#101 (permalink) | |
Member # 132098
TMR Customs "THE BLUEPRINT" TJ Build
TMR CUSTOMS YOUR PREMIER SOURCE FOR CUSTOM FABRICATION & OFFROAD ACCESSORIES! SPECIALIZING IN: Rod Ends & Tube Adapters - DIY/Builders Components - Transfer Case Support Kits - Gussets - Link & Shock Tabs - 3 & 4 Link Brackets and more.... Check us out on FACEBOOK! Online - www.tmrcustoms.com CALL US TOLL FREE @ 1.877.503.TMR1 (8671) |
#102 (permalink) |
4502 "The Rental"
Member # 147317
Cage is lookin sahweeT!!!
Good work guys!!!!
TEAM YUKON GEAR and AXLE "The Rental" 4502 Driver: Barry "Bear" Cherneske Sponsors/Supporters: Skinny Pedal Products,Yukon Gear and Axle,Fountain Tire,Pace Oilfield,Diffsonly.com, JW Speaker, GenRight Offroad,WARN,TMR Customs,Radflow,CBR Performance Products Inc, Currie Enterprises |
#103 (permalink) | |
Member # 1919
so how much for just that piece?
![]() Quote:
#104 (permalink) | |
Member # 132098
Thanks dude! ![]() $159.95...drop me an email and I'll get one sent your way...they are in-stock!
#105 (permalink) |
Member # 132098
Couple more pics of the rear all finished up...excluding brake lines.
#106 (permalink) |
Question about your 14 Bolt Shave Kit- If you are going to cut the axle with a sawzal/grinder...How do you know how much to cut off since you have to cut the diff and the cover?
Not enough and you aren't getting all the bang for you buck. Too much and the ring gear will rub. Thanks I am very interested in your kit vs. buying from a particular other source. Scott |
#107 (permalink) |
Member # 127171
The directions are very self explanatory, and if they aren't you should be paying someone else to do it. They give you measurements of about everything they can.
"You never really know a woman until you meet her in court!" |
#110 (permalink) | |||
Member # 132098
LOL...nice reference! ![]() Quote:
#111 (permalink) |
Member # 132098
TMR CUSTOMS - DIY Bumper Components
Time to finish up the front end! Here's some pics of the D60 suspended by our TMR Customs Front 3 Link Kit, 14" ORI Struts and TMR Customs Shock Towers.
![]() ![]() ![]() ![]() ![]() And some more cleaning/prep before final installation of the cage.
#113 (permalink) |
Member # 133593
Looking awesome as usual, although it would look even better with square headlights.
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
#114 (permalink) |
Member # 111955
do you have any pics of front driveshaft clearance with the frame? i'm getting ready for a same swap in my TJ, and I would like to see what kind of clearances I'm up against. Thanks. Love the build. Even if it is 'cookie cutter.' There is obviously a reason TJ's are the most popular platform around...
#115 (permalink) |
Member # 56176
Front driveshaft is a bit of a soft spot for Tim and Mike.
![]() Looking great. Top notch everything! Keep the pics coming. See ya's at the party tonight.
The Build [url]http://www.pirate4x4.com/forum/showthread.php?t=680391[/url] |
#116 (permalink) |
Member # 1919
has anyone done those style front towers on a YJ?
the TJ frame has a ton more room in that area would a set of the rear towers I ordered be a better start point for the front of a YJ I wonder? |
#118 (permalink) |
What are the length of your rear lower arms?
I am having issues with my 14" ORIs contacting the frame or the tire and I think it is because my rear links are too short (lowers are 28") which causes the axle to swing further under the vehicle when flexed. Thanks, Scott |
#119 (permalink) | |||
Member # 132098
CLICK HERE for the link! Quote:
#121 (permalink) |
Member # 132098
Get your order in before tomorrow
![]() For the second month in a row you exceeded the bandwidth limit and crashed our site...now that we're back up we're extending the sale until Tuesday to make up for the lost time!
#122 (permalink) |
Newbie
Member # 162324
Awesome build! Can't wait to see the finished product. I'm building something similar, 14 bolt 4 linked on a CJ frame (now tha I read what I wrote, really no similarity other than the 14 bolt).... In any event am intersted in how you are going to run your brake lines to the rear. I am thinking hard tube on top of the frame and then a ss flex hose to go around the top jj to hard line down the upper link to flex hose again. Please post some pics of your solution! Anxiously waiting!
#124 (permalink) | ||||||
Member # 132098
![]() Quote:
#125 (permalink) |
Member # 132098
Next up it was time to finish off the steering. You'll see in previous pics that we machined a dish into the front diff cover, we did the same on the tie rod to gain some extra clearance and get as much steering angle as possible. Again, we're using 1.5" solid 7075 for the tie rod and drag link. After drilling and tapping the ends we tossed it on the mill and machined out the additional clearance.
![]() ![]() ![]() Then it was time to install the Derale Power Steering Cooler. We didn't want to bury it under the hood, so we kept it in front of the grill so it would get some airflow. We had to machine some clearance on the backside of the cooler to stuff it tight against the grill, and some clearance along the front side to jam it in behind the winch. I'll have some better finished pics later. Here's a pic of the mounting brackets we machined from aluminum. ![]() Next we had to finish installing the Derale Atomic Cooler in the rear for the AW4 and route all the required lines.
