4.0 A/C Delete - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-06-2009, 09:38 PM   #1 (permalink)
Member # 78841
4.0 A/C Delete
I've got a 1990 4.0 in my CJ7 and the A/C compressor just seized up on me. Anyone know if there is an A/C delete pulley that can bolt in its place ore do I have to try and make something?
All help greatly appreciated.
-Bill
-Bill
billyballer is offline   Reply With Quote Quick reply to this message
Old 01-06-2009, 09:58 PM   #2 (permalink)
GreatWhiteXJ's Avatar
Member # 103442
Send a message via AIM to GreatWhiteXJ
Not all 4.0's came with a/c option. So just get a belt for a 4.0 w/o air conditioning.
XJ Buggy, 60/14, 42's, doubler, etc. RoXJoX President
GreatWhiteXJ is online now   Reply With Quote Quick reply to this message
Old 01-06-2009, 10:07 PM   #3 (permalink)
Member # 47380
Theres a pulley you can buy at most parts store.I got mine at napa. Its just a pulley with a mount thats bolts to the old compressor bolt holes.
:flipoff2:
oakesters is offline   Reply With Quote Quick reply to this message
Old 01-06-2009, 10:16 PM   #4 (permalink)
Member # 103442
Why by a part you dont need? Just buy a belt....trust me. Done it, works great.
Old 01-06-2009, 10:19 PM   #5 (permalink)
Member # 59753
Exactly just look at the serpintine belt sticker, under your hood.
[QUOTE=ChevyGal;9752200]I personally think it's cool Janet Reno likes to wheel. :)[/QUOTE]
Alfred W. is offline   Reply With Quote Quick reply to this message
Old 01-06-2009, 10:58 PM   #6 (permalink)
Member # 103610
Send a message via AIM to jeep937
Yea just get the belt for a jeep w/o AC. Gives a little more power too. Hey, I felt it.
jeep937 is offline   Reply With Quote Quick reply to this message
Old 01-06-2009, 11:02 PM   #7 (permalink)
Member # 102365
its a great time to turn that a/c condensr into a trany cooler too
MOLON LABE
urbanmuddboger is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 12:07 AM   #8 (permalink)
Member # 103442
Or swap in a working one and turn it into onboard air....both good options.
Old 01-07-2009, 05:21 AM   #9 (permalink)
dcherill's Avatar
Member # 101138
there is a specific bracket with 4 vertical holes for the compressor that you can mount a york on using a small bracket from Kilby. pictures of this bracket are on his site. that is what is going in my AC compressor's spot
dcherill is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 06:10 AM   #10 (permalink)
Member # 19323
You can't always just throw a shorter belt on, you have to make sure that if you do that it will still be turning everything in the right direction, they way they route them has the belt turning things in different directions and if you just skip one it can change the way others turn, check and make sure before you do it, they also make an ac delete bracket that will mount up instead of the ac compressor to keep things how they are supposed to be also
Mud River Motorsports
RCrocs Class 3 Team #304
Fullsizexj is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 12:03 PM   #11 (permalink)
Member # 78841
Thank's for all the replies. I never had the A/C hooked up to begin with so I'll just grab a A/C delete belt. I should mention that the early Renix style 4.0's have a different AC pump that mounts with two bolts run front to back, not 4 bolts running top to bottom like the later 4 liters, so for a A/C bypass pulley to work (or the Kilbey kits I've seen) you would have to update the bracket ( I already grabbed one from pick n pull in case I do OBA down the road). Also for future reference, all the major parts places only list the non-A/C belts for 1994 and up Cherokee's, anything earlier than that doesn't have the without A/C option according to them (Napa, Kragen etc.)
Thanks again guys
-Bill
-Bill
Old 01-07-2009, 12:04 PM   #12 (permalink)
Member # 78841
Also for Reference here is a link to the belt routing diagram, shows both with and without A/C.
http://i30.photobucket.com/albums/c3...s/PB250013.jpg
-Bill
-Bill
Old 01-07-2009, 07:40 PM   #13 (permalink)
88flexj's Avatar
Member # 56895
-Bill
Does that picture look funny to anyone else?? Maybe I have had a couple too many beers but that doesnt look like my 4.0 layout ac or not.
[COLOR="darkorange"][/COLOR]Santa Cruz 4 Wheel Drive Club
88flexj is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 09:44 PM   #14 (permalink)
Member # 85666
Send a message via AIM to Fraser
what would the part # be for the delete bracket? for the later 4- vertical bolt compressor
Fraser is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 11:52 PM   #15 (permalink)
Member # 78841
88exo and others. I just discovered that there were multiple routings for different years of the 4.0. I also discovered (through trial and error) that the short A/C delete belt for '94 and up cherokees does not fit early models. The routing directions on the back of the belt showed about four different configurations for the 4.0.
-Bill
Old 01-08-2009, 06:08 AM   #16 (permalink)
Member # 123283
A/c air
I know that the old york A/C compressors are the most popular does anyone know if those will bolt up to the 4 liter. Or does someone make a kit to bolt it straight up. Is there another compressor that will work, as in bolt straight up and work as on board air? all helpful input would be great Thank!
BIGDADDYJK is offline   Reply With Quote Quick reply to this message
Old 01-09-2009, 12:46 AM   #17 (permalink)
Blaine B.'s Avatar
Member # 120665
Send a message via AIM to Blaine B. Send a message via MSN to Blaine B. Send a message via Yahoo to Blaine B.
This must be for the GM V6 motor (or the 2.5 4 cyl?)
Definitely not for any 4.0, renix, OBD1, or 96+ OBD2 style routing configurations.
Blaine B. is offline   Reply With Quote Quick reply to this message
