][/SIZE]
frankensteinxj is offline   Reply With Quote
Old 09-07-2012, 07:40 AM   #110 (permalink)
moparmaniaccuda's Avatar
Member # 121563
Assuming you've reconnected the factory vents on top of the tank?
I never had an issue with fumes in mine unless I had literally just topped it off.
moparmaniaccuda is offline   Reply With Quote
Old 09-07-2012, 07:44 AM   #111 (permalink)
Member # 184176
Sorry forgot to mention Im using a sami plastic fuel tank.
here is the tank Im using will post exact pics of my setup when Im off work.
Old 09-26-2012, 07:01 AM   #112 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
4 walbro pickups used 3/8in copper tube compression fitting Teed to 1/2in copper tube, Teed to the 5/8in rubber pickup cut down. I also swapped out the return line fitting for a hard line that goes to the bottom of the tank. The return line is epoxied to the copper hard line so it cant hop around.
The pickup bult head fitting is -10AN 5/8in hose going to the 100u pre filter, short section of -8an 1/in hose from the prefilter to the pump inlet, the pump outlet is -8an 1/2in hose to the regulator, the regulator uses -6an 3/8in high pressure line through the post filter 10u to the fuel rail. Return line from regulator is -8 1/2in and the fuel cell vent is -8AN 1/2in hose with an air filter on it. All three lines coming off the fuel cell have ball valve shutoffs.
The external pump is a Walbro GSL392, 60 PSI 255 liter per hour pump. It has a built in check valve that holds about 20 psi. It is virtually silent. This pump has a small 10mm inlet. I bought the -8AN to 10mm adapter from summit but I modified it to have a larger ID hole to reduce cavitation.
I replaced all tank Teflon bulk fitting washers with stat-o-seals. And used polysulfide two part epoxy to glue and seal all bulk head fittings.
ashmanjeepXJ is offline   Reply With Quote
Old 09-26-2012, 08:52 AM   #113 (permalink)
6,000lb diesel ZJ
Black sheep fabworx's Avatar
Member # 215954
Cool
I did mine flat with the bottom of the frame so its half in half out. I ran some braces under the tank for it to sit on, and relocated my straps up top. The way I did it, the strap goes in its existing hole, and the studs are welded to the shock structure. I'm tieing it all into my shock structure, and I'm gonna add plate on top so I still have room for cargo. It's not finished yet, because I still need to make the hole bigger for my diesel tank. Pix aren't great, but its all I have left. The great computer crash wiped out most of my pix, and all I have is what I put on Photobucket.
Don't let my new join date/post count fool you, Iv been a member for10 years!
Those who say it can not be done should not interrupt me when Im doing it!
Black sheep fabworx is offline   Reply With Quote
