Member # 133593
Clutch as cutting brake?
I'm still searching but has anybody turned their clutch pedal and stock clutch master cylinder into a cutting brake? I'm swaping an AW4 into my YJ and thought that it would be a cool way to take advantage of the extra pedal.
"The American people sleep peaceably in their beds at night because US Soldiers stand ready to do violence on their behalf" 2000 XJ Classic: 4.5" lift, 4.56's, Alum Beadlocks, 35's, and all the other soccer mom add-ons 1948 Willys CJ2a: stock for now 2000 Audi S4 Stage II |
Member # 133593
Answered my own question, the clutch master only has a line out, not a line in. Duh.
I would like to mount the cutting brake master to the clutch pedal though, I think that would be pretty usefull.
#4 (permalink) | |
Doublewide engineer
Member # 6971
Providing your clutch master cylinder has enough volume to actuate the calipers (which I doubt) it would work. Rig up the right sized caliper on the T-case output and the clutch master should work like a champ.
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
Doublewide engineer
Member # 6971
It would lock both rears for a front dig. No way he's going to be able to control an individual wheel with only the one pedal.
Member # 133593
Yes, I would be locking up both rears. As it stands now I've been able to do front digs with the 3 foot shuffle and powering through my front brakes, so I see no problem having both rears actuated by the cutting brakes. The fact that I'll only need 2 feet on 2 pedals to do it (1 on the clutch turn cuttting brake and one on the throttle) instead of the current 2 feet on 3 pedals will in itself be a lot nicer.
Cutting brakes are in-line with the normal brake lines, thats why the clutch master won't work. There is no where to hook in the feed from the brake master.
Moderator
Member # 5861
Really not a bad idea at all. I.e. on my yj, I used a manual valve as a parking brake that locked the rears, no issues with that. Someone here posted a simple setup using the stock e-brake cable foot (YJ\CJ) actuated or hand (on a TJ), that was pretty clean, basically you could use the hand brake as a cutting brake in that case (press brakes, push e-brake pedal or hand brake to hold pressure), release brake pedal, and rears are locked.
The same concept will apply just need t figure out a way to utilize the pedal. In my opinion I would not use the clutch master as the cylinder connected to your main brake line as the clutch MC's are prone to failure, what could leave you ultimately with no brakes. Last edited by geberhard; 09-26-2011 at 02:55 PM. |
Member # 17986
Having both lock up is just a manual line lock or just rear brakes, not cutting brakes. You'll need two masters to have cutting brakes.
98TJ 5.9/46RE/D300 RAC Pansy-Ass Offroad |
#12 (permalink) |
Member # 98189
What I've done in the past is run two Wilwood pedals with a single master on each, one for front and one for rear. Place 'em close together (basically touching sides) so that you have to really think about it to step JUST the rear...
#13 (permalink) | |
Member # 1792
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers. |
#14 (permalink) |
Member # 133593
My original thought was to use the clutch master, but after looking at it I doub't it would hold up at all. What it looks like I'll be doing is figuring a way to mount the master from the cutting brakes in a manner that allows them to be actuated by the clutch pedal instead of with a hand lever.
I was thinking of this too, just wasn't sure how well those worked not having any form of booster. I saw them do it on Extreme 4x4 with one of the buggies they built and thought it a cool idea. Not sure if they did it but I figured it would be easiest to just weld a bar to the front brake pedal so that when you ppushed on it then rear brake pedal would also be depressed. You would still be able to hit the rear brake pedal only for doing a dig.
#15 (permalink) |
Doublewide engineer
Member # 6971
Stop by a tractor store and look at the brake pedals. Notice the little flip bar that locks both brake pedals together. Flip it over to lock em for street driving, then flip it to unlock the pedals when on the trail. Done deal.
#16 (permalink) | |
Member # 98189
![]() Also, the Wilwood pedals are designed to run with no booster, so master bore, pedal ratio, etc is all sized appropriately. No problems as far as breaking power. |
#17 (permalink) | ||
Member # 133593
I figured as much. I'll look into that as well, It'd be nice to make some room under the hood by ditching the booster and my massive Lincoln master cylinder.
