Tater2 Build Up - Page 9 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-15-2010, 07:52 PM   #201 (permalink)
ONEtonXJ's Avatar
Member # 145633
Originally Posted by blackrider View Post
Hey Nate that's going to be an interesting drive from Winnamucca to Lakeveiw
Were supposed to get dumped on friday.
fuck.. i'll go through boise then.....
"If you are good at something, never do it for free."
- The Joker
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote Quick reply to this message
Old 12-15-2010, 08:22 PM   #202 (permalink)
AgitatedPancake's Avatar
Member # 42341
Fawking right. Glad to see this thing gettin some love again soon! The ZJ I'm building is gunna be all done and driving soon enough, how long are you expecting for this thing once you can put your mind to it?
Dovenosed 5 speed WJ on 9"s
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Old 12-15-2010, 09:17 PM   #203 (permalink)
ONEtonXJ's Avatar
Member # 145633
haha thanks man.. well this trip home is pretty much do or die... my parents got a divorce so me and my dad are loosing our shop as soon as the house sells..
sooo... im gunna be pullin 36 hour shifts nonstop then break for a nap then i'll be right back at it.. hoping to have it moving around on its own power by christmas which means getting the fuel tank plumbed, get the ECU issue figured out, fluids, driveshafts, and brakes....
then im gunna try and have the floor done, seats mounted, and have a good start on the shifters by new years...
imma be busy.......
- The Joker
Old 12-19-2010, 08:24 PM   #204 (permalink)
ONEtonXJ's Avatar
Member # 145633
well got the tranny mount done and the front drive shaft done.. pics later...
- The Joker
Old 12-19-2010, 09:33 PM   #205 (permalink)
Member # 42341
Nice nice man! I was thinking about your engine problem...what are the chances you could have an issue with the ignition/ignition wiring? Maybe the ECM isn't communicating with the vehicle because the issue is upstream?
Old 12-19-2010, 10:46 PM   #206 (permalink)
ONEtonXJ's Avatar
Member # 145633
bro i have no fucking idea.. completely stumped at this point....
i just put an ECM that i KNOW works on it and i've still got the same problem...
-fuel pump wont prime when you first turn the key on, but i can manually turn in on with the relay..
-no voltage at the coil.. it's actually is showing ground (-) on both sides
-brand new crank sensor
-the wiring harness doesn't seem fucked with or melted in anyway
-i appear to have all my grounds grounded
one thing's for sure, this is the last fucking '91 XJ i'll ever own....
- The Joker
Old 12-19-2010, 11:05 PM   #207 (permalink)
Member # 42341
Haha damn. When you turn the key does ANYthing happen or is it completely dead? could the lock cylinder be dead?
Old 12-19-2010, 11:22 PM   #208 (permalink)
ONEtonXJ's Avatar
Member # 145633
no it cranks over fine....
- The Joker
Old 12-19-2010, 11:31 PM   #209 (permalink)
Member # 42341
Ahh didn't know that!
Hmmm I say start poking around your wiring schematics, find the power wires in the ECM plug, disconnect it and make sure the ECM is getting power when you turn the key. If not, check continuity of those power wires.
*EDIT* If the ECM is getting power, I could only think that it would be sensor related.
*Edit again* What about the camshaft position sensor? It can cause the same syptoms as the crank position sensor IIRC. I did both when I had my issue
Old 12-21-2010, 12:41 AM   #210 (permalink)
Member # 165100
my friend had almost the exact same symptoms on a 94 xj and it ended up being the distributor we threw in a junk yard pull and it lit right up
I HUG TREES.... WITH TOW STRAPS!
built-not-bought is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 02:43 AM   #211 (permalink)
ONEtonXJ's Avatar
Member # 145633
thats what im thinking it is... there's a '91 XJ in the U-pull-it yard, im gunna hit that up tomorrow morning and get the coil and the distributor and some other misc shiz
there's a SHIT LOAD of very helpful tests on identifix.com but you have to pay to use it....
- The Joker
Old 12-21-2010, 03:17 AM   #212 (permalink)
ONEtonXJ's Avatar
Member # 145633
Thumbs down
finally gettin around to postin some pics of what i've been up to the last couple days...
first, had to cut this mount off and move it to the left about 2inches so i could center the tailshaft and get a shifter cable on the 231
which lead to this..
which then lead to this.....
the suspension wasn't working quite right, so i cut the lower control arm mounts off and made new ones... i shortened up and dropped the lower control arms about an inch both ways..
then i got started on this..
bed time......
EDIT: oh and i got the orbital valve mount built and forgot to take a picture of it....
- The Joker
Old 12-21-2010, 05:27 AM   #213 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
You went to bed 2 hours before I woke up.
Maybe some day I can work on my junk again.
1 ton XJ, 60/14, 42's, doubler, etc. RoXJoX President
GreatWhiteXJ is online now   Reply With Quote Quick reply to this message
Old 12-21-2010, 03:11 PM   #214 (permalink)
CTeunuch's Avatar
Member # 121903
You said that the wire that's supposed to supply power to the PCM is showing continuity to ground? How many ohms? I know the harness may look ok but there has to be an issue with that wire if it's grounded. Have you separated and checked all the connectors to make sure there's no corrosion? Do the gauges work? What about the CEL, does it turn on? If you plug the PCM into the 93 you mentioned before, could it communicate at all? I went through this on my 93 ZJ and it was a nightmare.
Oh and your Jeep's queer.
94 ZJ 4.0/AX15/HP44/8.8/5.13's/35's
In the northeast? Check out
CTeunuch is offline   Reply With Quote Quick reply to this message
Old 12-23-2010, 09:50 AM   #215 (permalink)
ONEtonXJ's Avatar
Member # 145633
fired the jeep last night... the #3 pin terminal inside the ECU plug, which is the main power wire for the ECU, was corroded to the point it wasn't making contact with the pin on the ECU.... took the plug apart and replaced that one wire and terminal, and it fired..
ran like shit cuz the timing was off.. got that set straight, now all is well..
needs exhaust now..
i also got the hole in the fuel tank the wrecking yard put in it so they could remove all the fuel.. patched that, and also moved the filler and breather necks to the top of the tank and patched their original holes..
- The Joker
Old 12-23-2010, 10:59 AM   #216 (permalink)
Member # 42341
Good news man glad to heard it! Weight off your shoulders so you can just focus on the fab. NOW GET TO IT! Ahh haha I kid I kid
Old 12-25-2010, 12:38 AM   #217 (permalink)
ONEtonXJ's Avatar
Member # 145633
been workin on gettin the exhast done the last couple days... finally buttoned it up tonight.. some other stuff got started or finished in the mean time too.. i redid the rear suspension bracketry on the axle... now the pinion points at the tcase output at all times and i dont have a 3% antisquat..
i also started the floor but didn't get far, started the driver side boat side so i could get exhaust in, and also started the driver side inner fender so i could finish the exhaust..
thats it for the exhaust.. i'll try and get a video on here so you guys can hear it i guess... here's some more pics..
rear axle
floor.......ish
- The Joker
Old 12-25-2010, 12:40 AM   #218 (permalink)
ONEtonXJ's Avatar
Member # 145633
sweet sight tube thingy......
the $20 wiring harness i bought
for this one single 6" long wire.......
that's all... Merry Christmas
- The Joker
Old 12-25-2010, 01:00 AM   #219 (permalink)
ONEtonXJ's Avatar
Member # 145633
well lets check some shit off this list.... red means done
floor
seat mounts
shifters
belts
interior B pillar
mount orbital, steering ram, and cooler for full hydro
brakes
driveshafts (front/rear)
tranny mount
lincoln lock front and reaf diffs
tail lights
battery tray
front bumper and winch
paint cage and all suspension
bead locks and rim stiffeners
redo rear 4 link geometry
mount shocks front and rear
make engine run
air intake
exhaust
front inner fenders (left/right)
on board air
mount fuel tank
bump stops
fill trans, cases, and diffs (fluids)
trim door bottoms and make removable
skid plate
boat sides (left/right) only the le gets to be red cuz the left one needs to be skinned and it'll be done
rear inner fenders (left/right)same with this.. need to finish the top
fuel lines
and a shit load of welding...
- The Joker
Old 12-25-2010, 09:48 AM   #220 (permalink)
Member # 103442
Thats exhaust is fuggin sick Nate! Nice work man!
Old 12-25-2010, 12:08 PM   #221 (permalink)
ONEtonXJ's Avatar
Member # 145633
thanks man..
i wish i could run it longer so i could listen to it.... i started it and rev'd it up twice and shut it down.. no water, minimal tranny fluid, and no power steering fluid.... not trying to make more work for myself...
- The Joker
Old 12-25-2010, 12:24 PM   #222 (permalink)
xj9140's Avatar
Member # 122916
Yeah, x2 on the exhaust. Hell of a job, looks killer. I got tired of screwing with my tail pipe and welded it solid too. I was surprised, the noise and vibrations wasn't at all as bad as I expected. Flex couplers do their job well.
xj9140 is offline   Reply With Quote Quick reply to this message
Old 12-25-2010, 11:12 PM   #223 (permalink)
Swag Sales
dozer_xj's Avatar
Member # 90594
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well!
Andrew Dial
Jedco Sales Inc.
PM me or email
We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are!
dozer_xj is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 12:24 AM   #224 (permalink)
Member # 105526
Sending the exhaust through the frame rail like that is very cool. Never seen someone do that before with an XJ.
praetorian is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 01:20 AM   #225 (permalink)
ONEtonXJ's Avatar
Member # 145633
thank you, and neither have i.. it was easy as fuck, the hardest part was getting that 3.5" skeg 40 through the frame with the holes in the right spot.. there were some big ass gaps i had to fill but it came out alright i think...
after i got it though the frame it was smooth sailin.. WAY easier than trying to snake it passed all my suspension and shit...
the shocks will be inside that inner fender for those who have thought ahead that far...
- The Joker
