Old Skool CJ Build - Page 19 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2012, 07:14 AM   #451 (permalink)
"Mike Honcho"
yjwrangler95's Avatar
Member # 81277
Here are some poser shots.
yjwrangler95 is offline   Reply With Quote
Old 05-09-2012, 09:37 AM   #452 (permalink)
Member # 100810
Looks like a bad case of jock itch on the 2nd picture
awacjeep is offline   Reply With Quote
Old 05-09-2012, 09:45 AM   #453 (permalink)
"Mike Honcho"
Member # 81277
I had a little going on,I like playing with it.
Old 05-09-2012, 09:53 AM   #454 (permalink)
Member # 70006
I'll be over for the first race tonight about 9:00.
DE
onebadtj is offline   Reply With Quote
Old 05-09-2012, 12:33 PM   #455 (permalink)
3j7
nobody special
3j7's Avatar
Member # 79635
i'll bet on dh, gm all the way!!
looks great derek!
3j7 is offline   Reply With Quote
Old 05-09-2012, 12:46 PM   #456 (permalink)
"Mike Honcho"
Member # 81277
looks great derek!
I might pull a Pete Rose on this one. I'm not sure I've got SRT8 Homo Power
Old 05-09-2012, 01:02 PM   #457 (permalink)
Member # 70006
I'm headed home now to strip some weight off of it so I have a fighting chance. The cooler stays though.
DE
Old 05-09-2012, 08:06 PM   #458 (permalink)
"Mike Honcho"
Member # 81277
More poser shots, never made it to the farm to hit the fork truck but found a dirt pile on the way.
Looks like the shafts are going to work at full flex. I was concerned with maxing out the cv and yoke on the front but I'm pretty sure its going to work or really really close. the shaft does hit the transmission shifter, I'm going to have to put a bend in it.
The guys at Olymco in Clarksville Indiana did an excellent job not exhaust. I could not have been any happier that and I'm pretty tired of tabbing. It was nice to just tell them that I want and come pick it up. I would recommend them for any custom exhaust work. I'll get some pics tomorrow.
i drop about 30 miles today, it ran really good, the computer started learning the shift points and driving style, it got better the more I drove it.
Its definitely time to do some shock tuning. That and I still need some helps with BRAKES! ANYONE have any IDEAS On the MANUAL BRAKE SETUP??????
Pics, found some friends along the way and I wasn't even the firs one to put it in the dirt.
Old 05-10-2012, 04:55 AM   #459 (permalink)
mattgettel's Avatar
Member # 189813
Looking Damn good! Glad those drivelines went in without too much problem.
mattgettel is offline   Reply With Quote
Old 05-10-2012, 04:58 AM   #460 (permalink)
"Mike Honcho"
Member # 81277
I'm 90% sure that they are
I still need to lift it up and check full droop for cv bind. The slips seem to be plenty. It really doesn't move that much through the range of motion, maybe 3/4 of an inch.
We could not have gotten a bitter shaft in there though, they are nice.
Thanks Gettelfinger
www.republicdiesel.com
Old 05-11-2012, 06:30 AM   #461 (permalink)
Member # 100810
You got this pig ridin on a cloud of titties yet?
Old 05-11-2012, 08:45 AM   #462 (permalink)
WFTW Part Deux
quaylefarmer's Avatar
Member # 19355
If I send you some $ could you make me up a set of those bad a$$ hood tie downs.
The Bolt on Billionaire needs some of that action.........
The Bolt-On Billionaire
quaylefarmer is offline   Reply With Quote
Old 05-11-2012, 09:06 AM   #463 (permalink)
mattgettel's Avatar
Member # 189813
I don't know how anyone could have put that question any better. Well done.
Old 05-11-2012, 10:57 AM   #464 (permalink)
Member # 157647
Thems street legal in Floyd Co.
Clowns to the left of me, Jokers to the right.
Clowns to the left of me and jokers to the right.
HappyTj is offline   Reply With Quote
Old 05-11-2012, 02:46 PM   #465 (permalink)
Member # 157647
I feel so inadequate.
Old 05-13-2012, 08:05 AM   #466 (permalink)
"Mike Honcho"
Member # 81277
Shakedown run was yesterday. Everything seemed to work pretty good except the brakes and I need some shock tuning.
Coming down off a ledge the front and the rear would bottom out pretty hard. They need some work. It is very stable and rides pretty good just not quite right in my opinion. I pulled 100cc's out of all 4 shocks, they were incredibly stiff before and would not even move on the road. It rode like a leaf sprung jeep.
Old 05-13-2012, 08:12 AM   #467 (permalink)
"Mike Honcho"
Member # 81277
More pics
Old 05-13-2012, 06:32 PM   #468 (permalink)
3j7
nobody special
3j7's Avatar
Member # 79635
hey, dick!! that is just uncalled for!!
Old 05-13-2012, 07:21 PM   #469 (permalink)
Member # 131296
sweet looking rig,
i may have missed it but are you using the stock brake system? (no booster)? i just did a 1 ton swap on my 75 cj-5 and was thinking about upgrading it with twin piston calipers and mabey a vac boost system but im not too sure,
any thoughts?
86 cj-5 frame, 76 cj-5 body, put together on 35" krawlers, 360v8,np435,d300 twin sticked
whitetrashxj is offline   Reply With Quote
Old 05-13-2012, 07:29 PM   #470 (permalink)
"Mike Honcho"
Member # 81277
Originally Posted by whitetrashxj View Post
sweet looking rig,
any thoughts?
Thanks man, I'm happy to have it moving again.
I'm running manual brakes with dual piston fords in the front and 3/4 ton chevy's in the rear with a corvette master and no proportioning valve. It will lock the rears up on the street and the fronts won't' slide in wet grass.
I've got a YJ single diaphragm booster and a Dodge 2500 master with an adjustable proportioning valve I'm going to throw on tomorrow. There's a thread on there with the exact set up and says it stops well. Mine will pull through the brakes as of now.
Hope this helps.
Sorry Josh, but your's doesn't ride like a leaf sprung jeep.
Middel Fangars.....
Old 05-13-2012, 08:57 PM   #471 (permalink)
Member # 131296
Awesome, thank u, do u by chance have the link for that brake setup?
I'm running d60 drums in the rear and twin piston ford calipers on the
Front,
Thank u
Old 05-14-2012, 07:10 AM   #472 (permalink)
"Mike Honcho"
Member # 81277
Front,
Thank u
Link do Dodge Master Cylinder
/forum/jeep-hardcore-tech/677082-ram-2500-master-cylinder-mc-upgrade-yj-tj.html
I should have some results of this on mine later on tonight or tomorrow if all goes well.
Old 05-14-2012, 07:51 PM   #473 (permalink)
"Mike Honcho"
Member # 81277
Got all fired up tonight to do some power brakes, had a yj booster, didn't take long to realize that the shaft was wrong for the cj pedal assembly as well as the bolt pattern. Had a tj booster sitting here as well, got it bolted up, bolted the dodge master cylinder on and the hood wouldn't close.
At this point I'm getting pissed, I spent my lunch break putting ali this shit together and it doesn't fit. Drilled out the corvette master cylinder to fit the tj booster, hooked it all up, and I guess there is a seal that is needed for the booster between the masters and the booster, cause it had a horrible vacuum leak, either that or it is shot. I got pissed and bolted the manual brakes back up with the proportioning valve. It is better than it was without the valve but still needs work. At least the rear doesn't lock up anymore. So I'm kinda at a loss for braking at this point.
Any suggestions would be appreciated. I'm trying to keep this simple and not go hydroboost.
Old 05-14-2012, 10:21 PM   #474 (permalink)
Member # 127171
There's a thread on running the ford E350 mc. Dunno if that would help or not.
"You never really know a woman until you meet her in court!"
sleepsontoilet is offline   Reply With Quote
Old 05-15-2012, 03:18 AM   #475 (permalink)
Member # 130731
Let me know if you decide to go hydroboost, I just happen to have one laying in the garage for a dodge 2500
Chip Munk is offline   Reply With Quote
