Pushing The Limits! - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2011, 01:59 PM   #26 (permalink)
Member # 175105
Originally Posted by 8lug xj View Post
all of my pics came from my phone my camera took a shit. I just bought a new one so all new pics will be bigger
If u r using photo bucket to post them from ur phone, u can go into the settings and resize them larger
[B]89 XJ 350 D60/14B nv4500/203/205 linked 2.5 16" coilovers 39.5 iroks [/B]
2007 chevy d-max town rig
littlejoe83 is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 10:31 PM   #27 (permalink)
Member # 185648
Good and Bad!
So I have good news and bad. I ordered my rear heims today and a dimple die set 1/2in threw 2 1/2. Got a big part of my stiffeners on and the rest of my boat side supports on. I'm grabbing some more tube in the morning so I can get the tubing done under the hood and build the front shock mounts. The bad news is after this weekend this project wil be on hold I got an offer on my daily driver that I couldn't turn down. So now I have to get my 72 short wide back together. The one good thing is I have everything I need to build It at the shop except the one piece glass its on the way. The bad thing is its a bare blasted cab on a cart right now. Ill be back on the jeep in about two weeks
8lug xj is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 09:09 PM   #28 (permalink)
37FABRICATION's Avatar
Member # 188402
I dig it..
3SEVEN
H.F.F.H.
37FABRICATION is offline   Reply With Quote Quick reply to this message
Old 05-01-2011, 11:26 PM   #29 (permalink)
Member # 185648
front tubing
got a little more done. Its not finished going to ad a couple more tubes gussets and brackets just waiting for my dimple dies.
Old 05-02-2011, 11:13 AM   #30 (permalink)
Member # 161897
looking good! any plans for a brace where the 2 tubes bend into the engine bay?
like so:
Build Thread:
96_xj is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 03:14 PM   #31 (permalink)
Member # 185648
like so:
yes I do there will be a bolt in brace a little back from that. it will bolt into the shock mounts and continue to the outer tubes.
Old 05-04-2011, 06:20 PM   #32 (permalink)
Member # 122116
lookin good mike !!!
92 gmc ls1 with tons links and cases 44" Boggers
Top truck challenge 2014!
abigassbowtie is offline   Reply With Quote Quick reply to this message
Old 05-21-2011, 03:15 PM   #33 (permalink)
Member # 185648
a little work done.
I got my dimple dies so it was time to get a little work done. I still have some finish work to do but its getting there.
This is at ride hight 3.5 up travle. It looks taller then it is 2 inches of lift from stock. I need my 42s!
Old 05-21-2011, 03:33 PM   #34 (permalink)
Member # 185648
so my bad again on the small pics i resized them and they still came out the same. Im workin on it.
Old 05-25-2011, 01:05 PM   #35 (permalink)
Member # 185648
frame
getting the middle of the frame finished up and the upper link brackets in.
Old 05-29-2011, 08:21 PM   #36 (permalink)
rubiguy's Avatar
Member # 85872
any more updates?
1992 Jeep cherokee
rubiguy is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 04:46 PM   #37 (permalink)
Member # 100397
I like the upper shock mounts, look sick! Hey, I saw you out at the ponds a few months ago, my friend and I helped push you off the huge concrete culvert! The new mods will be sweet!
Mild XJ - 8.8 rear, 4.5 RE lift, 37's nothing too special, just a cheap wheeler!
zdaily is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 05:56 PM   #38 (permalink)
Member # 185648
updates!!
just got back from the steel yard plan on getting alot done over the weekend
Old 06-02-2011, 05:59 PM   #39 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
Holy boatsides! This is coming out great! Excellent work.
3 things....
-make your pics bigger
-What is the purpose for keeping the stock tranny tunnel since you've cut out everything else?
-Why didnt you opt to dovenose?
1 ton XJ, 60/14, 42's, doubler, etc. RoXJoX President
GreatWhiteXJ is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 08:26 PM   #40 (permalink)
Member # 185648
Most of the tunnel has already been cut out. I only cut as I need as I go. As far as the narrowing the front. I still want it to look like. Jeep, the best i can when its all done. Also it will be street legal.
Old 06-02-2011, 08:38 PM   #41 (permalink)
Member # 103442
10-4 on the streetability. That was the main reason I didnt pull the trigger on mine initially. Now thats outta the question, I went for it. But I hear ya.
FWIW...mine is doved about 7 1/2" and honestly looks VERY stockish. Check my thread if your intrested.
Old 06-04-2011, 12:16 PM   #42 (permalink)
Member # 185648
I got the rear end in last night. I think I might work on bobing it today.
Old 06-05-2011, 08:20 PM   #43 (permalink)
Member # 155933
Send a message via AIM to samfordscout2
subscribed!
Wait...I bought a Scout? :bounce:
samfordscout2 is offline   Reply With Quote Quick reply to this message
Old 06-08-2011, 08:49 PM   #44 (permalink)
Member # 185648
bob
I started the bob 10 in is the plan. Once I got in to it I decided see how the stock tank would fit and it did but didn't optimize space and clearance both with how low the rig is at bump. My fix for this was to replace the rear frame rails with 2x4 1.20 4 1/2 higher and I will just shorten the hatch to match. Should be around 5in to match the bumper.
If something doesn't fit the way you want just cut more!!
Old 06-08-2011, 10:03 PM   #45 (permalink)
Member # 125848
I'll be keeping an eye on this one but like others have said, I can't wait for bigger pics too!
98ZJ is offline   Reply With Quote Quick reply to this message
Old 06-09-2011, 03:52 PM   #46 (permalink)
Member # 185648
shes out on all fours front is at bump the back is a little under.
Old 06-13-2011, 08:37 PM   #47 (permalink)
Member # 185648
the hatch
I started welding up the rear chop and getting the bottom of the rear shortened. Hopping to get some tube going in tomorrow.
The hatch will end up 6 3/4 shorter than stock. So i will build some tail light boxes. I'm not sure where to put the license plate?
Old 06-17-2011, 11:47 AM   #48 (permalink)
Member # 185648
Have not got alot done lately bu this is what I did do.
Old 06-17-2011, 12:34 PM   #49 (permalink)
tripleXJ's Avatar
Member # 67831
I dig it! keep it rockin.
My old shit
97 TJ build:
My new Shit
buggy build:
tripleXJ is offline   Reply With Quote Quick reply to this message
Old 06-18-2011, 08:00 AM   #50 (permalink)
Member # 178019
this build is badass...
...just try to take some clear pictures
n20jeep is offline   Reply With Quote Quick reply to this message
