GW Backwards re-Build...v1.7 - Page 18 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-24-2012, 05:56 PM   #426 (permalink)
FroBot
AgitatedPancake's Avatar
Member # 42341
Send a message via AIM to AgitatedPancake
That front is lookin badass man. I can't quite tell if you have the grill mounted in there, or just laying slanted forward...but I like it. It kinda gives the feel of something between an old jeep and an old dodge to me, the proportions of everything look great with the dovenose though! Floorboards look clean too, sucks you have to hack into 'em for the seats!
Dovenosed 5 speed WJ on 9"s
and an ongoing won-ton 5.9 ZJ build
AgitatedPancake is offline   Reply With Quote
Old 04-24-2012, 06:35 PM   #427 (permalink)
Stump Humper
Chaps's Avatar
Member # 137046
Looks great man, I like what you did with the floor. Hows the seat mounting going? I am starting on the same project with the same doubler setup. I have been running a Spartin Locker in my front D60 for a while now with no problems and it hooks up well. The Spartin is a great locker for the money.
Another POS unibody
Chaps XJ build
Check out my You Tube
Chaps is offline   Reply With Quote
Old 04-24-2012, 08:08 PM   #428 (permalink)
Member # 153054
XJ meets glass bottom boat. allsome
DeftwillP is offline   Reply With Quote
Old 04-25-2012, 02:41 PM   #429 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
Originally Posted by dukie564 View Post
jesus christ the front of that looks menacing. Great job on the floors and such.
Haha...much appreciated! Thanks! I constantly find myself squatted just gazing at the front end. Im a big fan of it myself.
Thanks man! The grill is just chillen. And yea, its fallen out of place an leaning forward. If you notice tho, I took all that stoopid thin, fin type crap, out between the large slots. Looks much better to me.
And yea, I wasnt too happy when I wrapped up that last piece and painted the floor...only to set a seat in place and realize Im way too high.
Thanks Chaps! Seat mounting isss aaa.... yea Im takin a break. Im a pretty avid fisherman and the walleye are up spawning. Ive hit the rig HARD for almost everyday for the last 6 weeks. Takin a few nights off. But honestly I was gettin the urge at work to tinker tonight.
And actually seat mounting has been another classic case if designs block. Ive got 2 notches cut and Ive placed the seats in. Everything is good and Im hapy with head clearance. But figuring out the actual mount is getting the upper hand. Im thinking Ill lay in a slightly heavier (1/8) filler there and weld the bolts threw the underside with a a reinforment plate running the entire length f the seat, to the other bolt. Similar to a stock method but on steriods. I dont know tho. Im thinking Ill stare at it for a few hours, then go thro line and think about it a few more hours. :Shrugs:
Whaaaaaat? Thanks.....I think.
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 05-04-2012, 04:19 PM   #430 (permalink)
Member # 103442
And thats all Ive got to say about that.
XJ on 42's
Old 05-05-2012, 06:27 PM   #431 (permalink)
Member # 103442
Seats are in!
Batteries are dead.
Pics tommorow.
XJ on 42's
Old 05-05-2012, 08:01 PM   #432 (permalink)
BryanDowdy's Avatar
Member # 33510
Originally Posted by GreatWhiteXJ View Post
Uhmm....
Went with a Spartan Front Locker. Yukon makes em and they have yet to report a broken one. Moreless identicle to a lockrite. Come with a new heavy duty crosspin. A few have worn em out but no broken ones. Thats good enough for me.
Probably one of the easiet part installs on the whole rig. Didnt even take me an hour to assemble it. The pull pin, sping design is genious!
I went with these font & rear. After searching I came across two guys running these. One with 44s the other 49s, both had sbc. Neither reported problems. Hopfully will be a good stepping stone to selectables.
Rig is looking great! That floor is crazy.
Northridge Fabrications
Montrose, CO
970.626.6090
XJ, TBI SBC/TH350, Atlas2, 4-linked F/R, 60s, 42s
BryanDowdy is offline   Reply With Quote
Old 05-06-2012, 10:41 AM   #433 (permalink)
Member # 210838
Awesome build man. Where are you located in CO, i sware ive seen this rig in its early stages before...
TheCK4x4 is offline   Reply With Quote
Old 05-07-2012, 02:55 PM   #434 (permalink)
Member # 103442
Loveland
Are you one of the quadrillion people who drive there 33's by my house and never stop and talk to me?
XJ on 42's
Old 05-07-2012, 03:13 PM   #435 (permalink)
Member # 103442
Seats are in.
Im not happy with this at all. I mean, I am....but things got so tight underneath Im more concerned about the t-case kissing the seat mount now than anything. Ive got a little over 1" until the tcase touches. If it rotates any more than that, then I will have to modify the seat.....again. But with poly motor mounts, rubber tranny mount and a rubber 300 support....I think....Im going to be ok. Thoughts on this are welcome.
Should be as easy as reving the motor a tad right? Yea....if my alarm would shut off long enough to let me do that...... Motor starts and runs fine, just wont stay running cause of the alarm. (Does anyone know how to disengage a factory alarm system?)
Moving on....
Mounts are stout as shit. Everything removed was replaced with 1/8 and 3/16. If the seats are gonna break off, they are going to have to take the entire floorboard with. I orginally thought I needed some more bracing, but then decided it would just be unnessicary weight.
Passenger side....
Also passenger side.....showing 1/8 gussets
Passenger mounted...
Driver side.
This is the hole I hade to cut. Nice ehh....
XJ on 42's
Old 05-07-2012, 03:15 PM   #436 (permalink)
Member # 103442
Driver side filled back in.....
Another view....
Seats are Hunsakers by PRP.....From PolyPerformance.
And mounted...........
And yes, the driver side is higher than the passenger. Had to be this way to clear the case.
XJ on 42's
Old 05-07-2012, 03:17 PM   #437 (permalink)
FroBot
Member # 42341
that came out clean man, badass work. I'm a fan of the look of the seats too.
So close now! How much left on the to do list?
Old 05-07-2012, 03:22 PM   #438 (permalink)
Member # 103442
Thanks Bryan! I searched the Spartan pretty hard too. Only found a few who had worn out the teeth and absolutly ZERO failures. Lots of comp guys running them and a handful at KOH with em too.....still no failures.
XJ on 42's
Old 05-07-2012, 03:35 PM   #439 (permalink)
Member # 103442
Ya know considering the brainfart and crap holes I had some neaderthal cut out, it did come out pretty clean and I am happy with it. It kicked my ass tho. Thanks for the compliments!
And yes,.....very very close. But not according to the wallet.
Fab wise its moreless done. I still need to do the interior b-pillar cage (which broke out the rear window BTW...) and then attach seat belts. And I need to wrap up the belly skid which is moreless done also. Aside that, just about everything is done. Oh I guess I need shifters too.
Im down to waiting on the last few parts I need really. Which totals to about 1200 bucks. Most of which is plain jain stuff. Battery, few brake parts, few steering parts, exaust, fluids and some other dumb stuff. Then assemble everything Im too anal to leave outside.
Had to get another shot in my back tho, so gotta meet the 2,000 deduct and have a few other things I gotta take care of, then Im back on track. That explains why Ive been kinda casually working on it.
Alllllllllmost there tho.
XJ on 42's
Old 05-07-2012, 03:54 PM   #440 (permalink)
Member # 103442
Also I wanted to share this.... little seat info.
Im not a huge guy but bigger than most. About 6'2, 210lbs or so (and dropping rapidly ). In searching for seats I found SEVERAL complaining about Corbeaus SS being short. Short as in the top of the head rest was hitting the base of their necks. And being taller than some of those complaining, I simply did not want to take the risk of a neck injury.
So my options where to upgrade to the Ultra's (Another 100 a seat) or find another seat all together. Naturally I shopped around.
Now, I oginally looked at the Hunsakers but in searching around for reviews I found a comment from Camo saying "Shitty welds, shitty material, blah, blah, blah..." So I kinda steered away from them. But then running out of the less expsensive seats to look at....I went back and re-researched the Hunsakers. Camo's post was almost 5 years old so I let that slide an focused on the rest of the reviews....
Come to find out, the Hunsakers are now made by PRP. Which made me very happy. So I searched for seat dimesions and low and behold, the seat is 4" tall than a Corbeau and cheaper. So I pulled the trigger.
Now, keep in mind the seat being taller is not the issue with me hitting my dome on the roof. Thats a combination of the t-case and me just being a little tall. The seat cushion height and depth is the same as just about all other suspesion style seats.
If anyone else stumbbled upon Camo's post....ignore it. I assure you the seat is very well made. They are very comfy as well.
XJ on 42's
Old 05-07-2012, 05:10 PM   #441 (permalink)
Member # 210838
Loveland
yeah probably......ive really only driven by like 3 times over the last 2 years but never see you outside, next time i drive by ill knock!
Old 05-07-2012, 05:14 PM   #442 (permalink)
Member # 103442
Your name isnt Brandon is it?
XJ on 42's
Old 05-07-2012, 05:24 PM   #443 (permalink)
Member # 210838
Nope, Colton i do know a brandon that drove a blue xj though
Old 05-07-2012, 05:54 PM   #444 (permalink)
Member # 103442
Well stop by sometime man! Ive been out A LOT latelty.
Just leave that Brandon kid where he's at tho. If its the same Brandon I know, then he's out telling people he built things that I infact built. Im not cool with that and my next encounter with this fuckbag wont go over so well.
XJ on 42's
Old 05-07-2012, 06:21 PM   #445 (permalink)
Member # 210838
Ya we might be thinking of different brandons then.....but thats messed up. also i ill swing by maybe tomorrow, will you be out working anytime after 2
Old 05-07-2012, 06:37 PM   #446 (permalink)
Member # 103442
I dont get home from work till about 3-3:30 but anytime after that Im usually out there. Depending on what Im doing I usually wrap up about 8.
XJ on 42's
Old 05-10-2012, 04:04 AM   #447 (permalink)
ONEtonXJ's Avatar
Member # 145633
cute ruler...
the floor still came out good even with the unexpected changes..
wait to you see what i've been fuckin around with this past week
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 05-10-2012, 02:24 PM   #448 (permalink)
Member # 103442
Glad you like my ruler.
Yeah, considering what I had to do, Im quite happy with the floor. Thanks!
XJ on 42's
Old 05-13-2012, 09:05 AM   #449 (permalink)
Member # 103442
These seats are fuggin me at all corners. As if t-case clearance and head clearance issues werent enough......now they are seriously comprimising the way I had the interior cage planned out.
Pics tonight.....Its gonna be one of these things where "It is what it is". Dont have any corners left to cut.
XJ on 42's
Old 05-13-2012, 09:41 AM   #450 (permalink)
ONEtonXJ's Avatar
Member # 145633
By interior cage, you me b pillar cross right...........
