GW Backwards re-Build...v1.7 - Page 24 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2012, 07:08 AM   #576 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
I'll get to pimpn the truck later. I gotta finsih the rig and source a trailer before I do anything crazy.
When I do tho, Ill be changing:
--Lights to 05-07
--White grill
--Tint windows
--Snag some Excursion seats from the JY (Bench seat isnt bad, but its angled in a way that my back doesnt appreciate and is not adjustable.)
--Mirrors
--Minor interior upgrades
-- build some bumpers
Back to GreatWhite....she's gettng there. Front end is pretty much completly appart. Fenders and hood are off. (Well, hood is laying in place to keep out weather.) Front axle was pulled last night to double check everything and prep for final paint. Should have the axle 100% assembled and installd by the end of the day. It will look moreless the same as it has in recent pics. Color choices are staying the same. Just a little more blingy this time around.
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 08-08-2012, 03:53 PM   #577 (permalink)
Member # 103442
Ohhh!!!!!!!!!!!!!!!!!.............. is it done????
Nope.
School me on rear limit straps. Im fried on reading it all. Read Camos thread and several others but sill dont understand whats best FOR ME.
Most of what I read pertained to coilover or airshock setups. And again mostly all talk on mounting them eye to eye vs other locations and generally related to higher speed.
The 2 main points Ive gathered and that are beating me retardo are :
Single, centered strap, helps with rig with lots of drop and paticularly driveline binding.
Double, strap each side, is better for controlling articulation.
As fas as Im concerned I have lots of both. So what do I want/need?
Go.
For those wondering heres the "TO DO" list.
-Front and rear limit straps
-Front driveshaft
-Reinstal steering and bleed
-Run brake lines
-Properly run fuel lines
-Finish shifters
-Fill fluids
-Finish exaust
-Lots of dumb little stuff
-GO WHEELING!
Parts to get still:
PSC pulley
Brake Prop Valve-----DEFINATLY OPEN FOR SUGGESTIONS
Battery
Front DriveShaft
Limit Straps
Fluids
Bolts
SOOOOOOO CLOSE.....
Cept I need a trailer still
XJ on 42's
Old 08-08-2012, 04:27 PM   #578 (permalink)
FroBot
AgitatedPancake's Avatar
Member # 42341
Send a message via AIM to AgitatedPancake
Do individual straps on each corner, and have them hit 1-1.5" before you're shocks limit, because they are bound to stretch a bit on sever dropout occasions. Thats how I did it and I'm loving it.
I feel center limit straps are a band aid for a binding drivetrain (as you said), but see no reason to use them if you're not binding. When you're going fast you want the entire axle capable of moving up and down as much as your shocks and springs allow it, no reason to limit your suspension travel.
Dovenosed 5 speed WJ on 9"s
and an ongoing won-ton 5.9 ZJ build
AgitatedPancake is offline   Reply With Quote
Old 08-08-2012, 05:13 PM   #579 (permalink)
ONEtonXJ's Avatar
Member # 145633
whats wrong with 3 straps?? 1 for the drive shaft and 1 on each side for the shocks?? its not like you HAVE to only use either 1 or 2.... use 3....
i agree with pancake.... but if i know you right, you wont need to worry about sacrificing travel for jumps/speed
oh and cables dont stretch jus sayin
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 08-10-2012, 05:22 PM   #580 (permalink)
BryanDowdy's Avatar
Member # 33510
Did cables on mine and like them so far.
Northridge Fabrications
Montrose, CO
970.626.6090
XJ, TBI SBC/TH350, Atlas2, 4-linked F/R, 60s, 42s
BryanDowdy is offline   Reply With Quote
Old 08-12-2012, 07:52 AM   #581 (permalink)
Member # 103442
What straps are you running?
3 straps seems way overkill for a rig like mine. And your correct, speed will never be part of my equaition. At least not in this rig.
And cables are common. Tons of guys run em. Same with chain. Both work fine.
What size cable are you running?
"Like them so far" means.....your wheelin? What size cable?
XJ on 42's
Old 08-12-2012, 10:46 AM   #582 (permalink)
ONEtonXJ's Avatar
Member # 145633
i wouldnt say it's overkill... obviously you need to limit the shocks, and if you need to limit the shaft too then do it....
i wanna say 5/16".... my swagging tool wasnt big enough for 3/8 i think
Old 08-12-2012, 12:53 PM   #583 (permalink)
FroBot
Member # 42341
I'm running Ruffstuff straps, they are beef. I've got no real problem with chain or cable in a non go fast situation, I ran chains myself for a couple years without issue. I do personally enjoy the idea of the straps stretching though, it absorbs the energy softer over time via that stretch instead of having the axle dropping out and hitting max droop with a shock load like chains and cables would. I don't know if it's soft enough to feel a difference in the real world, though I just feel like the stretch makes it easier on things.
Old 08-12-2012, 01:12 PM   #584 (permalink)
ONEtonXJ's Avatar
Member # 145633
i definitely agree... Matt an I are pussies and prefer to drive slow lol
Matt's painting shit.... everyone demand pics....
Old 08-13-2012, 02:22 PM   #585 (permalink)
Member # 103442
You shush your face.
XJ on 42's
Old 08-15-2012, 07:47 PM   #586 (permalink)
BryanDowdy's Avatar
Member # 33510
I used 1/4'' cable that has the rubber coating. Yep, wheeled it some. Trying to work out some bugs. Cooling, rear d-shaft vibs, and exhaust. Planning on taking it out again this weekend, so I'll get a better idea how the cables do. I did get the front air born 10-12" once and the cables seemed to handle the weight fine.
Montrose, CO
970.626.6090
Old 08-15-2012, 08:45 PM   #587 (permalink)
ONEtonXJ's Avatar
Member # 145633
Wtf.... I need to know what a roll cage painted black looks like......
Old 08-16-2012, 03:14 PM   #588 (permalink)
Member # 103442
It looks like a roll cage with black paint.
And Im not using black.
XJ on 42's
Old 08-16-2012, 07:06 PM   #589 (permalink)
ONEtonXJ's Avatar
Member # 145633
ive never seen one... tell me more ooorrrrrrr.... show me
Old 08-18-2012, 01:01 PM   #590 (permalink)
Member # 103442
MMMMMMM...no.
I wont post anymore pics until its done. Not tooooo much further to go.
XJ on 42's
Old 08-18-2012, 01:09 PM   #591 (permalink)
Member # 103442
GIVEAWAY!!!!!
Yea....seriously.
Winner gets one of my 231-300 Doubler Plate Kits. Kit includes: 231 main plate, 231 block-off plate, clocking ring, and new guide pin. This kit will require you purchase your own midshaft. (I recommend D&D Machine, $265). Plates are all 1/2", CNC machined, 6061 Aluminum.
How do you win?
Identify the object below. If you correctly guess what it is and specifically where it goes, you win.
Its 9/16" thick steel and CNC machined. Thats all you get. Good luck!
XJ on 42's
Old 08-18-2012, 01:29 PM   #592 (permalink)
Member # 122916
Its steering cylinder mount to the diff cover. But I think you need a bigger hole.
1949 F5 '49 Ford truck build
ZukiDuke build The Suzuki Duke
xj9140 is offline   Reply With Quote
Old 08-18-2012, 01:35 PM   #593 (permalink)
Banned
Member # 178399
I'll guess its a axle side D ring mount for a suck down winch??
GeneticDisposition is offline   Reply With Quote
Old 08-18-2012, 01:52 PM   #594 (permalink)
Member # 103442
Nope.
Nope.
XJ on 42's
Old 08-18-2012, 02:37 PM   #595 (permalink)
Member # 67365
Limit strap mount/ knuckle gusset? Mounts to top of knuckle and axle tube?
9T3XJ is offline   Reply With Quote
Old 08-18-2012, 05:49 PM   #596 (permalink)
ONEtonXJ's Avatar
Member # 145633
i dont need yo shit... but i'll take a stab..... is it some kind of mount for the doubler kit? weld to the 231 somehow?
it's aluminum so it cant weld to an axle, ya retards
Old 08-18-2012, 05:56 PM   #597 (permalink)
Member # 122916
Old 08-18-2012, 06:04 PM   #598 (permalink)
Member # 103442
GIVEAWAY!!!!!
Its steel.... so I cant weld it to the doubler. ya retard.
XJ on 42's
Old 08-18-2012, 06:06 PM   #599 (permalink)
ONEtonXJ's Avatar
Member # 145633
fawk... fail
Old 08-18-2012, 06:06 PM   #600 (permalink)
Member # 103442
No correct answers yet.
XJ on 42's
