any way to fit 35" on a XJ with no lift?
Well, i found an Xj, and am going to go look at it. only thing is that it is stock, and i will be broke after buying it. BUt i do have some 35" mt/r's on 15x8's on my dodge that i can use when i wheel it. This is a 4 door cherokee. Now is it possiable to cut the hell out of it and make it fit without doing anything else, or will i need to move the rear axle back so it doesent hit the door. Will it work?
thanks Garrett |
Possibly in the front if you add huge bumpstops and cut the shit out of the fenders and add rims w/ like 3" of backspacing. But in the rear. You could cut out the entire fender well and cut the body, but since this is a unibody rig, you will be compromising strength by cutting to far as the body seem opens up if you cut more than like an inch in a half. If you have the skills to weld in an entire new fenderwell and close up the seem in the body, then sure.
currently rigless and working on doctorate in Mechanical Engineering |
Member # 792
Check the tech section at www.SawzallAndCaseOfBeer.com
01 TJ |
#6 (permalink) | |
Moderator
Member # 10249
Re: any way to fit 35" on a XJ with no lift?
Cherokee is 5-4.5 rims wont fit!! Id do 4in of Bs or less for the 35s to preven rubbing on lower control arm. you will need to cut and reweld the body as described above. I drove my friends xj around the block, no lift no trimming with 32s, add bumpstops, trim or remove all possable metal, and take pics to show us. it would be sweet!!!!!! with 35s youll also need to regear the 3.55 gears youll probibly have will suck, so with those gears, the 35s might be a performance down-grade but I say do it....
Dave, 2013 KOH "Got, Some of it" #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
#7 (permalink) | |
Member # 11588
That would be one SWEET site!!! Somebody should do it.
Never own anything you're not prepared to drill a hole in. |
#9 (permalink) | |
Member # 11598
Re: Re: any way to fit 35" on a XJ with no lift?
This space for rent. |
Member # 8540
anything is possible, i dont think it would be easy to relocate any necessitys on the front inner fender(if you trim that far up) you would be cutting mucho mucho metal away and ruining it's integrity, if you trim to fit 35's in the rear i am pretty sure that your tires will be in the cab with you , but hey if it is just a trail rig.....chop the whole thing to pieces
Member # 8883
If you have access to a welder and some metal, then I would fab up some of your own ACOS. A buddy is doing this for a cherokee right now. It is still in the works, but I will let you know how it turns out. Trim a whole lotta metal from the fenders, and reweld the pinch seams and molded supports. Wheel it! You will still sit fairly low at the rockers, but on XJ's things are tucked away fairly well. Let us know how things turn out.
#13 (permalink) |
Member # 5639
edited: looks like you got it figured out.
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. Last edited by Weasel; 09-05-2002 at 07:34 AM. |
#14 (permalink) |
Member # 2125
sure its possible, I just cut a stock xj to fit 33 ssr's on 10" wheels, at full stuff the front tires only hit the fire wall when turned, but nothing else, so add some bumps stops and the front may work. the rear on the other hand, you'll have to cut the wheel well completly out and build a bigger one, with the edge of the wheel well at the door, good luck.
#15 (permalink) |
Hmm, well, this cherokee has a factory d44. and the tires are off of my 77 dodge... and in the 70's dodges had 5 on 4.5, not the 96 with has 5 on 5.5.. both of those truck have 3.55 gears.. 77 with the 35", and the 96 with 33". SO i know what 3.55 gears and big tires fell like, but with an auto, it is OK (just never take it out of low range). I have also been lookin into just getting a teraflex 1.5" budget lift kit, and cutting like a mad man, and i can only admagine what the COG woudl be like.. i think it would kick major ass. And yes, the metal shop (south bay metal) is about 10 min from my house, and i have a nice welder (thought a little big at 315 amps
) that will weld up the metal if i am careful and quick. Hopefully i can go look at the cherokee in a couple of days to see how it looks to do... just weld up the rear and i woudl be set for almost any trial around... maybe rock sliders too... Garrett |
#20 (permalink) | |
I would love to see it. Damn thats a lot of cutting!
1988 RattleCan Primer Green XJ 4.5" Tomken/Custom Lift 33x12.50 Geolander MT's on 15x8 AR767's. If I had money for groceries, Id get em in this. |
#23 (permalink) |
Moderator
Member # 10249
I like the "Hero"
My "cherokee" fell off so I think the "F350 pioneer" will suit it well.
#25 (permalink) | |
Moderator
Member # 10249
It will be nice to see when you get the rear done.
