I am working on a 4 link with Coilovers on my CJ-7. Has anybody mounted a coilover within the rear fenderwells of a CJ without cutting thru the top of the fenderwell?
My rollcage rear supports bolt thru the top of the fenderwell at the rear I was thinking I could bolt to the cage mounts to the C/O bracket to give more support without a cross link.
lets see some pics of the 4 link. Nice web site. I am Just starting to try a 4 link on my Cj-7. I am looking for ideas. I Thought I was going to go threw the rear fenders and mount the coilovers to the rool cage also.
This may be your best bet. If you are wanting to not hack into the tub because of the back seat you may want to think about cutting up underneath the seat while still having it. Kepp in mind, high tech shocks allow lots of options. If they are mounted like this / \ (back view), you can adjust the valving (make it heavier) so that you retain the bitch'in ride these shocks can give. The same goes for the springs. You just have compersate for angle correction factor.
Due to a small problem the FRAME I cannot mount them at a / \ angle in the rear, even with almost fullwidth axles I risk contact with the frame, the best I can hope for is a | | setup with maybe a 1" wider mount at the axle end.
Now up front due to the size of the knuckle assembly I will have to deal with a \ / setup there to clear the frame. I am waiting on my red star to renew and I will post the picture to describe what I am dealing with.
I want to make damn sure this setup will work before I shell out the coin to buy the parts.
Guess I gotta get this math thing figured out as far as the angles to set the links at. The biggest problem is one post says do it one way and the next says the oppsite....go figure.... I am still in the learning stage of my swap. I would like to do it right the first time for once!
I do ahve few people local that are going to give me a hand with it,but it is nice to see what is outhere. You just have to read threw the crap and kinda get a feel about who know there shit and who it full of it.
We have a dude in our group who just put coilovers i a YJ with TJ 44's-he had to notch the frame to put them in!!! I have been thinking about doing a coilover set up, but think that if I do it, I will run coilovers or 1/4 elliptic in the rear with leaves or 3/4 elliptic up front. My only reason being that there are 2 TJ's, 2 XJ's, and 1 ZJ in my group with coils and longarms, and the ride of a fully coiled rig feels too funkie for me. I like to feel the trail a little bit more. Just me .02
The rear wheel wells in the back are square. I would put a piece of tube from the main hoop back to your rear of the cage, assuming the rear piece is mounted to the frame. Then drop the brackets down through the top of the wheel well.
hmmm...mine are mounted like that / \ and they seem to work fine...of course I only have 14,000 miles on the rig in that set-up, so I probably don't know what I'm talking about...
if your having handling quirks it's most likely your link goemetry
CJ generally has some good input on link crap so I am interested to hear what his thoughts are on that. All I can think of are valving and spring rate issues, but that is dependent on how extreme the mounting angle is.
The only time I have seen this setup being a problem is if the tops were too close together and it couldn't control body roll...the Factory Tubular comp rig is a prime example of this(unless they have changed it for the new season)
366.7K members
