Mad Mike's CHIEF - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2010, 04:57 PM   #1 (permalink)
Member # 122916
Mad Mike's CHIEF
Here goes my build. Currently I am putting together a 3 link in my daily driver. First I cut a hole in the floor and got the frame side, upper control arm bracket mostly mounted
xj9140 is offline   Reply With Quote
Old 07-05-2010, 05:03 PM   #2 (permalink)
Member # 122916
bumper
here is my winch bumper I recently finished:
Old 07-05-2010, 05:09 PM   #3 (permalink)
Member # 122916
rocker replacement
3x5 .25 wall tube. I butted up against the pinch seem and welded to it. Eventually these will become air tanks
Old 07-05-2010, 05:11 PM   #4 (permalink)
Member # 122916
flat belly cross member
The current cross member, its 3/8's flat bar and I clocked the 231j transfer case flat by re drilling the trans adapter.
Old 07-05-2010, 05:21 PM   #5 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
All that work for a winch bumper, and you left the winch in front of the radiator?
Weird.
'94 XJ RIP, time to move on
New East Coast TTB racer in the works, trimmin' the fat...
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote
Old 07-05-2010, 05:27 PM   #6 (permalink)
Member # 122916
Weird.
I put it where I wanted, it sits back a little. I like the protection my grill gets, and being able to easily access my free spool lever and solenoid box. Besides its my daily driver, not that it matters. I keep up with most rigs off road.
Old 07-06-2010, 01:01 AM   #7 (permalink)
Member # 74576
Weird.
Did you mean....grille?
Mounting it behind the radiator would be impressive.
tmorgan4 is offline   Reply With Quote
Old 07-06-2010, 05:11 AM   #8 (permalink)
Pigs Fly
vetteboy79's Avatar
Member # 31621
No, not especially.
The feet on my winch are about even with the centerline of the radiator, and the drum is about a half inch from the balancer.
Old 07-06-2010, 08:07 AM   #9 (permalink)
Rock Racer Wanna-be
BrassMunkey4's Avatar
Member # 35581
I'd be more impressed if it went behind the grill but not the radiator.
Now that would be squeezing 10lbs of shit into a 5 lb bucket.
Your sliders look familiar
High sock tans and flat brims on the east coast.
-Scott
Miller Motorsports #9 / 921 Stock Class (cause we are too cool for a 4600 number)
BrassMunkey4 is offline   Reply With Quote
Old 07-06-2010, 11:33 AM   #10 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Behind the grill, below the radiator... You can only fit 10lbs of shit in a 10lb bucket if your holding the bucket upright
ashmanjeepXJ is offline   Reply With Quote
Old 07-10-2010, 09:15 PM   #11 (permalink)
Member # 122916
cargo area
I did some work on my cargo area today. The plan is to have it completely covered so I can carry groceries and shit back there. Duplicolor bed liner is a bitch to remove. My fuel tanks full, still makes me nervous as hell welding so close to it. I still need a grommet for the fuel injection hoses. Tomorrow I get some lathe time. Steerings getting new, bigger hiems and I am going to build some twisty shackles for my leaves.
Old 07-10-2010, 11:25 PM   #12 (permalink)
Member # 122916
shackle relocation
pics of my shackle relocation boxes:
Old 07-15-2010, 05:22 PM   #13 (permalink)
Member # 122916
steering shaft
my steering shaft was a bit sloppy. I found it the be the rubber yoke bushings. I burned them out with a torch and welded it solid. I used some key stock in place of the rubber.
Old 07-17-2010, 09:11 AM   #14 (permalink)
Member # 65332
find a temp front end yet?
fishotro is offline   Reply With Quote
Old 07-18-2010, 11:50 AM   #15 (permalink)
Member # 122916
3 link
I started filling in the floor, It would be better to wait in tell I finish the control arms, but the hole really freaks out my passengers and allot of heat from the exhaust pipe is coming in the cab.
Old 07-21-2010, 03:31 PM   #16 (permalink)
Member # 119372
done yet?
calipup72 is offline   Reply With Quote
Old 07-24-2010, 02:18 PM   #17 (permalink)
Member # 104995
Send a message via Yahoo to seniorxj
Exclamation
-Nice work,, gonna have 2 pick ur brain a bit for my build as im always beefin up my XJ!! ESP if i get that front axle from ya!!!!
6.5" 35" Claws 4.88's Ford 8.8/ARB HP d30/Aussie 1ton steer RK trac TW F&R Dshafts Armored snorkel
seniorxj is offline   Reply With Quote
Old 08-06-2010, 07:52 PM   #18 (permalink)
Member # 122916
tons
I took my xj for a couple hour drive today and picked up a bunch of parts.
Old 08-07-2010, 08:56 AM   #19 (permalink)
jeffhaut's Avatar
Member # 148714
[QUOTE=xj9140;11656963]
QUOTE]
AWesome gusset haha, you make that?
109" one tonn YJ
jeffhaut is offline   Reply With Quote
Old 08-07-2010, 06:34 PM   #20 (permalink)
Member # 104995
Question
Are u buildin those 60's urself??
Old 08-07-2010, 07:28 PM   #21 (permalink)
Twisty's Avatar
Member # 97798
lo-pinion D60 rear end pumpkin for the front?
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 5.38s, full hydro
newenglandjeepz.org
Twisty is offline   Reply With Quote
Old 08-07-2010, 07:30 PM   #22 (permalink)
Member # 122916
yep
Old 08-09-2010, 03:41 PM   #23 (permalink)
Member # 16575
9 with 60 outters would be smokin
dumblucky is offline   Reply With Quote
Old 08-12-2010, 04:45 PM   #24 (permalink)
Member # 65332
Originally Posted by xj9140 View Post
Yeah, Sucks though the axle tubes are only 1/4 wall. I may just build a 44 or 9" with the 60 outers. Not sure yet.
You should have told me you where in the market, I can poop in my hand and sale it to ya cheaper than what you paid for that guys poo.
Old 08-12-2010, 10:21 PM   #25 (permalink)
Member # 122916
The current plan for the front (because I already have spicer d60 6.17's)
machined up some full length 1/4" wall internal sleeves with seal provisions to press in to the axle tubes.
And for the rear: I was pretty disapointed about the wimpy 30 spline shafts, apparently 60 rears are mostly lame, but because I already have the gear set, most likely I'll run it.
