TOTM: Panhard Bars (Trackbar) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2010, 11:53 AM   #1 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Welcome to the next contribution to the
The Official Pirate4x4.com Jeep Talk Bible
Topic of the Month Panhard BArs
This includes Panhard bars upgrades also known as Trackbars, frame and axle mounts, rod end types, length, link material, angle with respect to the steering drag link, this is for fabrication typically needed for axle swap upgrades and high steer upgrades
This does not include other suspension links or steering links. This does not include bolt on kits.
A panhard bar is the horizontal suspension link that locates the axle left to right. The factory suspension 5link uses two upper control arms, two lower control arms and the Panhard bar. It is important to make the panhard bar parallel with the drag link or you will have bump steer. Secondly the panhard bar should be close to the same length as the draglink to prevent bump steer.
A steep angle on the panhard bar and drag link is not desirable, Competition Rockcrawlers typically have negative angle on the panhard bar for added stability.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 12:16 PM   #2 (permalink)
Member # 84970
Send a message via AIM to Xjcrawler736
I do not have pictures here at work, but my trackbar is made from 7/8" chromo Hiems from Ruff Stuff. 1.75" OD 1.25" ID DOM.
Frame and axle mount is all 1/4" steel. Frame mount was welded to the unibody because it would flex regardless of of tight the 4 bolts were. Since welding I have had no problems with any of it. Even with a week of thrashing at KOH.
It will be relocated and lengthened when I switch over to coilovers in a couple months.
Andy~
Ultra4 #4343 Co-driver -
Xjcrawler736 is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 12:39 PM   #3 (permalink)
Member # 148369
Can someone post a picture that shows an example of this? Thanks.
Ghetto fabbin' on a college budget
89' XJ
nonpointfab is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 12:52 PM   #4 (permalink)
Member # 84970
This is all full compression but the bar will be just about parallel with the ground at ride height. But you get the idea.
Andy~
Old 03-03-2010, 12:55 PM   #5 (permalink)
Member # 107038
I've been running flex joints on mine for quite some time and I'm tired of rebuilding/replacing them. Because of this, I've been thinking about running a good solid poly bushing at both ends. I figure it's simple and it'll keep everything nice and tight but still allow a bit of movement.
Thoughts?
Deadman 94 xj is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 01:04 PM   #6 (permalink)
Member # 84970
Thoughts?
What joints are you running? And how long do they last?
Andy~
Old 03-03-2010, 01:07 PM   #7 (permalink)
Member # 107038
RE superflex. They usually last a few months. I grease and tighten them down before install. I'm just wondering if the joint in this application is really that necessary.
Old 03-03-2010, 01:13 PM   #8 (permalink)
Jes
Member # 7575
I wouldn't run any bushings in a panhard bar application. IMO it makes the steering vauge and unresponsive.
Heims have always worked for mine.
TDO Dysfunctional Rockcrawlers. URF Racing. TIN BENDERS.
JV rally post #31.
Jes is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 01:25 PM   #9 (permalink)
the freeak's Avatar
Member # 41185
the freeak is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 01:30 PM   #10 (permalink)
Member # 107038
Good point about them being unresponsive. Thanks.
Old 03-03-2010, 01:40 PM   #11 (permalink)
AgitatedPancake's Avatar
Member # 42341
Mine is just a JKS bar with bushings at both ends, but I can comment on its angle and length vs drag link. When I built the front axle I didn't have high steer, and I had the track bar and drag link identical length and angle. Broke the steering, went to high steer but didnt change the track bar. I've had it this way for a few years (and I'm still on it's FIRST set of bushings) with most of it DD duty. The steering is still very bearable, but I do have bump steer and you have to let the steering wheel float through bumps in the road. It's something I hardly even notice anymore but to someone hopping in for the first time it might be a suprise. I have plans to lengthen it to match the drag link here in the near future.
Dovenosed 5 speed WJ on 9"s
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 03:50 PM   #12 (permalink)
Member # 148369
Thank you sir. It is clear to me now.
89' XJ
Old 03-08-2010, 10:28 PM   #13 (permalink)
[Memphis]'s Avatar
Member # 49281
Bumping March Topic...
Running Heims on both ends of the track bar while better for zero plan in the front end side to side movement...
What is the likelihood that it will promote faster frame cracks in that area due to lack of bushing absorption? I want to brace it regardless even though it is slightly unnecessary in my application
Driving a 5.3L 4x4 el camino wrapped in tupperware :homer:
[Memphis] is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 02:01 PM   #14 (permalink)
Member # 107038
I'm rebuilding mine with balistic 2" flex joints at both ends. 1.25" OD DOM with adjustablilty at one end.
Old 03-09-2010, 02:08 PM   #15 (permalink)
Jes
Member # 7575
I wouldn't worry about it.
JV rally post #31.
Old 03-09-2010, 03:03 PM   #16 (permalink)
adamusmc2002's Avatar
Member # 133157
I like this idea...if I'm running a RE heavy duty, should i replace the axle side bushing w/ a heim? Actually just ordered a replacement bushing from RE, but if i confirm this heim idea, I'll send it back and do something stronger.
Thanks
Adam
adamusmc2002 is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 03:27 PM   #17 (permalink)
It's bent. #ttb
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Getting rid of bushings everywhere in my suspension - the trackbar especially - helped a ton towards making the truck feel more solid. Honestly it ain't even that bad driving on the road with all rigid joints.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 04:33 PM   #18 (permalink)
Twisty's Avatar
Member # 97798
Here's my setup. Tubing is 1.25x.120 (a little skimpy, I know). 3/4 heims on both ends. I do not know the exact length of the panhard bar.
Here's how it sits at ride height.
This image best shows the axle mount.
And here's the frame mount.
And a quick pic of it wheeling.
I think I will upgrade to a 1.5x.250 tube sometime.
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 42" Iroks, full hydro
newenglandjeepz.org
Twisty is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 06:24 PM   #19 (permalink)
Member # 107038
The 1.25" should work out fine. I have an equal length piece of 1.5" I was going to use but it's overkill, IMO, with the little 2" joints. Not to mention the clearance issues in my application.
Old 03-10-2010, 04:48 AM   #20 (permalink)
Member # 97020
sounds much like mine. same heims, same material, uses 9/16" bolts at each end.
mine below, tnt customs at top
nevermind the coat of ps fluid
the tb mount is just some class 3 hitch tubing welded to a piece of 1/4" plate. the frame has been plated on the outside and below since this pic, and the tb mount welded to it.
If I were to do it again:
-went with heims years ago
-played with the axle end mount, so I could run a straight trackbar= easier adjustment.
my jeep is still a daily driver, and fairly mild on radial 35's. I was expecting a great increase in road noise and a crappier ride, but all i noticed was a tighter handling suspension. i will never run a rubber bushing in my front end again.
ktmracer419 is offline   Reply With Quote Quick reply to this message
Old 03-10-2010, 06:50 PM   #21 (permalink)
Member # 82394
BerzerCO is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 06:00 AM   #22 (permalink)
Member # 82644
I just made a new one. I had a 2" JJ with a 7/16" bolt on the frame side. The bolt bent inside the joint. I was a pain in the butt. I swapped it out for a 3/4" heim. Axle side is a bushing from rod end supply. No problems with that or responsiveness.
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE]
hadfield4wd is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 08:09 AM   #23 (permalink)
xo_jeep's Avatar
Member # 112255
KTMracer, what size coils are those in the first pic?
Hadfield, was it a grade 8 bolt? In double shear? If so, that doesn't seem right. I thought even a 7/16" grade 8 still has something like 100,000 ksi in shear strength.
You boys make me proud. You took my inner thoughts and feelings then expand on them in such colorful and creative ways filled with hate.
xo_jeep is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 09:13 AM   #24 (permalink)
Member # 107038
You can get the 2" JJ with a .50" through bolt. It's an option you have to call for FWIW. I just decided to go with these over the ballistic joints, given my experience with adjustables...
The bolt he's probably talking about is the 7/16" greasable, which has a somewhat hollow center to allow the grease through. I never trusted them either.
Old 03-11-2010, 12:46 PM   #25 (permalink)
xo_jeep's Avatar
Member # 112255
Please elaborate....
