#477 (permalink) | |
Member # 70006
DE |
#478 (permalink) |
"Mike Honcho"
Member # 81277
Thanks DE, I'll give that a shot tonight.
My Build: /forum/jeep-hardcore-tech/1012076-old-skool-cj-build.html |
#479 (permalink) | |
WFTW Part Deux
Member # 19355
Works like a champ.
The Bolt-On Billionaire |
#480 (permalink) | |
"Mike Honcho"
Member # 81277
I did put the proportioning valve on and it made a tremendous difference. I can either use the TJ booster and Corvette master or I can use the YJ booster and try either master, Vette or Dodge. The TJ booster and Dodge MS will not clear the hood. What are your thoughts. I'm thinking YJ booster, its brand new, and try which ever MS works. Vette will be first, its already hooked up and bled somewhat.
My Build: http://www.pirate4x4.com/forum/showthread.php?t=1012076 |
#481 (permalink) | |
WFTW Part Deux
Member # 19355
![]() This pig on the trailer yet?
#482 (permalink) | |
Member # 157647
Clowns to the left of me, Jokers to the right.
Clowns to the left of me and jokers to the right. |
#483 (permalink) | |
"Mike Honcho"
Member # 81277
I ended up with a single diaphragm yj booster, made my own mount, with a corvette master cylinder. The dodge would not clear the hood. I may look at a van master that people say works good. It stops, but there is room for improvement. I had to reverse the lines on the master from what everyone says is the right way to get any kind of stopping power. I can throw it in reverse, slam on the brakes and lock up the fronts, but it won't do it going forward.
#484 (permalink) |
Member # 157647
The Boone trip was a great success.
More pics & video to come. ![]() Clowns to the left of me, Jokers to the right.
#485 (permalink) | |
Member # 45977
Are you guys going to Harlan next weekend? |
#487 (permalink) |
"Mike Honcho"
Member # 81277
This was the first full throttle beat down.
The CJ did really well. It needs some shock tuning and a couple things changed up. I'm really pleased with how it turned out and wheels straigt outa the box. http://www.facebook.com/video/video....00105296726516
#488 (permalink) | |
Member # 157647
#490 (permalink) | |
Member # 47947
Seriously, that pig sounds sweet and looks good. I bet it only gets better as Honcho gets it dialed and gets more seat time. How much air pressure were you all running?
89 YJ, 4 cyl, 5 sp 04.5 Dodge 2500 4x4 QC LB,CTD,6sp |
#492 (permalink) | |
"Mike Honcho"
Member # 81277
Yes
Yes, there were a couple of cables pulled on that flat hill
#494 (permalink) |
"Mike Honcho"
Member # 81277
I know bud, I think the best was on battery hill where she almost came end over end and no one got a vid or a pic. Happel can verify, it was a little sketchy at best. I love the wheel base and the width, it makes for a very stable ride.
#495 (permalink) |
Member # 47947
Those things look like they had 20 pounds or more. I bet you could run those down at about 3 psi. Although, I am sure they are pretty stiff just because of the new-ness. When those sidewalls get broken in, that thing will ride like a cadillac!
#497 (permalink) | |
"Mike Honcho"
Member # 81277
I'll give that a whirl this weekend.
#499 (permalink) |
Member # 157647
Just cause it's bad ass doesn't mean you don't have to update this thread.
