Member # 132629
I over reamed my knuckle for 1 tons :[
Hey guys, this is actually my first post on Pirate some of you may know me from NEJz. My issue today is that I over reamed my driver side knuckle when installing my JCR steering. I could still use the DRE es2027L if it had a right hand thread. Does anyone know where I can find one preferably tomorrow? I'm sure that there is a shorter DRE out there if you know of one please share I'm pretty disparate here I don't feel like swapping the knuckle and need to tow something with my jeep Saturday.
Member # 132629
That's a good idea but I don't think I could get it right the first try though. I have a 140A mig and I use flux core wire, could it be done that way. I don't know much about welding cast, I have welded a caliper bracket ear onto a knuckle before with good results and I know the pre heat post heat deal but that's about it. How could I go about this with my welder? I do have a gs kit and wire but no tank.
#4 (permalink) | |
Pre-heat knuckle to as hot as you can get it. If you dont have a torch...a barbeque grill or pit works nicely. Then fill it with Stainless wire. Home Depot or Lowes carries 1lb spools for like $14. Once you get it filled, toss it back in the BBQ or apply heat again. Make sure it cools slowly , otherwise the plug will seperate from the knuckle. Sand retains heat well, fire blankets, a bunch of coats or blankets will work too. Just make sure the heat is retained and the weld cools slowly.
XJ on 42's Last edited by GreatWhiteXJ; 03-27-2009 at 09:32 AM. |
Member # 97798
Dean, you should come to the grab day, and just get a knuckle. Or if you like, I have a spare XJ that you can pull a knuckle off of.
About welding the knuckle, I do not know what the material is. My D60 is iron, and if this is the case, its just easier for you to get a new one.
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 5.38s, full hydro newenglandjeepz.org |
#6 (permalink) | |
Moderator
Member # 10249
I dont like the 2027 and 2026 on a tierod they get loose quicker then the lower miss alignment ones, and if you have 1.5in 250 DOM tube the rod end will bend before the tube. I wanted over the knucle steering on my d60 (mounting top down not bottom up)...so I welded up the hold with my 135A hobart, I drilled the weld using a masonry 5/8in carbide tipped drill then I ream them from the top. It was a ridiculous PITA to try and drill through my weld, then to ream it. I think i put a full 8hrs into it.
Dave, 2013 KOH "Got, Some of it" #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
Member # 132629
Don't I need a sheilding gas for SS wire, if so what gas?
Hopefully tomorrow I'll get a new knuckle at the jy unfortunaty I need to tow my trailer there with my jeep. I was also thinking about using a hemi temporarily, does anyone know of a retailer so I could get one today? I'm near Boston. |
Gas will depend on wire. You can get flux cored stainless wire though and have no need for gas. However stainless is commonly welded with a 3 way combination of Helium, argon and CO2.
XJ on 42's Last edited by GreatWhiteXJ; 03-27-2009 at 09:55 AM. |
Swag Sales
Member # 90594
Why dont you get a 2026 (I belive that is the part number) which is the same thing but right handed thread. Thats what I used on my jeep (2027 and 2026) for steering. The local autoparts store had them in stock. Good luck
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! Last edited by dozer_xj; 03-27-2009 at 11:22 AM. |
Member # 132629
The ea2026r is too long my tie rod is ore made... I could cut it down and retap it but I dont have the tap.
I picked up a tank of Co2 argon sheilding gas today at lunch and I have a roll of er70s-6 wire and an acetyline torch I use for brazing pipe will that be sufficent? |
Member # 89479
swapping the knuckle is going to be a whole lot easier than welding that thing up and drilling it out. Just go get a knuckle at the JY, and besides, you probably need to redo you balljoints anyway.
#12 (permalink) | |
Member # 117427
it will cool very slowly this way. |
#13 (permalink) | ||
XJ on 42's |
#16 (permalink) | |
Pigs Fly
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 |
#18 (permalink) |
Member # 132629
I welded up the knuckle on Friday night and it came out great! I was really surprised at what a difference the L-56 wire made with the shielding gas. I
Ruined probably a half a dozen drill bits of various sizes and a $75 reamer but it was worth it just for the experience. On Saturday I picked up a 97 8.25 for $60 so I'll probably weld the tubes up on that and put one piece axles in the front that I got out of a late model zj for less than $30. Then all I have to do is put in my sye np242 and 23 spline aw4 and I'll be ready to hit the trails... Sort of. |
