TMR Customs "THE BLUEPRINT" TJ Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-23-2011, 04:10 PM   #1 (permalink)
TMR Customs's Avatar
Member # 132098
We finished up "The Blueprint" TJ build earlier this season. We've had it out to a ton of events and wheeling trips and it works great so far. Everyone asks us for more info on the build specs and has wanted to see a build thread.
We'll start from the beginning and post up as many pics and as much tech info as possible.
The donor Jeep was a 2000 Jeep TJ Sahara that we've owned since new. The current state before the build was a 4.5"RE Superflex Kit with 35"s, stock D30 and D44.
Our goal for the build was to build a road worthy truck that could handle any trail we point it at. We wanted to keep the enclosed cab for heat & air as well as 4 seats to take friends out on the trail. Driving it down the highway at 70MPH was a definite requirement as we wanted to drive the Jeep to and from trails and events. We used aluminum everywhere we thought appropriate on the build to keep it as lightweight as possible.
Our planned specs at the start of the build:
HP Dana 60 Front
14 Bolt Rear
TMR Customs 3 Link Front with Aluminum Arms
TMR Customs 4 Link Rear with Aluminum Arms
104+ inch Wheelbase
ORI ST Struts
PSC Extreme Duty Hydro Assist Steering with all Aluminum Links
TMR Customs Full Cage
Corbeau Suspension Seats
Genright Gas Tank
Atlas T-Case
Aluminum Front Fenders
TMR Customs Aluminum Rear Corner Guards
TMR Customs Rocker Guards
TMR Customs Front & Rear Bumpers
40" Tires & Aluminum Beadlocks
Warn Winch
On Board Air
On Board Welder
We'll post all the build thread pics and info in order. If you want to see completed pics check out our TMR Customs Facebook Page!
Let us know what you think of "The Blueprint" build, and if you have any questions/comments post up!
Here's some pics of the TJ before we started the build.
TMR CUSTOMS
YOUR PREMIER SOURCE FOR CUSTOM FABRICATION & OFFROAD ACCESSORIES!
SPECIALIZING IN:
Rod Ends & Tube Adapters - DIY/Builders Components - Transfer Case Support Kits - Gussets - Link & Shock Tabs - 3 & 4 Link Brackets and more....
Check us out on FACEBOOK!
Online - www.tmrcustoms.com
CALL US TOLL FREE @ 1.877.503.TMR1 (8671)
TMR Customs is offline   Reply With Quote
Old 09-23-2011, 05:50 PM   #2 (permalink)
jsawduste's Avatar
Member # 77571
In first !!
jsawduste is offline   Reply With Quote
Old 09-23-2011, 07:46 PM   #3 (permalink)
Member # 171030
Can't wait to see some pics of the progress/transformation
mallard15 is offline   Reply With Quote
Old 09-23-2011, 09:05 PM   #4 (permalink)
NEWBIE (in capitals)
Member # 141351
seen it in person... this is one you'll want to subscribe too.
great work TMR.
insert something witty here...
beakie is offline   Reply With Quote
Old 09-23-2011, 10:06 PM   #5 (permalink)
atom smasher
biohazardtj's Avatar
Member # 107507
Send a message via MSN to biohazardtj
looking fwd to seeing the build pics. saw the completed rig a couple weeks ago, was going to take it for a spin but mike took the keys out of it. :fawk:
Stupid fukin nature!
Should have been a lumberjack, then i could have gotten paid to hit trees!!
biohazardtj is offline   Reply With Quote
Old 09-24-2011, 04:35 AM   #6 (permalink)
Member # 191952
Nice guys, the finished Jeep is awsome, can't wait to see the build progess and see how it came together.
BigOrngYJ is offline   Reply With Quote
Old 09-24-2011, 05:31 AM   #7 (permalink)
Member # 190080
I saw the jeep at burls creek looks great its good to see good canadian builds on here
Jeep yj 22 is offline   Reply With Quote
Old 09-24-2011, 05:51 PM   #8 (permalink)
Member # 191542
Subscribed! Looks like the setup I'd like for mine, will follow this one intently.
wfochris is offline   Reply With Quote
Old 09-24-2011, 06:54 PM   #9 (permalink)
Member # 56176
Definitely a sweet machine. Looks and works awesome! Almost kept up with me.
The Build [url]http://www.pirate4x4.com/forum/showthread.php?t=680391[/url]
Curt's_97 is offline   Reply With Quote
Old 09-25-2011, 07:22 PM   #10 (permalink)
Member # 132098
Thanks for all the good feedback so far...aside from that Curt's_97 clown!
Let's get this build thread under way!
Based on our planned wheelbase we knew the stock fuel tank was definitely not going to meet our needs. Since we didn't want to give up the rear seat/interior space a fuel cell wasn't going to cut it, so we started looking at tanks from GenRight. We decided to go with the Alien tank since it's the smallest tank they offer, and would allow us to push the 14 Bolt back as far as we wanted without worrying about tank interference.
The Alien Tank is made from 1/8" TIG Welded Aluminum, and includes a 3/16" Steel Skid Plate. 1" more clearance than the stock tank doesn't hurt, and the tank bolts right in place of the factory unit. The tank accepted the stock pump/sensor so the install was a breeze...didn't take more than an hour or two.
Here's some pics of the stock tank stripped out, as well as some photo's to compare the GenRight Alien Tank next to the stocker.
TMR CUSTOMS
SPECIALIZING IN:
Old 09-27-2011, 05:59 PM   #11 (permalink)
Member # 132098
Next up was our rear axle selection. We went with the 14 Bolt because they are dirt cheap, readily available and would be more than strong enough for our needs. It also gave us a good excuse to roll out a bunch of new 14 Bolt specific products.
We found one locally on Kijiji that was in good shape for a fair price. It came with 2 Gear Sets - 4.10's were in it, and a spare set of 4.56's. We didn't use either, as we went with Yukon 5.38's and a Yukon Grizzly Locker.
We were happy to have our forklift to unload the heavy pig after we picked it up. We instantly stripped the rear drums in favor of using our 14 Bolt Rear Disc Conversion Brackets. Going with the discs saved a bunch of weight and makes the axle easier to service than the old drums.
TMR CUSTOMS
SPECIALIZING IN:
Old 09-28-2011, 10:53 AM   #12 (permalink)
imped4now's Avatar
Member # 124275
More!
"Don't fuck with my dog"
-heavytlc
imped4now is offline   Reply With Quote
Old 09-28-2011, 07:48 PM   #13 (permalink)
Member # 132098
Originally Posted by imped4now View Post
More!
I'll try and get MOAR pics up tomorrow!
TMR CUSTOMS
SPECIALIZING IN:
Old 09-28-2011, 08:22 PM   #14 (permalink)
Newbie
Member # 197415
I'm going to be following this one
06 TJ
08 Harley Night Train and 79 Harley Lowrider
razorback84 is offline   Reply With Quote
Old 09-28-2011, 10:16 PM   #15 (permalink)
DutchVDub's Avatar
Member # 133593
Should've kept the drums, those ribs make for excellent traction when your tire slips off the rock.
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf"
2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons
1948 Willys CJ2a: stock for now
2000 Audi S4 Stage II
DutchVDub is offline   Reply With Quote
Old 09-29-2011, 10:08 AM   #16 (permalink)
Moderator
geberhard's Avatar
Member # 5861
X2 and who needs water on the tires with those puppies
geberhard is offline   Reply With Quote
Old 09-29-2011, 12:56 PM   #17 (permalink)
alehandro3's Avatar
Member # 133869
And you can hook up one e-brake handle for each side"s e-brake cable and have really cheap cutting brakes
junk transformer: [url]http://pirate4x4.com/forum/showthrea...hlight=ol+blue[/url]
-Alex
alehandro3 is offline   Reply With Quote
Old 09-29-2011, 05:09 PM   #18 (permalink)
Rock Hard Rock On
Canyonmann's Avatar
Member # 126126
lets check it out?
We may not have it all together, but together we have it all. ROCK HARD & ROCK ON OFFROAD BROTHERS!
My Build /forum/jeep-hardcore-tech/884419-all-chrome-bling-bling-wrangler-build.html
Canyonmann is offline   Reply With Quote
Old 09-29-2011, 06:48 PM   #19 (permalink)
Member # 132098
With all these great drum brake ideas maybe we should be offering a drum brake conversion kit for all the dumbasses like us who have already converted to discs?
Since all the cool kids are doing it we wanted to add a light bar to our build. The goal was to build a bar that was easily adjustable, removable, low profile and a bit of bling.
We used 1-1/4" x .095"W Tubing, 6 of our own XM10 Rod Ends, Tube Adapters and Jam Nuts, and machined the adjustable links from 7075 Aluminum....all of which was way overkill but we're happy how it turned out.
TMR CUSTOMS
SPECIALIZING IN:
Old 09-29-2011, 07:49 PM   #20 (permalink)
alehandro3's Avatar
Member # 133869
Thats cool as shit
-Alex
Old 09-29-2011, 08:20 PM   #21 (permalink)
Member # 171030
fawking awesome... keep it coming
Old 09-29-2011, 08:44 PM   #22 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Lightbar is not my thing but its still nice work all the same. Keep posting I like this build.
93 W250 CTD 5spd
97 TJ 60/14 Atlas 40" Maxxis 106" WB
Shawn
www.polyperformance.com
UCTJ is offline   Reply With Quote
Old 09-29-2011, 08:56 PM   #23 (permalink)
DutchVDub's Avatar
Member # 133593
Another advantage to all those ribs is they act like paddles for deep water crossings.
Seriously sweet build. I'm liking what I'm seeing, and I know how much that matters to you.
Old 09-30-2011, 02:23 AM   #24 (permalink)
Member # 131813
How much for a light bar with no lights.
tjon37 is offline   Reply With Quote
Old 10-01-2011, 04:54 PM   #25 (permalink)
Member # 132098
Originally Posted by alehandro3 View Post
Thats cool as shit
Thanks guys, appreciate the good feedback!
Keep it up, you guys are writing all my marketing material for the new drum brake conversion kit!
We built this one as a custom "one off" with no intentions of selling them. If enough people like them we can look at adding it to our product line...most likely in "kit" form so you can finish it off to your liking.
TMR CUSTOMS
SPECIALIZING IN:
