#351 (permalink) |
How tight are your slugs on the shaft?
Mine just came in and I simply cannot get the flange onto the shaft without a decent amount of force. And I mean like beating the shit out of it with a deadblow force..... (No, I havnt done that....) It fits in the Unit bearing perfect.....but not the shaft. I have tapped it with the deadblow and it did engage a bit, but to get it fully installed will be a big chore. Anyone?
XJ on 42's |
#352 (permalink) | |
Member # 122916
even tighter on one side than the other, I have to basically hammer the subs in. Once they get some use, I'm hoping the stubs will loosen up. Did you try and see if your slugs fit any other axle splines better? What stub shafts are you using?
#354 (permalink) |
Member # 207734
Is the 14 bolt rear and HP Dana 60 the best set up for an XJ?
Also these both are of similar widths if im not mistaken so i wouldnt have to shave them down or nothing? Just redo the mounts and brake lines and your ready to rock? |
#355 (permalink) |
Member # 133593
Yes, they practically bolt right in. Its actually amazing just how simple it is to install them.
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
#356 (permalink) | |
Member # 145633
As for your flanges... I read once apon a time somethin that vette was having the same problem.. Dead blow away..
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds |
#357 (permalink) |
Member # 207734
Why are you calling me an idiot? im asking a question so i can further my understanding... is there more fab i need to do? Ive been stalking the builds on here and i cant really find anything to tell me what exactly i need to do for the steering 60. All i can gather is common since telling me that i would have to reposition all mounting brackets for everything and probably redo the brake lines to accommodate the wider axles. From what i hear the ford HP 60 is the same side drop as the Dana 30 if im not mistaken.
#358 (permalink) | |
As for the tech, the culprit of the tighness has been found. Its the shafts. They seem to have been machined to the high side of the tolerences and then with the finish coating, they got even tighter. Ive contacted the supplier and the manufactuer and they say beat em on and they will loosen up with use. Reassuing I guess, but beating a 200 dollar slug onto a 200 dollar shaft, running threw a 400 dollar unit bearing doesnt really strike my fancy. They did say tell me that if anything is heavily damaged, they will replace it. Pics coming sometime....Im making decent progress.
XJ on 42's |
#359 (permalink) | |
Member # 145633
get some shit done now.. I'll be out in CO soon, we'll have to hit up some trails
#360 (permalink) |
Good news!
Took the shafts to work today. Just got off. I did my own little investigating on this. They are machined to the high side of the tolerance. I also threw them under a mirco and determined that when they where hobbed a very slight burr was created. Prolly 5 ten thousandths. To get rid of this I took em to the bench grinder. Now hold on sec.....I use a unitized, aluminum oxide, deburring grinder wheel all the time to debur parts at work. So all I did was lighly take the shaft to the wheel and knocked off the slight burr from the hobbing and to remove the finish coating. Slides on like a champ now.
XJ on 42's Last edited by GreatWhiteXJ; 01-12-2012 at 05:22 PM. |
#361 (permalink) |
Was kinda hoping to hold off on an update but I need a little assistance....
Ill keep it strickly to the problem tho as Id like to do a really big update when a few more parts come in. Yes, theres tons more done and ready to show, but you'll have to wait ![]() Panhard whoes. Ive been stuck here for quite a while now. Cant figure out a suffcient mount without serious sacrafices. Pre notes: (What Im currently trying to fit) Drag link = 40 3/8" Panhard = 37" Before its suggested.....I do volunteer search, rescue, and aid in severe conditions and it is a requirement to have mechanical steering. Full hydro is not an option. I will not pass there inspection. So I knew Immediatly after fabbing the panhard and bolting it frame side, that fitment was gonna be a major PITA! And its kicking my ass. So today I figured I go ahead an finish it off, get the ram mounted and call it done. Not going so well thus far.... So to see exactly what I was gonna be working with, I made a tab and tacked it in place. First...this is the hi steer arms all finsihed up. Double sheer all around. Im quite happy with them. No beef spared here. ![]() So all mounted up and straight we end up like this. (For those wondering its all 1.5", .250 Wall DOM, with 7/8 heims on the tierod and 3/4's on the drag link and panhard.) Lookin good, lookin good.... Remebering that panhard is not attached....the body kinda sits where it wants. Hence the crooked coils..... ![]() Then full lock, passenger....shit hits the fan. ![]() It clears at full lock.....it does not clear at full lock, full bump. So gotta come up with somethin. Without getting too carried away I just started playing with the heim. If I could get away mounting it verticle, things would be great. But I get the strong feeling the joint would be binding long before full drop. Any feed back on this is appreciated greatly tho, as this is one option that would require no major re-working. ![]() Another option is rotated in this manner.... Which is really no better than straight verticle and actually takes a little clearace away opposed to straight verticle. ![]() So my other thoughts are....remove the misalliment spacers, tack up another mount and see if the heim binds without the spacers. Shortern the panhard 6"......which I REEEALLLY am not intrested in. Throw a bend in the panhard so it slightly wraps behind the side of the passenger coil. The panhard and joint are not the problem. It the mount and bolt that make contact. If I could move that mount back like 1" ...everything would clear. Still tight, but would clear. However, Ive never seen anyone bend a panhard in that manner. So Ive got really no idea how it would react. Something like this is what Im thinking..... ![]() Anyone got any ideas???? Thanks in adavance!
XJ on 42's Last edited by GreatWhiteXJ; 02-01-2012 at 04:31 PM. |
#362 (permalink) |
Member # 145633
![]() Not exactly like this but I think something like it off the front of your coil perch would be good... I wouldn't wanna bend the track bar like that.... That much anyway, one good shove from the passenger tire would fuck that shit up.. Dig the steering.. Carry on
#363 (permalink) |
Member # 145633
![]() Also you could tap the front and put the bolt in from the back...
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds Last edited by ONEtonXJ; 01-29-2012 at 02:08 PM. |
#365 (permalink) | ||
Not sure what your getting at here Mike. I think I see what you mean, but shortning up the links wont get me more clearance. See my last thoughts below..... I kept tinkering yesterday with only progression in thought. Mounting the bolt and heim verticle could potentially be ok. I think Ive figure about 8 1/2" drop before binding. And I was planning 9" down travel anyways. So I may tack up a mount and attempt this first. Eliminating the mis spacers seems pretty promising. That would net me the 1" I need. The frame side heim has mis spacers. And between frame side with em and axle side without em, Im prolly looking at 40* of rotation to work with. At full drop, I doubt Ill see 40* of rotation. Also, putting a bend in the panhard has my attention too. My awesome paint skills are a tad excessive and the bend would not be anywhere near as severe as I illistated. Nate, I see your thoughts on this bending but again it wouldnt be like I painted. If none of the above ideas work out, Im left with not choice but to do major fab. This would mean reworking coil locations. Id have to remove both upper and lower mounts on each side and move them back. Thats the only other feesable way I see this happening. Any other suggestions are welcome and appreciated.
XJ on 42's |
#367 (permalink) |
Member # 112255
I'm not a huge fan of this, but it just might work for you. It gives you a longer panhard also. Would definitely need to gusset the inner Cs a lot to feel good about it.
Boom goes the dynamite |
#368 (permalink) |
FroBot
This probably isn't what you want to hear, but I say shift the coils rearward. The axle side mounts you may have to extend the flat part of the perch backwards a little bit, but the top looks like its got plenty of room to have the post cut off and pushed backwards an inch or so from the way you built it. Seems like it wouldnt be too intense of a job honestly.
I can't recall, do you have a plasma cutter? Make it REALLY easy haha
Dovenosed 5 speed WJ on 9"s and an ongoing won-ton 5.9 ZJ build
#370 (permalink) | |
Member # 67365
Your drag link is mounted with a vertical bolt, granted its slightly longer then your track bar, but I bet you'd be fine mounting it the same way. I'd tack it in place and cycle the suspension. IIRC a heim with high misalignment spacers is good for about 30 degrees of travel, with 37" track bar that's about 19" of travel. |
#371 (permalink) |
Stump Humper
Member # 137046
Take a look at my build, half way down page 1 when I built my front 60. That setup may work for you, it works very well for me and is not far off from what you already have. you could move your frame side panhard mount more outboard to give you more possible locations for the axle side mount.
#372 (permalink) | ||||||
No plasma. Gotta finish the big toy before I start buying the little ones. :Shrugs: But I see what your saying and honestly....no its not an overwhelming amount of work...........it just...sucks. Thanks!Quote:
(Not at you...at them.) But even if I did....yes its a sufficient amount I would lose. Quote:
As of right now, this is plan B. I honestly think I can ditch the spacers and everything will be fine. This is plan A. Explain how you calculated 19" of travel. Not saying your wrong, just curious. Thanks Quote:
And then......I posted in Gen 4x4 about this and got one response that was worth considering.... from "MiniWally". "We have run a bend in the track bar on several rigs, including our race car. 1.5" .250 wall minimum material. larger and thicker if possible. Run only the amount of mis-alignment spacer that you need, if you don't need any don't run any. We actually cut the shoulder off of a bushing assembly and put one on each side of our chassis end link arm mount on the race car. This keeps the track bar aligned vertically, allows it some misalignment as they are slightly narrow and also gives a bit of soft cushion if they hiem needs it. Sometimes clearances are measured in 1/16ths when working around factory stuff and things you don't want to change. Not saying that little clearance is good but I litterally have had clearances so small that the paint rubbed off but never went metal to metal. Just keep working things in and make it happen." So plan of attack is: A.) Try without spacers and check full bump and drop at full lock B.) Try mounting verticle and do the same. C.) Rework coil mounts. Thank you all for your thoughts and opinions. Much appreciated! Next update should be a good one. Lots of shinny parts collecting in the garage.
XJ on 42's |
#375 (permalink) |
FroBot
Sounds like a plan cap'n! I just noticed one more potential interferance issue though, how much uptravel are you going to run? It looks like the track bar might get into the brace on full uptravel because they are in the same plane of travel
Other then that, get dems new pics up!
