How to lighten a zj. Pt1 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2011, 11:55 PM   #1 (permalink)
lodikrawlingkiller's Avatar
Member # 67493
Send a message via AIM to lodikrawlingkiller Send a message via MSN to lodikrawlingkiller
Well I've been wheeling my heavy pig of a zj for a while now and it became brutally clear that heavy equals broken parts. So I got out the sawzall and went to town. I figure I've dropped over 450-500 lbs. And boy did it make a difference at the hammers this weekend! So from this.
93zj-linked-spooled-9in/d44-atlas-exo'd-37's
'06 ,mega cab, 5.9 CR, edge, banks 4in, k&n intake
mateya"daddy do you know there's turtles in the desert and they're endangered?"
me "yep"
mateya "well they're stupid…don't they know turtles cant live in the desert theres no water.
lodikrawlingkiller is offline   Reply With Quote
Old 05-17-2011, 11:58 PM   #2 (permalink)
Member # 67493
To this. In about 24 hours
me "yep"
Old 05-18-2011, 12:04 AM   #3 (permalink)
Member # 184176
Looks good.
Ill be doin the same to mine soon.
I need to make a trip to harbor freight for some cutoff wheels and some sawzall blades.
[SIZE="4"][COLOR="Red"]Id rather go fishing for a day than to have crabs for a life.[/COLOR][/SIZE]
frankensteinxj is offline   Reply With Quote
Old 05-18-2011, 01:37 AM   #4 (permalink)
Member # 67493
Make sure you have some liquid courage because it took me about an hour to convince my self to make the first cut. Once I did it was on like donkey kong.
me "yep"
Old 05-18-2011, 06:08 AM   #5 (permalink)
moparmaniaccuda's Avatar
Member # 121563
Originally Posted by frankensteinxj View Post
Looks good.
HF cutoff wheels suck, I've had multiple ones shatter and explode on me.
Get them from here
moparmaniaccuda is offline   Reply With Quote
Old 05-18-2011, 06:27 AM   #6 (permalink)
CTeunuch's Avatar
Member # 121903
Get them from here
I'll second this, even the Home Depot ones are absolute garbage. I use Sait wheels now and I'd bet they last 4-5x as long. Although any wheel will explode on you if you're not careful.
94 ZJ 4.0/AX15/HP44/8.8/5.13's/35's
In the northeast? Check out [url]www.undergroundjeeps.net[/url]
CTeunuch is offline   Reply With Quote
Old 05-18-2011, 06:59 AM   #7 (permalink)
Member # 67493
Got the fuel cell in as well. I bet that alone shave 25-30 lbs that stock tank and skid plate were heavy sobs. New Holley inline pump and the 5.2 was running better than ever I do however need to clean up my ghetto plumbing.
me "yep"
Old 05-18-2011, 07:04 AM   #8 (permalink)
Member # 67493
Got the fourlink cycling better than ever. Once all the inference was out of the way. It made a huge difference.
me "yep"
Old 05-18-2011, 07:09 AM   #9 (permalink)
Member # 175105
Looks good man r u running 16" coil overs? And have u changed out ur springs after changing how heavy ur rig is?
89 XJ 350 D60/14B nv4500/203/205 linked 2.5 16" coilovers 39.5 iroks
My XJ build
2007 chevy d-max town rig
littlejoe83 is offline   Reply With Quote
Old 05-18-2011, 07:19 AM   #10 (permalink)
Member # 67493
No I didnt change my springs out. I took almost all preload out though. Just waiting on money. Then I'll do bump cans f/r limit straps new springs and coilover in the front. Right now I'm running ford radius arms w/ 9" JK springs and bilstein 6100 s up front and it blows at anything more that about 20 offroad. Bottoms out like Crazy.
me "yep"
Old 05-18-2011, 07:26 AM   #11 (permalink)
Member # 67493
Some front suspension shots.
me "yep"
Old 05-18-2011, 07:59 AM   #12 (permalink)
Member # 175105
So good I'm Thinking of running 16" coil overs on all four corners (3 link fount 4 link in rear)
Get them from here
I have a blacksmith warehouse near by that sells great cut off wheels for $1.50 each and I have never had one brake!
My XJ build
Old 05-24-2011, 05:18 AM   #13 (permalink)
Member # 67493
Not much to up date other than I laid out some visuals for my rear cage for mock up with e-tape. Lol cheap and effective.
me "yep"
Old 05-27-2011, 07:01 PM   #14 (permalink)
Bangin's Avatar
Member # 191327
I use Radnor everything. All my cut off wheels, my flap wheels, grinding wheels...etc. I love RADNOR!!
93 ZJ 6.5" Long Arms, 318,46RH,231. HP60 Front 4.56s, Currie Iron Rock Jock 60 Rear 4.56s.
Bangin is offline   Reply With Quote
Old 05-29-2011, 12:30 AM   #15 (permalink)
Member # 184176
Thanks about the grinding wheels guys. Ill check them out.
As for making the first cut, It wont be a problem for me as my rig isn't nearly as nice as yours and its no stranger to a sawzall and a grinder.
Old 06-05-2011, 07:42 AM   #16 (permalink)
Member # 67493
Well the sawsall got another workout this weekend. Lol. I bought a evolution mitre chop saw. And itsphenominal. Best 300 I ever spent!!!
me "yep"
Old 06-17-2011, 03:33 PM   #17 (permalink)
Member # 67493
Well I need you alls opinion. I did my back half job and was doing my cage when I had a thought about doing my spare tire mount and rear "stinger". It's all mock off coars so don't be brutal on the hasty cuts on the tube. But I'd like to know what you guys think.
me "yep"
Old 06-17-2011, 03:38 PM   #18 (permalink)
Member # 67493
Pictures would help
me "yep"
Old 06-17-2011, 05:12 PM   #19 (permalink)
rock junkie
mucovich's Avatar
Member # 141882
I like it, can you get some pics of the entire side profile?
mucovich is offline   Reply With Quote
Old 06-17-2011, 05:28 PM   #20 (permalink)
Member # 99927
It sucks having to lift a spare.
kota4bye is offline   Reply With Quote
Old 06-17-2011, 05:56 PM   #21 (permalink)
FroBot
AgitatedPancake's Avatar
Member # 42341
Send a message via AIM to AgitatedPancake
I think it would work out well and open up space if you put a bend near the bottom of the stinger so you could squeeze the tire vertically behind the fuel cell. Then you could use the space above the fuel cell...make a rack for a cooler or other crap you want to lug around.
Dovenosed 5 speed WJ on 9"s
and an ongoing won-ton 5.9 ZJ build
AgitatedPancake is online now   Reply With Quote
Old 06-17-2011, 06:05 PM   #22 (permalink)
Member # 67493
Oh for sure but my other option is onto of the exo where I had it before that blows big huge donkey dick getting it up there bymyself.
me "yep"
Old 06-17-2011, 06:32 PM   #23 (permalink)
Member # 67493
Ya I've got company this weekend so it might be a while lol
me "yep"
Old 06-17-2011, 07:02 PM   #24 (permalink)
Member # 67493
I tried doing it. However I dont have a bender. And also the other way I had it my fuel cell was crowded and there wasn't a who lotta room for upsizing tires down the road. However if I can get someone to bend it up for me I'd love to go that route
me "yep"
Old 06-17-2011, 07:24 PM   #25 (permalink)
Member # 99927
Chris, my rear stinger swings down, makes loading that tire a lot easier.
yeah, yeah, old pic
