cutting down a dana 44 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2009, 11:55 AM   #1 (permalink)
shagy9888's Avatar
Member # 123028
am thinking about cutting down a dana 44 for my XJ. i could get a 1979 Ford dana 44 but i think its got the 1/4" walls on it and if am going to spend the time in doing it i think i would want the 3/8". so i want to know if i could buy (if i could buy at all) the 3/8" the put the in the houseing and the knucks. or would should i just find a 1977 dana 44 with the 3/8"??
where can i buy the tubes at??
shagy9888 is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 12:07 PM   #2 (permalink)
BrassMunkey4's Avatar
Member # 35581
thats way to much time and $$ into a dana 44
Making vroom noises from my keyboard.
-Scott
Miller Motorsports #9
BrassMunkey4 is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 12:27 PM   #3 (permalink)
WA-HCRC's Avatar
Member # 39184
This is a NEWBIE questions. but ill give you an answer.
Find an F-250 housing from the same era. 1/2" tubes, No cast shit all over it. the f-150 axles IMO are more trouble then they are worth. hell, a dana 44 swap is too. Tiny u joints, shafts, spindles, etc.
WA-HCRC is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 12:30 PM   #4 (permalink)
shagy9888's Avatar
Member # 123028
well thanx for answering my new be ??? very helpful and everyone got to start as newbees so thanx for answering it
Old 08-05-2009, 12:53 PM   #5 (permalink)
the freeak's Avatar
Member # 41185
there is a thread on Jeepin.net dedicated to this very topic.
Since I am feeling generous: http://www.jeepin.net/forum/showthread.php?t=38909
the freeak is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 01:59 PM   #6 (permalink)
Member # 25377
The tubes from my '75 F100 D44 were 1/2" thick.
Billy
Follow my build-up at
JeepFreak21 is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 02:30 PM   #7 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
They were never 1/4"
They should be 3/8 if from a coil spring truck.
They should be 1/2 if from a leaf spring truck.
Any good machine shop local to you should be able to order the tubing.
Dana 60 or 14 bolt disk brake kits $315 shipped -->
Dana 70 kits $300 -->
. . Sterling 10.25 kits $390 -->
Dana 60 front 3/4 ton kits $295-->
GubNi is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 03:45 PM   #8 (permalink)
Member # 25377
Oh, and mine was coil sprung
Billy
Billy
Old 08-05-2009, 05:04 PM   #9 (permalink)
shagy9888's Avatar
Member # 123028
[QUOTE=RCman;8221713]Mr. N did a great job writing up some D44 info on swaps:
Part1
Part2
Part3
this is where i found everything
Old 08-06-2009, 04:01 PM   #10 (permalink)
Member # 29071
Send a message via AIM to Starboard M
I thought the 78+ axles were 1/4'' while the pre78 were 1/2''.
Mine came out of a 74 F100 and it has 1/2'' tubes.
Starboard M is online now   Reply With Quote Quick reply to this message
Old 02-03-2010, 05:27 PM   #11 (permalink)
shagy9888's Avatar
Member # 123028
ok boys and girls got myself a 1977 Ford Dana 44 now got to find out how to cut it down to fit under my XJ. more search for me any one want to help
Old 02-03-2010, 05:32 PM   #12 (permalink)
WA-HCRC's Avatar
Member # 39184
ok. now this really doesnt belong here.
search search search. google search. leave pirate.
dont come back
Cut the tubes how short you want. cut the welds were the c's are held on. knock the c's off. put them back on in the correct orientation, weld them on. real easy. dont need an alignment bar or nothing. set castor, bing bang bong.
Old 02-03-2010, 06:32 PM   #13 (permalink)
Member # 40082
SO old its on JeepsUnlimited even :O
http://jeepsunlimited.com/forums/sho...d.php?t=392180
Dennis
If you soaked up all you can... get a new sponge cause theres more to learn!
SHNIPE is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 07:12 PM   #14 (permalink)
shagy9888's Avatar
Member # 123028
thanx alot i knew there was some nice ppl on pirate
Old 02-03-2010, 08:47 PM   #15 (permalink)
Member # 18531
and if you lived closer..... i would have came over, cut it down and all for ya.
and installed in my rig
[QUOTE=weedwacker;9581606]It ain't perfect but it works well if lubed. [/QUOTE]
PornstaR is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 03:33 PM   #16 (permalink)
Member # 25117
For the time and money you will spend on the D44 you can have a stock 60. A few hundred more you can have a narrowed 60. I did the D44 thing and its working for me but I secretly wish I had gone with a 60 up front. WNC Custom Jeeps used to be up in your area and I know they used to do axle work.
AARON
91 MJ truggyfied, Custom Suspension and Axles on 35s
MrShoeBoy is offline   Reply With Quote Quick reply to this message
